Question about Vizio VP322 32 in. Plasma TV
I have a VP322 32" Plasma TV with bad capacitors
I have a VP322 32" Plasma TV that is about 1.5 years old (so obviously out of warranty.) I already know it's the capacitors that need replacing and even know the ones that need replacing. *grin* Not bad for a girl, eh? haha
This is the list I have and the location of the capacitor:
Loc. V. uF Temp.
C233 10V 3300 105 C(M)
C234 10V 1000 105 C(M)
C236 10V 1000 105 C(M)
C204 25V 1000 105 C(M)
C205 25V 1000 105 C(M)
C238 10V 470 105 C(M)
C241 10V 1000 105 C(M)
Those are all the capacitors that need replacing. I have been to several electronic stores in my area and no one... and I DO mean "NO ONE" has the parts I need. I want to purchase parts that are comparable, but have a higher temperature threshold because obviously that is the problem. There's no point in me replacing bad parts with the same parts that are also going to go bad in only a matter of time, so I want to replace the parts with a higher tolerance, higher temperature threshold, and if I have to use a higher voltage that's fine as long as I get the other two conditions.
Anyone have any idea where I can get what I need, or if they have the parts to sell? This is turning out to be more difficult just to get the parts than to do the actual repair. I already have a soldering tool. :o)
Thanks in advance to anyone who responds to my plea for help... (can you hear me now??) haha
Terrae
  • terrae May 30, 2010
    Well.. I haven't been able to find any for sale with the same specs.. and actually.. from everything I've read on here, and other forums as well, they have all said the same thing.. overheating of the powerboard.. and since the temp threshold is 105 degrees on ALL of these caps.. I can see why... I live in California and last year during the summer, it got to 110+ degrees here.. so that, coupled with the temp of the unit itself.. I can see why it would be a temp issue... just saying... it makes sense..
    As for the 10V.. if you are referring to how many bad ones I have on the powerboard.. there are 5, 10V caps that are bad... check the list of bad caps that I posted above.. it's not just the 10V caps that exploded.. there are also 2, 25V caps as well... none of the electronic shops around here have those voltage caps with a higher temperature threshold, they do not have a higher voltage cap with a higher temperature threshold either... so, I'm at a loss as to where to get what I need... as I said... I don't want to replace it with equivalent parts or I'm going to be doing this again... and having the same headache finding the parts I need...
    So, would prefer to fix it once and be done with it... right now, my TV is all torn apart and sitting in my room.. lol
    Thanks for responding... I really appreciate it... and I don't care if I have to buy the parts online, I just need to be able to buy parts that I can swap out for a higher quality and more tolerance, etc...
    So... my question is... what caps can I use that are:
    1) higher voltage and higher temp threshold for each of the caps that need replacing??
    2) Once I know what I need, since this is not my area of knowledge base, I have no idea where or how to order the necessary replacement caps...
    Terrae
I just got off the phone with a Vizio rep - My VP322 also stopped powering on - 2 years and 2 days old. They are sending a repair person to fix the TV with NO charge to me. I had no problem with them, just called and told them what had happened (wouldnt power on), they took my information and informed me that they can authorize a courtesy repair for 1 year AFTER the warranty expires. They returned my call within 5 hours with the name of the company that will contact me to repair the TV in my house. I will let you know if they actually come through
Posted on Jun 28, 2010
  • terrae Jun 30, 2010
    Morello, I had the same problem... it would turn on and off a gazillion times before it would stay on... then one day, it just would not stay on at all... took me 2 tries to get it right because this is just not my area of expertise... but I did finally get it right..... I replaced all the burnt out capacitors myself... all it took was a little time, capacitors with a higher voltage, and some soldering... but I did it... pretty proud of myself... I haven't seen too many females on here who take on repairing their own television sets.. ;o) Terrae
    Sniper:
  • 67 Answers
Temp is not the problem you need to replace with higher voltage rating this is a 12v board how many 10v caps u gots?
Posted on May 30, 2010
I had the very same problem and thanks to great advice from this forum and others, I fixed it! I simply looked for the bad capacitors (since it had no response at all when pressing the power button i assumed it was in that area), the ones that were bulged at the top. I got the specs from them which where clearly printed on the side, and ordered new ones from MCM Electronics. I'm no soldering whiz, but with some expert tutorials and videos, i have to say i did a darn good job and it works like a charm! BTW, someone had put it out at the trash, and i put it in my truck figuring what the heck. $20 (including shipping) later, and I have a $500 TV.
