Question about Shure SLX24/58 Wireless Microphone System with SM58 Cartridge Microphone
Shure slx produces low sub harmonic that makes the person speaking sound like demonic overtones.
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
I would suggest sending the system to Shure for repairs.
Posted on Jun 07, 2010
Call center agent
Since you did not give any details about the issue is, try calling Shure for assistance in troubleshooting. 800-516-2525.
Jan 24, 2014 | Shure SLX Series Wireless Microphone...
No antenna display on receiver,mo sound receiver no antenna display on slx 4
Call Shure at 800-516-2525. They are experts on their products and can help you troubleshoot. This type of problem is nearly impossible to troubleshoot in a forum.
Dec 06, 2012 | Shure ULX P4 BETA 58A Professional...
Have a Shure SLX Wireless System. The only way the microphone SLX1 or SLX2 is if they are right up to your mouth. If you put the lapel mic on a persons tie you can't hear them. The transmitter is set to...
The Shure SLX2 hand-held microphone has similar performance characteristics to the much-loved (cabled) Shure SM58 vocal microphone. It has a 'cardoid pick-up pattern' intended for close work - being spoken / sung straight into the top of the capsule at no more than about 8 inches from the mouth of the user- to minimise feedback and extraneous noise. If you double the distance between the mouth and microphone the sound level will drop four-fold so distance really matters.
The SLX1 lapel/ lavalier is a semi 'omni-directiona'l pick up pattern microphone, which should work satisfactorily up to 12 inches from the speakers mouth, but closer is better. Always try to get your users to hang it about 6 inches below their chin, at most, and preferably with the top of the microphone capsule pointed upwards towards the mouth.
Here are a few other things for you to try:
  1. There is a volume (gain) knob on the back panel of the SLX receiver unit. Try turning this up to maximum (needs a small screwdriver)
  2. Make sure that both aerials on the receiver are fully extended at different angles to each other and in a clear 'line-of'sight' with the transmitter pack, with no large bits of metal in between which could block the signal. Ideally the receiver should not be more than 25metres from the transmitter. If distance is a problem locate the receiver near to the transmitter and run a balanced (xlr) cable to your mixer/ amplifier.
  3. The angle that the receiver aerials are at should be broadly similar to the angle that the transmitter antenna is at to optimise signal reception.
  4. Make sure the receiver is not located too close to other electrical equipment which may be interfering with the signal (especially voltage transformers, CD or DVD players and hearing loop induction amplifiers which have a strong magnetic field)
  5. Always use good quality batteries - Duracell Ultra or equivalent ( do not use rechargeable batteries as they seldom achieve optimum voltage)
  6. Check that the antenna is tightly screwed into the SLX1 transmitter pack and not damaged.
  7. The SLX2 hand-held microphone has an adjustable level switch inside the body - unscrew the top of the microphone to access it - switch to maximum.
  8. Another possible cause could be an impedance mis-match between the SLX receiver and your amplifier or mixer. There are two outputs on the rear panel of the receiver. One is an XLR (large 3 pin socket) this is LOW impedance and needs connecting to a low impedance input on your mixer/amplifier. You should normally be using this output even if your amplifier has a jack-socket input (use a proper balanced XLR to 6mm trs jack cable rather than a adapter plug). The other output on the receiver unit is a 6mm HIGH impedance, unbalanced, standard jack socket (labelled 'line in'). This would normally be to connect to a guitar amplifier which has a high impedance 'line level' input socket. If you are using this output you may need to use a pre-amplifier to get a big enough signal for a microphone.
You can find the Shure SLX user manual here http://www.shure.com/idc/groups/public/documents/webcontent/us_pro_slx_en_ug.pdf
Jan 27, 2011 | Shure SLX1 Body-Pack Transmitter for...
I'm useing the SLX1/SLX4 cordless combo with a Crown headworn mic (CM 311/E SH). Sometimes the sound cuts off ! I'm based in NYC. where can I go for repair? Thanks
If the problem is with the Shure wireless, you'll need to send it back to Shure (www.shure.com/service). If the problem is with the Crown headset, you'll need to send that back to Crown.
Oct 28, 2010 | Shure SLX1 Body-Pack Transmitter for...
With the -10dB pad setting, still get distortion with loud singers using SLX Wireless Microphone. Need a mod to say -20dB pad. thanks
Yes I have this exact problem myself. Work for nightclub and our original Shure wireless was fine and we replaced it with an slx. We have MCs that really yell into the mic. I'm gonna try and find an older 58 capsule to pit on it and see how that goes. The mic would probally be fine with normal singers.
Oct 15, 2010 | Shure SLX-2 Handheld Wireless UHF...
I have A wirless slx 2 beta 58A and it rattles and now its stopped sendinga signal to the receiver any ideas
Oh, that doesn't sound good. That will need to be sent to the factory for repairs. Information is on the Shure website at www.shure.com/service
May 15, 2010 | Shure Beta 58A Professional Microphone
Remote microphone shure slx1 can't get enough volume I have control board maxed and I barely hear myself on speakers. the problem not in speakers or the sound board.the first time when I started getting...
1) Make certain the switch on the side of the SLX1 is set to "mic".
2) Make certain the output of the SLX4 receiver plugged into a microphone input, not a line input on your mixer.
Nov 16, 2009 | Shure SLX1 Body-Pack Transmitter for...
SLX SYSTEM W/ AUDIO TECHNICA HEADSET
Call Shure Applications at 847-600-8440. They can help you troubleshoot. Have the wireless system with you when you call.
Oct 12, 2008 | Shure SLX UHF Headset Wireless System...
Shure SLX24/58 Wireless Microphone System with SM58 Cartridge Microphone Logo
112 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
