I have a inspiron 1520 , will not power up and no lights when power cord is plugged in or battery is in
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 18 Answers
Uninstalling and reinstalling power management software in Windows Vista
In order to correct problems with the battery’s power management software, follow the steps below.
1. Click Start and type device in the search field, then select Device Manager .
2. Expand the Batteries category.
3. Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4. On the Device Manager taskbar, click Scan for hardware changes .
Alternately, select Action > Scan for hardware changes .
Windows will scan your computer for hardware that doesn’t have drivers installed, and will install the drivers needed to manage your dell inspiron 1520 battery's power. The notebook should now indicate that the battery is charging.
www.laptopbatteryinc.com.au
Posted on Jul 14, 2010
    Problem Solver:
  • 9 Answers
Adapter has gone bad or battery charger slot is not working fine
Posted on May 30, 2010
Dell inspiron 1520 won't turn on. battery indicator light at right sidr of laptop blinking blue
I would like you to try this step
1.Remove the battery and try to turn on again.
Update us with more information of this.
thanks
Feb 22, 2015 | Dell Inspiron 1520...
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Hi my dell inspiron 1520 not starting when power button is switched on..the power light blinks and goes off..and the system doesnt start. I had shown the laptop ito dell service center and they have...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
But, if you paid for the Dell service, Dell needs to fix the problem. Sounds like they replaced the motherboard with another faulty one.
Hope this helps.
Feb 12, 2011 | Dell Inspiron 1520 Motherboard
My dell inspiron 1520 does not work at all, power light is on for few seconds, then nothing happens, is this a factory defect?
have you tried chsrging it up by plugging in for a long period, make sure the cable to the transformer is actually plugged in securely they tend to work loose and look okay but arent.
Mar 21, 2010 | Dell Inspiron 1520 Motherboard
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
My screen on my dell inspiron 1520 has gone black
You've lost your desktop display.
The first thing I would do is to start the computer in safe mode. Once there, do a system restore back to the time that it worked.
I would also, just to be safe, do your disk management tasks like checking your hard drive for errors and running defrag.
Oct 22, 2009 | Dell Inspiron 6000 Notebook
Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
Aug 01, 2009 | Dell Inspiron 1525 Notebook
I have a dell inspiron 1520 that is 15 months old doesn't go on
Generally, if the AC adapter for the system's LED goes out when connected to the system, check the battery and see if it is holding a a charge (Press the button next to the LEDs on the battery see if all 5 light up)  If the battery still has power, then most likely there is a failure of the motherboard.
If you can, try another Dell D-series AC adapter and see if the same thing occurs.  If the system powers on, replace the AC adapter, if not it is a motherboard.
May 19, 2009 | Dell Computers & Internet
Computers & Internet Logo
227 people viewed this question
David Payne
David Payne
