Question about Garden
Can anyone direct me where to buy a carb rebuild kit?
Can anyone direct me where to buy a carb rebuilt kit for a B&S 124T02-0464-B1 ?
I've been searching for a few hours and coming up empty. Thanks.
  • 284 Answers
Try Partstree.com
Click on briggs and stratton logo look to the left and enter the model where it asks
Posted on May 30, 2010
Testimonial: "Ahhhhhh. Thank you! Great parts site."
85 jeep cherokee 2.5l runs fine on level ground but the carb floods when I'm going up hills? Any solutions? Its been tuned up new plugs and wires and everything but why is it flooding?
Your carb is needing to be rebuilt the seals and float and valve seat may be damage. The float opens when the fuel level in the carb is low. If the valve seat is damaged or the float is not working. Gas can keep pouring into the carb resulting in extra fuel. Till the engine stops and fuel pump pressure stops pushing fuel it will keep pouring fuel and will not stop till rebuilt correcting the problems. Buy rebuild kit and rebuild it or try junkyard and replace it.
Feb 12, 2018 | Jeep Cars & Trucks
Why my s430 will run and idle but dies as soon as squeeze the trigger even if I do it slow? The primmer bulb was bad so I changed that but still does the same thing?
Carb is in need or a cleaning and rebuild. I would suspect the diaphragm is bad. You can get a rebuild kit with all the gaskets for most carbs for around $10. There are some that gaskets are not available for and you would need to replace the entire carb. Carbs run from $15 to $30.
Oct 16, 2016 | Ryobi Garden
Stihl weedeater
I'd put my money on it being the actual carb body. The carb body its self contains a couple of small valves which can get blocked or damaged and are practically impossible to replace. Look for a second hand OEM carb and if needed use your rebuild kit on it. That would be the cheapest route
Jun 02, 2013 | Garden
New battery, new starter & still problems starting
Hello! How long have you owned it? Question is directed at the carb and fuel pump...I would suggest rebuilding the carb with kit and replacing the fuel pump at the same time...see photos below...There are a couple of different fuel filters; one for a non- fuel pump (gravity feed) and one with a fuel pump...Your engine requires the fuel pump filter...dirt and varnish build up in the carb and pump especially if the wrong filter is installed...Buy a gallon of carb cleaner with the tray inside...
Guru...saailer
Genuine OEM Part - Manufacturer #808656...$18 Fuel Pump
Genuine OEM Part - Manufacturer #691035...$6 Filter
Genuine OEM Part - Manufacturer #797890...$45 Rebuild Kit
Feb 13, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Ryobi 765R string trimmer. Engine is starving for gas. Fuel line is flowing and primer bulb has been replaced. Engine will run for a few seconds with ether sprayed into the carb. Trimmer is 3 years old...
On muffler there is a screen located on bottom of muffler remove the two small screws in cover, remove screen and clean thoroughly. If this does not fix check price of rebuild kit for carburetor or check price of new carb. If new is within $5 of kit buy new and replace or rebuild carb.
Sep 16, 2017 | Garden
Have a bad carburetor, is it cheaper to buy used or rebuild? Is it easy to replace myself? It's a 350v8 if that helps.
I only keep my original carb & rebuild myself
I only have one 27 year old vehicle left with a carb
Rebuilding a carb isn't easy,unless you can remember
where everything goes
I wouldn't pay the large amount for a carb from the parts
store that may not work correctly
You have no idea where the core came from or what
it was originally on.
They don't go bad
The float sometimes does & sinks down or the needle
& seat get old & worn
I would rebuild it
I never bought a used part in 48 years of auto repair
for anything. Although I think were about at that point
with the availabilty & price of things today.
If you have a car over 10 years old your pretty
much out of business ,as far as a dealer having parts
May 25, 2011 | 1987 GMC Suburban
I have a husqvarna YTH18542 lawn tractor that wont start! I replaced the spark plug and fuel filter but it just does not seem to be getting any fuel to start it. If you pour gas directly into the carb is...
before you rebuild the pump, I would check the lines to see if fuel is flowing through them, as my Mtd the lines where blocked and I had to buy a rebuilt kit for the carburetor. You can check on eBay or order one off the Hasqvarna site Hope this helps Tim
May 04, 2011 | Garden
Carb. problem replace options ?
Rebuild it yourself with a carb rebuild kit
Buy it rebuilt and just install it
Or buy a new aftermarket holley or edelbrock.
Apr 02, 2010 | 1984 Dodge Ram 50
Briggs & stratton Modal No 490179 carburettor linkage
it sounds like the governer needs to be set and the carb needs to be cleaned out> I would get a carb rebuild kit and go to briggs online and look up how to set the gov dont run it till you do or you may blow the motor
Aug 31, 2009 | Briggs & Stratton Power Products 5,550...
Carb rebuild
Online
http://www.oldbikebarn.com/Street/1997-Suzuki-GSX750-F-Katana
If you need one local,Give me your City,State,Zipcode(Not your address)
Please rate this Fixya
Jan 29, 2009 | 1997 Suzuki GSX 750 F (Katana)
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
