Question about Apple iPhone 3G
The speakers on my iphone 3G are barely working Im always missing incoming calls, when i watch a video or listen to a song its very low sound and therer's static. When I have my earphones in I can hear...
  • 76 Answers
Check volume settings, If not, you'll have to replace speaker
Posted on Jun 06, 2010
My phone doesnt ring for incoming calls
It can be confusing and frustrating to miss calls because your iPhone isn't ringing. There isn't a single reason why an iPhone stops ringing - but most of them are pretty easy to fix. Try these steps before concluding that your iPhone is broken and needs an expensive repair.
If you're not hearing your iPhone ringing, there are five possible culprits:
  1. A broken speaker
  2. Mute is turned on
  3. Do Not Disturb is turned on
  1. You've blocked the phone number
  2. A problem with your ringtone
Does Your Speaker Work?
The speaker at the bottom of your iPhone is used for every sound your phone makes. Whether that's playing music, watching movies, or hearing the ringtone for incoming calls, the speaker makes it all happen. If you're not hearing calls, your speaker could be broken.
Try playing some music or a YouTube video, and make sure to turn up the volume. If you're hearing audio fine, then that's not the problem. But if no sound comes out when it should, and you've got the volume up loud, it could be that you need to repair your iPhone's speaker.
Is Mute On?
It's always good to rule out the simple problems before diving into more complicated ones. In this case, you need to make sure that you haven't silenced your iPhone and forgotten to turn the ringer back on. There are two ways to check this:
  1. Check the mute switch on the side of your iPhone. Make sure that it's turned off (when it's turned on, you'll be able to see an orange line inside the switch).
  1. On your iPhone,go to Settings and tap Sounds (or Sounds & Haptics, depending on your model). Make sure the Ringer and Alerts slider isn't all the way to the left. If it is, move the slider to the right in order to turn up the volume.
Is Do Not Disturb On?
If those aren't the problem, it could be that you've enabled a setting that mutes phone calls: Do Not Disturb.
This is a great feature of the iPhone, introduced in iOS 6, that allows you to stop sounds from calls, texts, and notifications when you don't want to be bothered (while you're sleeping or in church, for instance). Do Not Disturb may be great, but it can also be tricky - because you can schedule it, you may forget that it's enabled. To check for Do Not Disturb:
  1. Tap Settings.
  2. Tap Do Not Disturb.
  3. Check to see if either the Manual or Scheduled sliders are enabled.
  4. If the Manual is enabled, slide it to Off/white.
  5. If Scheduled is enabled, review the times Do Not Disturb is scheduled to be in use. Did the calls you missed come in during those times? If so, you may want to adjust your Do Not Disturb settings
  6. If you want to keep Do Not Disturb but allow calls from some people to get through no matter what, tap Allow Calls From and select groups of contacts.
Is the Caller Blocked?
If someone tells you they called you, but there's no sign of their call on your iPhone, maybe you've blocked their number. In iOS 7, Apple gave iPhone users the ability to block phone calls, FaceTime calls, and text messages. To see whether the number that someone is trying to call you from is blocked on your phone:
  1. Tap Settings.
  1. Tap Phone.
  2. Tap Call Blocking & Identification (it's simply Blocked on earlier versions of the iOS).
On that screen, you'll see all of the phone numbers you have blocked. If you want to unblock a number, tap Edit in the top right corner, tap the red circle to the left of the number, and then tap Unblock.
Is There a Problem With Your Ringtone?
If your problem still isn't solved, it's worth checking your ringtone. If you have an iPhone custom ringtone assigned to contacts, a deleted or corrupted ringtone can cause your phone not to ring when someone calls.
To address problems with ringtones, try these two things:
1. Setting a new default ringtone. Here's how:
  1. Tap Settings.
  2. Tap Sounds (or Sounds & Haptics).
  3. Tap Ringtone.
  4. Choose a new ringtone.
2. You should also check to see if the person whose calls you're missing has an individual ringtone assigned to them. To do this:
  1. Tap Phone.
  2. Tap Contacts.
  3. Find the person's name and tap it.
  4. Tap Edit in the top right corner.
  5. Check the Ringtone line and try assigning a new ringtone to them.
If the unique ringtone seems to be the source of the problem, you'll need to find all the contacts that had that ringtone assigned to them and select a new ringtone for each. It's tedious but necessary if you want to hear those calls as they come in.
If None of This Fixed the Problem
If you've tried all of these tips and still aren't hearing your incoming calls, it's time to consult the experts. Make an appointment at the Apple Store and bring in your phone for inspection and, potentially, repair.
Dec 14, 2017 | Lands Phones
Low volume on incoming calls
remove battery from phone and reinstall after 10 mins... this seems to fix alot of things also go to sound setting a make sure the volume is turned up all the way
Jul 09, 2012 | Apple iPhone 3G
How to unlock emergency calls model iphone 3G A 1241 its showing lock code
  1. Connect the phone to the computer
  2. Hold the home button for 5 seconds and then while holding the home button press the power button until the apple logo appears, then let go of the power button but don't release the home button.
  3. open itunes and click on the iphone on the left pane
  4. click the restore button on the window with the iphone's information( this will erase all your data including apps, contacts, songs, videos, etc)
If you need any help watch this video
Feb 17, 2011 | Apple iPhone 3G
Sounds like one side of speakers is working
Hi, my name is jeff and I work for a used cell phone and repair store in Sioux Falls South Dakota called THE CELL PHONE GUY. it sounds like your speaker is blown or there is a bad connection. with the iphone i believe you would need to solder that if im not mistaken. if you would like to get it fixed give us a call at 605 335 0411
Mar 17, 2010 | Apple iPhone 3G
Iphone 3G speakerphone and headset volume is too low
Whilst on a call in bluetooth mode change the volume. It needs to be for each different "speaker" you use
Feb 25, 2010 | Apple iPhone 3G
My screen blinks during outgoing calls
The iPhone has a couple of detectors to the left of the speaker on the front screen that are designed to detect if the phone is placed against the face. I guess that these are responsible for the problem.
Check to ensure that the top left of the facade is uncovered and clean. Please be aware that some iPhone cases (particularly those for the iphone v1) can interfere with these detectors.
The iphone 3G has three detectors, the iPhone has two....
Nov 23, 2008 | Apple iPhone 3G
Making a phone call
It sounds like you have a defective speaker.. bring it back to the location of sale for an exchange. The only other simple solution i can think of is your volume is really low.. but i doubt you missed that.
Ciza
Oct 29, 2008 | Apple iPhone 3G
Apple iPhone 3G Logo
119 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
