Question about Bose TriPort Consumer Headphones
Wire disconnect from left earphones
The fibers on the wire on the left earphone have frayed from the base where they enter the earphone. left speaker isn't delivering music.
  • 24 Answers
Time for some ingenuity.Disassemble the housing to get to the wire connections.The solder pads where the wires go are usually marked + or minus(-). The white/colored wire(signal) goes on the + side.This could be a red dot. The other wire (black) goes on the other pad(-). These wires are so fine they sometimes use nylon thread to give it a lil strength.Good Luck! dnbbgy
Posted on Aug 02, 2010
Hi. Greetings. I have one of this set. One day while i'm playing songs on it, my siblings accidentally plugged another wire into the earphone port. When i unplugged it, there isn't anymore sound...
Put a plug in the earphone port and wiggle it . Could be the little gadget inside is stuck. I had a tv that did that and ended up disconnecting the ear plug port.
Sep 21, 2017 | Altec Lansing VS4121 Computer Speakers
Can i listen to fm radio without using earphones?
It will be depends on your mobile brand....
Jun 30, 2011 | Cell Phones
Hi the wire has frayed and is exposed at the entry point into the earphones to My 5 Series Shure earphones. One earphone no longer works. Can this be rectified? Regards, Robert....
hi,you can fix it by opening the ear that is not working and check if the wire inside the earphone has not removed. If it has removed, you can use a soldering iron and a lead to fix it back.
But if the wire inside has not removed,that means the speaker inside is damaged and will need to be replaced.
In replacing the damaged speaker, you will need to go to any nearby repair store for replacement parts .
If you can not get a replacement speaker,you will have to get a new one.
And for the exposed wire,you can use a gum or a glue to cover it up...
Hope it helps..
Thanks for using fixya.....
Jan 06, 2011 | Shure E500PTH Professional Headphones
Left earphone has lower volume than right
Maybe you can try adjusting the plug, or the wire within the left earphone is rusted, or change the sound effects on a computer.
May 03, 2010 | Philips Audio Players & Recorders
Earphones wont work on dell computer/vistas have to restart computer to go from sound to earphones . how do i fix this
first check you connected the earphone properly. earphone has two wire. connect earphone green wire where you connect the speaker.
Jan 22, 2010 | Dell Inspiron 531s Desktop Computer
The right ear has completely lost signal output. Anything I can do to save these awesome headphones?
check the wiring at the base of the right earphone .
try to put it on and giggle the wire around while listening to it .
the common problem with most head phones is the the wire is twisted too often and break at the base of the earphone .
If this is not the case , check the plug which could again be the same problem .
If the problem persist , the speaker could be faulty of one of the channels on the earphone output could be down .
Sep 27, 2009 | Philips HP-170 Headphones
Mp4 ear phones
hi the problem will be with the earphones after a bit of use the wires inside the plastic casing covering the wires where they plug into the mp4 these wires fray and eventually short out it is best to replace the earphones as soon as possible as shorting out will eventually cause the mp4 to overheat and short out.
If you have replaced the earphones and are still getting the same problem then it will be the solder points on the jack plug that you plug the earphones into the solder eventually will work lose causing bad connection but first repalce earphones then if you still have the problem but you probanly wont as the solder failing isnt a known problem with this product then you will need to take the cases off and get to the board where the earphone socket is soldered onto the board then you need to resolder the solder joint that connect it to the board.
But first repalce earphone with new ones as using someone elses or old ones might have same problem let me know if you need further assistance
Jan 16, 2008 | Konaki MP4-NS MP3 Player
Open Questions:
Bose TriPort Consumer Headphones Logo
354 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
