Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
My Aman side by side quit dispensing water. It
My Amana side by side refridgerator quit dispensing water. It humms but the solenoid valve isn't openin, and no water is dispensed
How do I fix it?
  • 548 Answers
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
Posted on May 30, 2010
My Amana side by side refrigerator's ice maker is working but the ice and water doesn't come out from the water filtration system
Posted on Feb 23, 2012
Amana/whirpool refridgerator
Check water line feeding both.
Aug 23, 2016 | Amana Refrigerators
We own a Kenmore Side by side refrigerator, model #253.54622406. The water has stopped coming out of the water dispenser in the door. What could cause this?
if the ice is opperating normaly listen for a click or humm from the water valve if nothing it may be the switch first check for power at the valve when switch depressed if present replace the valve if valve has power and you hear it oppening and closing it or the line to the dispenser may be plugged. if no ice either check the water supply to the fridge and the filter in the fridge if there is one.
Mar 08, 2011 | Kenmore Refrigerators
No water to ice maker. I want to check the water solenoid to see if it is getting power. I don't have a diagram. is it a 120 volt solenoid? and when does it get the signal to open and allow water into the...
The water control valve gets its signal from the ice maker itself. Then begins the cycle of about six different functions until the ice ejector forks go to the position you see most (home) Then it tells the water control valve to open for about seven (7.5) seconds. You may test the true voltage from the female connection with a OHM meter set to AC voltage. Just have someone press the dispense water control. You can also check each sides coil windings for resistance or OHM's and they should be the same or very close to the same. Use care in the area of the coils and make sure the wires are not wet. One of the two wires for each side may be active even without pressing dispense or having ice maker call for water. Another thing I noticed is that you have two sets of water control valves. The problem is about as much with the Primary Water Control
Valve Part Numbers=> 12544002 and Secondary Water Control Valve => 12002193
as is the=> D7824706Q Ice Maker Module Whirlpool now owns Amana, Maytag, Jenn-Air and Samsung will not let me post their manuals to the public. I can answer your questions as need so If you need more answers or diagrams or photos Click Here=> Sea Breeze If you have any questions please ask, Thanks, Sea Breeze
Amana DRS2660BW Wiring Diagram
Amana DRS2660BW Ice Maker Parts Breakdown
Dec 14, 2010 | Amana DRS2660B Side by Side Refrigerator
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The ice and water dispenser on my Amana Refrigerator slowly leaks water. Are there repair parts to correct this? And how is the plastic frame containing the dispenser removed from the door?
The problem is most likely not in the door. When the dispense button is pressed it actuates an electric solenoid valve in the rear of the refrigerator that opens and allows the water to flow. Over time the valve seals get worn and the water seeps by. This is what usually causes a drip at the water dispenser. If there is a drip at the ice side then the door is jammed and is not closing fully. This allows the ice at the opening to melt and drip. Hope this helps. Please accept and rate. Good luck.
Dec 08, 2009 | Amana ARSE664BS Side by Side Refrigerator
Icemaker works; water dispenser not
You can get to it, it is just a matter of figuring which valve has gone bad. You may need to disconnect different lines and actuate the water dispenser to see if water comes out of the valve. You gain access to the valves from behind the machine by removing the access panel that is at the bottom
Jun 16, 2009 | Amana SXD524VW Side by Side Refrigerator
My whirlpool fridge/freezer
probally need to replace inlet vavle. first check to see if valve powers up when you hit lever to recieve water. you can hear valve humm if not then replace micro switch above the lever inside dispenser housing
Jun 07, 2009 | Amana ARS2464B Side by Side Refrigerator
Amana refrigerator water dispenser not working
No you don't. You have two water solenoids in the back. One for ice, one for water. Pull line off water solenoid and blow into it. For more help go live chat.
Jan 10, 2009 | Amana Refrigerators
NO WATER OR ICE AT DOOR OR IN ICE MAKER
This is Gene's solution not mine, for a Ge fridge.
Assuming the ice dispenser works fine, the first thing I would check is the water filter, then the water inlet valve on the back of the fridge.
If the water filter is more than a year old it will cause restriction to the water flow.
Locate the water inlet valve on the back of the fridge. Remove the wires from the blue solenoid and check for 120V coming to the solenoid while the water dispenser lever is depressed.
If there is 120V then the water inlet valve has to be replaced.
May 03, 2008 | Refrigerators
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
291 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
