Question about Emerson Quiet Kool 10GV13 Air Conditioner
COMPRESSOR WONT COME ON
EVERYTHING ELSE SEEMS TO B OK WANT TO KNOW IF THE PROBLEM COULD BE THE COMPACITOR???
  • 31 Answers
More than likely it is the thermostat. Thermostat tells the compressor that the room is cool enough and to shut down. If it is faulty, it is telling the compressor that the desired temp has been reached and stop pumping use fan instead.
Posted on Jul 07, 2010
  • 674 Answers
Yes it could be the capacitor. Check it with a multimeter. If the capacitor looks swollen then its probably bad. Let me know if you need more assistance.
Posted on May 30, 2010
  • Brian Niten Jul 07, 2010
    Just wondering if you have gotten your a/c fixed?
What does the word "HERM" mean on a compacitor from a maytag 6000 btu
The word herm means hermetically sealed compressor. That wire goes to the start terminal on the compressor.
Oct 12, 2016 | Maytag Heating & Cooling
Duotherm a/c 59516.331 p/n 70130997 need to know what is attached to the top of compacitor...need to know the mfd for run compacitor as well as start compacitor. think run compacitor is=35.5 @ 370..
The wires attached to any component is shown on the wiring diagram. Use the same values that's printed on the capacitors, when replacing them. Call the manufacturer for any missing technical information.
Aug 27, 2013 | Heating & Cooling
The Ice Machine is pulling 40 - 50+ Amps on compressor startup, after 5 - 10 secs it trips the breaker. WHat could this be and is it easily corrected.
sounds like you need to change compacitor on compressor or your compressor needs replaced i would change compacitor first and if not helping then change compressor even if you buy compacitor and it doesnt help you still need to have a new one for the new compressor
Jun 20, 2011 | Franklin Industries Franklin Chef Ice Cube...
Compressor will not start, everything else seems to be ok but no compressor. this is a new unit, has never started the compressor.
Check the capacitor for the compressor. Also use a voltmeter and make sure power is getting to the compressor. Let me know what you find.
Jul 03, 2010 | Dometic Rooftop RV Air Conditioner
Should the wires coming from the run compacitor have power
The run capacitor is not a mechanical device, so the clicking that you are hearing is not actually coming from the capacitor. If you the wires going to the capacitor, (isolate the capacitor), you can check the microfarad rating of the capacitor to ensure it is still good using a multimeter. Hope this helps.
Apr 15, 2010 | Refrigerators
I have no power going to my compressor. I ohm out my two thermostats and they are completing there circuits. what do I check next?
Does your compressor have a compacitor there should be leads on top of compressor you need to ohms that also if it is hermetic the compacitor leads should be on top of compressor there should be a start and run line. Check both to the common lead marked C. Check compressor to see if it is hot at touch it could be compressor overheated let it cool over night it may start back up.
If neither of these are the case check your transformer or contacts if it is 110 contact just check for continuity it should be more than .4 ohms or check load line or low voltage those should read on a contact around 8-20 ohms if not the transformer check leads there it should have continuity.
If you don't get a reading on any one of those it could be open or grounded then you need to replace those items.
make sure they are disconnected before checking
good luck
Dec 28, 2009 | Frigidaire FRS23R4A Side by Side...
Compressor on sxd20tw wont shut off. just cleaned
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | Refrigerators
Compressor tries to kick in but then stops.
it is a hard start compacitor, the unit is not supposed to have three compacitors.
Apr 11, 2009 | Coleman Mach 15 Air Conditioner
Emerson Quiet Kool 10GV13 Air Conditioner Logo
90 people viewed this question
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
