Question about Crosley CDG6000 Gas Dryer
Fan blows but get no heat - Crosley CDG6000 Gas Dryer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this I fine then you’ll need to check the igniter and coils. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 30, 2010
Honeywell TH6320WF when i turn system to heat and fan on auto it says heat on but never clicks on but then when i change fan to on the system clicks on but it seems to be blowing cool air
It sounds like the heat setting is not high enough. The heat setting needs to be higher than the indoor temperature or the fan will just blow non-heated air.
Dec 03, 2016 | Honeywell Heating & Cooling
Amana ptac during heat mode will blow hot air , then blow cold , but will cycle back to heat eventually is this Normal?
if the fan switch is in the Run position and not the auto position you are getting cool are when the heat element is not on. this is kind of like a way to circulate the air. look for an auto setting it then should only come on when needed. Keep in mind it is normal for the fan to start blowing before the heating element is warmed up, this prevents it from over heating, or coming on when the fan is not working
Nov 26, 2014 | Heating & Cooling
Why would my combo A/C - Heater unit not blow air while heating or cooling is selected but will blow air just fine when set to "fan only"?
Sounds like wiring issue to me. I've delt with units like this and there is a wire lead for fan only and a separate one to run the fan when the unit is cooling or heating. I'm only speculating here but I would bet money that this was improperly installed.
Dont get discouraged though because it sounds like its working (for the most part) if you feel up to the task find the manual and check your connections. Otherwise hire a professional.
Sep 20, 2014 | Heating & Cooling
Lost heat fan still blows cold only and car overheating
Sounds like a possible water pump problem with the over heating part. About the heater only blowing cold you may have to get it "recharged"
Feb 28, 2013 | 2004 Chevrolet Aveo
HEIL HVAC, fan blows but no heat or AC
Your airconditioning system may be out of cooling gas, and if it has sufficient gas, the compressor might not pick when you put on the AC, and if the compressor did not pick ie start, you cant experience cooling effect, the fan will only be blowing.
Jan 18, 2013 | Cars & Trucks
Home AC only blows cool air when set to fan. When placed on Auto/fan it doesn't blow and no heat.
At your thermostat ,
Set switch to heat, turn up temp switch.
Fan should be set to auto. Wait up to 5 mins to be surethat somthing is wrong. If your fan comes on without heat. Check gas valve or if heat pump check main a/c breaker. If elect heat or any of above dosn't work.
Call a service company. If your in Pensacola. Look up Absolute Heating and Air Conditioning.
Oct 30, 2012 | Heating & Cooling
Hp a6320in processor fan air flow direction?
Processor fans are setup to nearly always blow air inward onto the heat sink that sits on top of the processor. The heat sink pulls heat off of the processor and the processor fan blows air onto the heat sink to cool the heat sink so that it can pull more heat off the processor. However, read the following link to see that it probably doesn't matter that much which way you put it: http://www.overclock.net/faqs/14695-opinion-****-vs-blow-way-do.html
I would definitely set it up with the processor fan blowing inward onto the CPU. If you're experiencing overheating you can try switching it to see if that helps. Use a program such as SpeedFan to monitor your computer's temperatures.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Jun 01, 2011 | HP Compaq Fan Assembly
Air conditioner and heat blower
You will have two fans, one fan blows out the rear of the unit that cools the condenser soil, one blows out the front across the evaporator that blows the cold air out into the room. Some window a/c's have whats called a squirrel cage fan assy. that has one motor that runs both fans. So you either have one bad fan motor (the evap fan motor) or you have a bad fan blade that has fallen off the shaft. Also check the filter see if it is clean.
Jul 30, 2009 | Heating & Cooling
Oven is not heating...the convection fan blows, but no heat
If the oven is electric and fan assisted,then I would suggest that the oven fan element is faulty.
Plz rate this solution.
thanks.
Nov 08, 2008 | Bosch HBL 745 Stainless Steel Electric...
Crosley CDG6000 Gas Dryer Logo
23 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
