Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Filter pump I have model #663T Filter pump, and for some reason it only works in manual not automatic, can you please help?
5 Suggested Answers
SOURCE: Need help installing filter pump model 635 for my swimming pool
Just go to the Intex Corp link below. Choose the appropriate pool and/or pump. At the bottom of the page you will see a link for instructional manuals and videos. Hope that helps.
http://www.intexstore.com/ProductList.aspx?categoryID=30
Oh yeah, by the way...you may want to start looking around for another pump for that pool if you plan on using it more than a year. I have had mine for 3 years and I spend more time in the pool vacumming than I do in the house!! The 635 pump is not strong enough for the 18x52 pool nor does it filter out fine silt and sand...it sucks it up and spits it right back into the pool thru the return. Good luck to you
Posted on May 22, 2009
SOURCE: hayward variflow filter SP710 O.K. with 2Hp pump?
What is the purpose of the Vari-Flow Filtration device on my pool? I installed a new 1 hp motor and still my water is not being sucked in from the pool. I fill the contained that is connected to the motor up with water and it sucks it, but not from the pool. What could be my problem?
Posted on May 26, 2010
jharwell668
  • 640 Answers
SOURCE: Krystal Clear Model 635 Pool Filter Pump 1500 Gph: I can not find my manual and I cant remember if th...
If you are talking about the plastic o-ring for your pool filter, it goes on the top, if I remember correctly.
Posted on Sep 08, 2010
jharwell668
  • 640 Answers
SOURCE: My model 603 filter pump leaks at the top under cap
It could be the o-ring on this model. There is a seal on these pool filters that looks like a rubber ring inside the lid. You might need to replace this ring if your pump is leaking here.
Sorry, if this is a silly question, but is a new Fuel Filter installed automatically/come with a new Fuel Pump? Or do you have to buy a new Fuel Filter and attach to the new Fuel Pump before installin
Has the filter ever been changed? Need to know year and model of the truck. Fuel filters can be near the tank or under the hood. Filters are usually separate from the fuel pump.
Nov 12, 2014 | Cars & Trucks
2006 yukon fuel filter
If your having trouble locating a fuel filter on a late model GM there is a good reason as to why you can not find one. The fuel filter has been combined with the fuel pump module. There is no longer a "serviceable" fuel filter on many late model GM Vehicles. The filter gets replaced when or if the fuel pump fails.
Apr 11, 2014 | 2001 Mitsubishi Mirage
I have a 2001 Hyundai elantra 4 cylinder automatic. High mileage. It starts battery electrical is good. It will drive for a while, if I stop and start it it will start but when I press gas it dies like it...
on a 2001 and later model the fuel filter is part of the fuel pump. it is located in the engine compartment. you should get a Haynes repair manual for your vehicle.
good luck,
frank
Sep 03, 2011 | Hyundai Elantra Cars & Trucks
My intex saltwater/pump system pumps water strong for about 20 minutes, then the flow slows down to a trickle. No warning beeps or lights come on. It ran strong for 9 hours as the manual stated when I...
Thank youfor posting your question here on Fixya.com. When a pump is shut off it gives the sediment in the filter a chance to become suspended in the water and not on the filter cartridge surface. When you turn the pump on this dirt does non restrict flow as much because it is not all on the filter and then it starts to collect there restricting again the flow. For this reason when this happens the filter cartridge needs to be removed and cleaned off with water from a hose with a spray attachment. The attachment should be set to a single strong jet. Once the filter is reassembled check to see how long it can go without reducing flow. I think you will be surprised.
Ifthis answer does not fix your problem, please comment with additional detailsprior to rating the answer. Positive feedback is appreciated once your problemis solved! Thank you
Aug 28, 2011 | Intex Automatic Salt Water System for ...
Getting same green film on top of water that is the same color green as the copper piece in the salt water pump has turned
The two green colors may be associated somehow but when you say anything about green water I think it is more likely the water is turning green from algae. The best way to rule this out is to test the chlorine level and then shock with vinyl shock to about 10 ppm. If it is algae then the it may be cloudy but should turn more blue rather than green. If other chemistry is good such as salt concentration and stabilizer then running the pump, filter and chlorinator according to the Intex manual. When a pool is shocked the filter can get dirty quickly and then reduce the flow. For this reason make sure you clean the filter. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Intex Automatic Salt Water System for ...
The water will not drain automatically we must use the outlet on the lower left bottome to drain manually...the error code we see on the device is "OE" what can we do to fix this?
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a millimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... Please revert for any further assistance.
Daniel
Feb 11, 2011 | LG WM-1832C Front Load Washer
Machine won't rinse stops at 21. took hose off pump and seems to work ,will drain if lower hose.will then stop at 11 min mark please help lost manual.
send the model number next time.the pump is blocked.if your model has the removable filter in the middle of it you have to remove it and clean it out.with a shop vac vac out all the water in the tub,then turn the filter counter clockwise and when the water starts coming out slowly vac it up until all the water is drained,remove the filter and clean it out.add some water and set it to drain and see if the pump works,if it does then you're all set,if it doesn't remove the filter again and make sure nothing is stuck in the pump,if it's clear you probably damaged the impeelar on the pump and need a new pump but they are pretty hard to brake,if it doesn't have the filter pull off the hose and vac out the pump then stick your finger in there or a screw driver and make sure the pump is clear,also check the hose to make sure that's clear,if it doesn't drain most likely you'll have to replace the pump.if you need more help let me know and send the model number,open the door and look around the opening of the dryer not on the door and you'll see the model number
Dec 22, 2010 | Washing Machines
Need to get a manual/directions for Intex pool filter pump for model 635
HI,
Please click on the below link to buy the manual for your model.There is no free manual available for your model on the net so you will have to buy it for $5.
http://www.coolinflatables.com/product/626825-11
Jul 08, 2009 | Intex Krystal Clear Model 635 Pool Filter...
May 17, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
