Ghosting on LCD TV
Ghosting on Baird 27" LCD TV (seems to happen mostly with bold colours)
Strong reception
Ghosting even happens when connected to laptop, DVD,
Get a big heavy brick and throw it at the screen this fixed mine
in no time and got a sony instead
Posted on May 29, 2008
TV has suddenly developed blurring and ghosting. Never happened before? Any idea cause or what to do?
This is a digital reception area, yes?
If so, probably a fault with the system board.
Feb 11, 2015 | Samsung Televison & Video
My Baird LCD has ghosting on screen how to fix
if memory serves me correct ghosting is caused by antenna location.try rotating
Jan 10, 2015 | Televison & Video
My Lg colour tv is getting these weird red and blue shadows that makes the picture looks like it's in 3d can I fix this?
thats called ghosting its usually down to your tv ariel try putting your ariel on a mast for a better clear reception.
May 05, 2014 | Televison & Video
Sony bravia 52 kdl xbr ghosting
Michael, does the ghosting go away of you tap the set? Or if you turn off the set and let it cool off and turn it back on, is the ghosting still here? One of the most common causes of ghosting or double image problem is due to a defective LCD panel tab. Sony's are known for this problem. I would recommend getting a diagnoses done on the set to be sure. If it turns out to be a LCD tab problem, the only true fix is to replace the panel.
Nov 24, 2012 | Sony BRAVIA Televison & Video
Colour display not ok
Does this happen on a particular source or on any signal source(cable, composite, hdmi etc). Try checking other signal sources and change cables.
May 21, 2012 | Philips 32PFL3403D/27 32 in. LCD TV
I'm getting trails using an HDMI cord on my Vizio 32" TV. Is thsi because the HDMI is too fast for the max 720p resolution? Should I switch to component cables? I'm also using a Bluray player when it...
This problem is actually called Ghosting.
Ghosting is what happens during high action scenes or during any scenes that have low light.
There's really no way to fix it other than getting a better tv. Vizio isn't really the greatest.
The video processor on the Vizio is unable to keep up with the input and it creates ghosting.
Mar 09, 2011 | Vizio L32 32 in. LCD HDTV
Ghosting of the colour guns
Replace the convergence amp IC's and call a good TV Tech this time. The last tech over charged you about $1000.
Jul 30, 2009 | Sony KP-51HW40 51" Rear Projection...
I have a 42" dynex LCD TV. There is a shadow to the left of all words and during some shows like NBA basketball games. How do I get rid of the shadow?
IM guessing here that this is an Analouge reciever if so the shadow is probably ghosting from your Aerial .
It Happens for two reasons either the Aerial is mounted inside your roof space and the signal although strong enough to get in is not strong enough to carry straight on out so it bounces back onto your Aerial from your roof giving you a second signal a fraction of a second behind the first ..GHOSTING ... if it is outside something is causing the same effect , if it has only just started maybe someone has put something behind it like a new building etc.
This would cause the same problem ..so also could a damaged aerial cable .. however if you have ruled this out has the set had a knock at all as it could be the lcd is damaged again without looking this is a needle in the haystack scenario....Regards Vortash
l
Apr 14, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
My Toshiba LCD to my new Onkyo SR506 receiver - missing colours
The problem has been fixed. Just happen to transpose a couple of cables.
Thanks
Ken
Jan 11, 2009 | Onkyo TX-SR506 Receiver
Televison & Video Logo
285 people viewed this question
Top Televison & Video Experts