Posted on Aug 12, 2010
  • 1 more comment
  • Troy71Phin Aug 12, 2010
    I had the same problem with the capacitors. If its a "turns on/off/on/off" thing it sounds like capacitors to me (though not necessarily). Most other electronic devices either fail to the point of not working at all or not, caps will be intermittent at times, especially when heated to the point of "semi-failing". I found one of these TVs on the side of the road ready for the garbage man to pick up, so I put it in my truck figuring what the heck. It didn't turn on at all when i got home. Upon checking inside I noticed two capacitors on the power board bulged at the top (a sure sign of failure). I couldn't find any matching components locally so I ordered them through MCM Electronics (Good delivery time and service, highly recommended.) Long story short, $20 later I had a $500 TV.
    oops, posted twice, sorry
  • terrae Aug 13, 2010
    Troy - that is GREAT! Wow... they lost a $500 TV set, and you got a $500 TV set for $20 - how can you beat that?! :o)
4 Suggested Answers
  • 12 Answers
SOURCE: No Picture on Vizio 42 in. Plasma
There is no backlight on plasma TVs. If you have a black screen than most likely one of your sustain boards are gone. Board can be purchased on line at about $100. If your TV has no signs of life it's most likely the power board. Any way it would not be that expensive to fix if you are able to take the TV apart and swap the boards. But I need to say that I recommend to do it ONLY if you are qualified enough. Otherwise ask your local TV repair company to service your TV.
Posted on Sep 06, 2009
SOURCE: My Visio 50" Plasma Model#
I just solved this kind of problem with my VIZIO VP504FHDTV10A. It was main power supply that went bad. You need to open back panel cover and right in the middle you will see two powersupply boards(subpower board(smaller) and big main powersupply board). Just get board part/model # and search it on eBay(what I did). It was approx. $100. Good luck.
Posted on Feb 05, 2011
SOURCE: Replacing a Vizio Backlight Inverter
I have a television that did this. The picture went out but it continued to have sound. It was the projector bulb. I ordered from a dealer on ebay, very resonably priced. It came with instructions on how to install it and was a very easy fix.
Posted on Feb 25, 2012
I have a 4 year old Samsung Plasma. While watching tv, the tv will turn off and then keep trying to turn back on, but is never able to turn back on. We unplug it, then after 1/2 hour it will work again...
Good day!!!!
You have a better chances if you have failing bad capacitors on the power supply board...
bad capacitors sometimes bulged on top,sometimes not...if the caps is bulged you can easily identify it..
Thanks for using fixya..
Aug 04, 2011 | Samsung HP-R4252 42 in. Plasma HDTV
Our Panasonic 50" TH 42PX75U
well it sounds like something fried inside the tv. In my experience, this sounds like your y-sustain board went bad. it could be your video board also. considering todays value of the 50" panasonic plasma, it will be cheaper to replace it, unless you are willing to spend around $300 to get it fix at a shop.
good luck
Jun 17, 2011 | Panasonic TH-42PX75U 42 in. Plasma...
Suddenly lost picture, sound is still working. The TV is 3 1/2 years old. Any fix for this? Parts?
If you are lucky it may be asimple power supply problem, with dry electrolytic capacitors. If you can find one or more capacitors with domed tops instead of flat tops, then it is an obvious sign that the capacitors require replacing.
Feb 25, 2011 | LG 42PC5DC 42 in. Plasma HDTV
My 2 year old 60in LG plasma turns on and then turns off right away automatically.
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem.
Hope this helps and Good luck.
Kaufman605
Dec 12, 2010 | LG 60PS60 60 in. Plasma HDTV
Tv just turns itself off and then starts clicking like its trying to turn on and off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 03, 2010 | Samsung PS42C91HDX 42 in. Plasma TV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Vizio plasma tv turned off..won;t turn back on
This sounds like the main power board went bad. If this is still under warranty, contact 1-877-MYVIZIO and they will have it repaired for you. if not, let me know and I will guide you to the right part.
Jul 15, 2008 | Vizio P4 46 in. HD-Ready Plasma Television
50"lg plasma tv
The popping noise you heard it's probably a capacitor blowing up in the power supply circuitry. If the TV is less than one year old, still covered under manufacturers warranty.
Let me know if you need any more assistant let me know.
Feb 28, 2008 | LG 50PX1D 50 in. Plasma Television
Bright Green Vertical Line on Plasma TV
two options 1 check ur power moudle for burst or swolling filter capacitors & check the electrolytic power capacitor in the primary side of ur power moudle .
Oct 24, 2007 | Audiovox FPE3206 32 in. LCD Television
Vizio VP322 32 in. Plasma TV Logo
1,503 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
