We have replaced wx motor.... I think it is not getting opower, how can we check
  • Washing Mach... Master
  • 8,220 Answers
Have yall seen THIS?
Posted on May 30, 2010
I need a schematic for the Cobra 18 wx st. I see them for the st 2 but not the plain version. I have no receive on CB position. I have resoldered all the vertical connections and tried a different mic. ...
start unsoldering you final , check it for proper voltage. then do the same for the driver. Check the voltage regulator. make sure you have the proper out put voltage in the vco section before doing anything. Also make sure you are on frequency.you more then likely have a short somewhere in the receive section and you are just going to have to break it down area by area , transistor to ICs .Its going to be painstaking but you will find it.
Aug 05, 2013 | Cobra 18 WX ST 40-Channels Base CB Radio
Cobra CB 29wxnwst no weather?
I think you have a capacitor on the wx board thats been cut and / or removed.If it has been cut and its still in the radio all you have to do should be replace it. I think it # C608 ???
Jun 26, 2013 | Cobra 29 WX NW ST 40-Channels Base CB...
What exactly does the anl nb/anl button do on my cobra 29 wx nw st
ANL stands for "Automatic Noise Limiter" and NB stands for "Noise Blanker".
The ANL gets rid of a lot of interference noise caused by mechanical noise from motors and other electronic components in a car.
It also gets rid of noise from other sources of interference.
The NB is for extreme cases of noise, but can slightly lessen your receive sensitivity.
Basically both functions help decrease interference noise.
Nov 24, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Where can i get tuneup specs for Cobra 18 wx st extra low modulation
The cobra 18 wx st is the worst radio Cobra ever made. I don't know why they still make it. It's not gonna do much no matter how much you tune it up. Its a bad radio.
Get a cobra 29, and turn VR4 all the way counter clockwise.
(this will not work on the 18)
VR2 is modulation in the 18 wx st. adjust it while checking on a watt meter to see when its all the way up.
Sep 20, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
I can't pick up the WX. Nothing but static. Also used to pick up Benton County SAFE-T tower while in Tippecanoe, but not anymore.I am in Indiana.
This scanner comes programmed with several wx frequencies depending on the region you live in It will go to the appropriate frequency when your using wx.. I dont know the frequency for indiana but that is one of the frequencies that shouldnt give any problem at all. The only thing i can think of is wherever your wx is coming from in your area is having problems. Know anybody else that has a scanner? Have them check it out to see if they get the same static.
Mar 21, 2010 | Radio Shack Pro-96 Scanner
Weather bleads Over on 21 LTD WX CLASSIC(*HELP*)
sounds like your wx receiver is being activated by a bad switch replace the switch to disable the wx when you dont want it to come thru
Jun 10, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Power went of HDTV sound works but not picture
blew the opower supply and if you are lucky,juse a fuse or varistor
Apr 09, 2009 | Sanyo DS31520 31" TV
Cobra 18 wx st rf/s-meter does not function
Sounds like the radio is working meter I
would think is bad you could replace it or
run as is.
Maybe this helped
Dec 25, 2008 | Cobra 18 WX ST 40-Channels Base CB Radio
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
