Question about Kodak Esp 3250 Allinone Multifunction ( C InkJet Printer
My Kodak esp 3200 series printer wont acknowledge the new black ink cartridge I just put in. Now it is saying-" black inkcartridge needs replacing-replace black ink cartridge".
  • 38 Answers
Is this a genuine ink? If not then try removing and inserting a few times. If this does not work then unplug printer, leave for a few minutes then plug in and turn on. Some non-genuine inks (and some genuine) just do not ever work though.
Posted on May 30, 2010
Kodak ESP-3 All-in-One-Printer still says black ink catridge is low after I replaced it
There is a sensor in the cartridge which contacts with the printer. See it is clean from dirt. Try reseating the cartridge. If you use cheap cartridge rather than genuine then this could happen.
Check for updates in the Kodak website appropriate for you.
http://support.kodak.com/app/intfSel/intf_redirect/L2FwcC9hbnN3ZXJzL2RldGFpbC9hX2lkLzE3MzAzL34va29kYWstZXNwLTMtYWxsLWluLW9uZS1wcmludGVyLWZpcm13YXJlLS0td2luZG93cy1vcGVyYXRpbmctc3lzdGVtcy9vcmlnX2ludGYva29kYWtfYjJjX2Vu
Dec 01, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Just had new printer again kodak esp 7 and got same problem black ink cartridge not printing
are the ink cartridge you are using refurbished because sometimes the printer wont read them had a simular prob with my printer you might have to just buy new ones for it
Sep 30, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
My Kodak printer ESP 3200 Series has stopped printing. It functions as it will print but no black ink will print. I have checked the cartridge levels and all ok, done the maintenance tests and now not...
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Mar 30, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I was recently given a 5300 all-in-one printer.I want to replace the ink cartridges. I bought ink(kodak) and want to make sure it is correct before I open the box. I bought an ink combo pack for an...
You got it right - the Kodak EasyShare 5300 All-in-One uses 10 series Kodak cartridges, and
since your box says 10B+10C, it has (2) 10-series cartridges in it - one 10-series Black (10B), and
one 10-series Color cartridge (the 10C).
The 10 Series Ink cartridges are compatible with:
EasyShare 5000 series (your All-in-One belongs here)
ESP 3/5/7/9
ESP 3200/5200/7200/9200 Series
ESP Office 4100/6100
Reference:
http://store.kodak.com/store/ekconsus/en_US/list/Ink_Cartridges/10_Series/categoryID.53666600
Mar 18, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak esp 9 printer is out of black ink, meanwhile all i want it to do is scan a paper and it wont do anything without new ink. The computer says the printer is busy, and the printer just says "error...
This is a common problem encountered by printer users and is in fact not a bug but considered a feature by manufacturers who build this function into printers to encourage consumers to buy their expensive ink cartridges. To fix this problem I would buy a 3rd party ink cartridge for use when your ink cartridge is empty. This way you can use your scanner when out of ink (be careful printing with 3rd party ink cartridges, many have mangled or destroyed their printers by using non OEM ink).
Feb 28, 2011 | Office Equipment & Supplies
How to remove the ink cartilidge
How do I install a new printhead in my all-in-one printer? To replace the printhead in your all-in-one printer:
  1. Make sure the printer is on.
  2. Lift the printer access door and wait for the carriage to move to the access position.
    NOTE: For ESP 3250 and ESP 5250 all-in-one printers:
    • On the printer control panel, press Home.
    • Select Maintenance, then press OK.
    • Select Install Ink Cartridges, then press OK.
      If "Install Ink Cartridges" is not an available selection, upgrade the firmware.
  3. Remove any paper that may be loaded in the printer.
  4. Remove the black and color ink cartridges and set them aside.
  5. Remove the existing printhead:
    • For ESP Series Printers, unlatch the printhead by lifting the latch in the center of the carriage.
    • For 5000 Series Printers, unlatch the printhead by pressing the button in the upper-left corner of the carriage.
  6. Lift the printhead out of the carriage.
  7. Remove the new printhead from its bag.
    CAUTION: Do not touch the copper contacts on the printhead, as this may damage it.
  8. Remove the plastic protective shields.
  9. Place the new printhead into the carriage.
  10. Push firmly against the target label of the printhead until you hear a loud snap.
  11. Insert the color ink cartridge into the printhead and press down until you hear it click into place.
  12. Insert the black ink cartridge into the printhead and press down until you hear it click into place.
  13. Close the printer access door.
    The printer detects the new printhead. Follow the instructions on the LCD to calibrate your printer.
    NOTE: ESP 3 all-in-one printers do not require calibration.
IMPORTANT: Be sure to use KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. You can purchase KODAK Ink Cartridges from the KODAK Store.
Feb 09, 2011 | Kodak ESP5 AllInOne InkJet Printer
Kodak ESP 3 doesn't print black ink!
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Can i print using black ink when im out of color ink it wont let me even though ive changed the settings to print colors as black and white
That's the way Kodak works
It won't allow yu to do anything if any of the lights are flashing or there is a error message
NO RESOLUTION
Get your color ink cartridge replaced by Kodak.
Just say its a new color ink cartridge and printer is saying its empty!!
Hurraay you'll get a free color ink cartridge
Jan 25, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak Esp 3250 Allinone  Multifunction (  C InkJet Printer Logo
1,201 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
