Question about Amana 24 in. ADW862EAS Dishwasher
My dishwasher wont drain. What do I need to do?
  • Amana Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
DishwasherMy dishwasher wont drain. What do I need to do? - 2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on May 30, 2010
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Doesn't drain after washing dishes
Thank you for contacting fixya.com.
There are various factors when a dishwasher wont drain water completely.Such as clogged drain hose,worn belt,pump assembly,bad motor,defective timer,drain valve etc.Please check the bellow links to read the article thoroughly to troubleshoot your problem:-
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help#thewaterdoesntdrainfromthemachine
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | Roper 24 in. RUD3000 Built-in Dishwasher
My portable GE dishwasher is clogged and wont drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 13, 2011 | GE Profile 24 in. Built-In Dishwasher...
Dishwasher wont drain even after running rince cycle is there steps to reset system ;ready to overflow
Hi
Daniel
Oct 26, 2010 | GE 24 in. GLD5860LSS Stainless Still...
Ge profile dishwasher wont drain. i have already replaced the drain motor. Why wont it drain completely
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 12, 2010 | GE Dishwashers
Wont drain, no pump
Hi it sounds like a blocked pump needs cleaning out
Feb 17, 2010 | Dishwashers
Dishwasher does nor drain. Small residue of water
If its not the drain hose, you might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | De Dietrich 23 in. DVF110J Built-in...
My dishwasher will not drain. I have pulled off
Try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Whirlpool Dishwashers
Dishwaher wont drain-checked drain hose and its clean
The problem is most likely the drain valve. It is electrically operated and with your problem it is the most common cause.
If you need more help, post a comment.
Thanks,
Tim
May 29, 2009 | Kenmore 16719 Dishwasher
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Open Questions:
Amana 24 in. ADW862EAS Dishwasher Logo
155 people viewed this question
Top Amana Dishwashers Experts
Cleverer2
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
