Question about Krups XP7230 Compact Super Automatic Espresso Machine
Looking for down loadable instructions for krups xp7245
    Brigadier General:
  • 7,191 Answers
You can download the instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on May 30, 2010
Error 0A en xp7240
The sensor is not detecting any heat from the boiler element. Most common cause is the sensor has become unstuck from the front of the boiler. Second most common cause is solder failure and wire is no longer making contact. If you cannot fix it then you need to buy a new boiler so be very careful and make no mistakes about how you plan to fix it.
Feb 06, 2014 | Krups XP7245
Error 06
Look for a water leak, it may be to the base of the machine and will release out the vent UNDER the drip tray if you tilt the machine forwards. There are many places for it to leak, not easy to find, I have an outer housing with cutouts to allow me to see inside while it's running. Hydraulic ram and the distributor are the most common places to cause error 6 but there is also a tricky one where the valve on the pump releases to the drip tray. A leak is the problem, finding where/which is the hard part.
Nov 29, 2013 | Krups XP7245
I have krups xp7245. It just happened today after 2 yrs daily use.
These coffeemakers are not the easiest to work on, contact Krups and locate an authorised service agent in your area and run the fault by them, they will likely need to open it up to properly quote you. There are lots and lots of potential problems inside one of those machines. If you wish to look at yourself you are going to have to remove the top, sides and back covers. Side & back is one part. Even when you have it all exposed to not expect the fault to be immediately obvious, I have covers with cutouts so I can run it and look inside at the same time.
Feb 07, 2012 | Krups Small Appliances Espresso Machine
I had some water problems with mij krups and try to solve it. Now it gives an error 0D. What does this mean?
I have a Krups XP7240 that came with the same error code (0d). I believe that the XP7240 and the XP7245 is pretty much identical inside. The sollution for me was that the connector to the front was loose. After pressing down on the connector, the machine worked perfectly again.
RuneBune
Feb 11, 2011 | Krups XP7245
Hi. I have a Krups XP7245 combination espresso/coffee maker that leaks when I make coffee. This is a recent problem. It's out of warranty (of course), and I'd like to disassemble it to try to resolve...
I had the same problem with the XP7240. The rubber seal in the plunger that pushes out the coffee cake after brewing is worn or dirty. You need to romve the cover by taking of the top (screws in the bean collector and cover tray for cleaning tablet). You have to be rough because parts are clicked together. The face of the machine comes off by pulling it upwards (it is just clamped with plastic nudges). Once that is done you remove the 4 screws that were hidden by the stainless steel face. Then remove the electronic board (leave connections on except for bean grinder and boiler). Grinder can then be removed followed by the cream cover. Remove the 15mm steel nut on top of the arm. Remove the front and display. Then use a torix on top of the brew plate and an allan key on the bottom of the plunger. Unscrew, remove spring and seal (very small cup). Let me know if you need more instructions (take a rainy sunday afternoon to do this)
Aug 13, 2010 | Krups Small Appliances Espresso Machine
Error code 06 on a Krup XP7245
remove calk-filter in watercontainer..
Jun 28, 2009 | Krups XP7230 Compact Super Automatic...
Krups xp7230, no water running through nozzles
Yes, you're machine is identical to the xp7240. Look up the post on leaking xp7240 and follow the instructions on how to open the machine and fix the valve.
Jan 06, 2009 | Krups XP7230 Compact Super Automatic...
Krups cappuccino manual
Don't know if your still looking, but if you go in the customer service section of the Krups website (krups.com) and ask them for the manual they will email it to you. Or, email me and I can send it to you!
Oct 29, 2007 | Krups Bravo Plus 872 Espresso Machine
Krups XP7230 Compact Super Automatic Espresso Machine Logo
532 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
