Question about Dell OptiPlex 755 Motherboard System Board Socket 775 DR845
The Battery on my Motherboard fell out while I was inspecting the SATA cables for my HDD and CD-ROM. When I put the Battery back in and rebooted. Set the time in the Bios it looked like it is going to boot, but right after the Windows XP screen shows up, I get the blue screen of death. Same thing happens when I try Safe mode or Safe Mode with Command Prompt. This is a company machine and I need to keep the data intact. It was working fine intil the Motherboard Battery fell out. The HDD and the CD-ROM are both SATA Drives. Suggestions Please? Thanks
  • 493 Answers
Once you replaced the CMOS battery, it is important to configure the BIOS settings.
-Start your PC. (Before the Operating system press F2 or the key to enter your BIOS. (The key may be the Del button)
-Enter the BIOS.
-Modify the Date.
-Verify if the parameters are correct. Check the information on the hardware installed in the computer (such as the number of tracks or sectors on each hard drive) are stored in the CMOS. You must select the HD and save it in the BIOS.
Check the HD type. You may use auto detect function of BIOS.
-Save and quit BIOS.
Waiting your comments.
Posted on May 30, 2010
  • 19 more comments
  • pangze2000 May 30, 2010
    I have already tried that. It is an old BIOS, but it does detect both the Hard Drive and the CD-ROM.
    I ensured that the Time and Date are correct and looked through the rest of the setting and they all look correct.
    I even tried to boot up with a XP professional Disk. The process started fine, but as it continued to load files for the set up, it gave a the BLUE SCREEN right when it says it is starting windows on the bottom right of the screen.
    The bottome line is I cannot lose the info on this drive. I am in the middle of the Bohai Bay in China at the moment, so I do not have easy access to any new hardware etc.
    Thanks
    the Technical info is as follows: 0X0000007B (0XF7C3763C, 0XC0000034, 0X00000000, 0X00000000)
  • Ibrahim OKTAY
    Ibrahim OKTAY May 30, 2010
    In the BIOS, you may change AHCI to "compatibility mode". (Or you can select your HD type.
  • Ibrahim OKTAY
    I wrote my last comment before reading your last comment. I'll write you my other solutions.
    The default under the SATA Operation settings is as follows:
    RAID Autodetect / AHCI
    There are 2 other options:
    RAID Autodetect /ATA or RAID On
    If I choose the second option there is a warning message that states:
    SATA Operation is being Changed!
    Changing this setting may prevent your operating system from booting or require a Reinstall. Are you sure you would like to continue?
    I am worried if I change the SATA Operation I will lose all my data.
    Thanks.
  • Ibrahim OKTAY
    Do you have only one SATA HD or is there any second HD?
    Ok, I changed the RAID setting to Autodetect /ATA and now it boots. Hooray!!.
    Now, the next problem, hahaha.
    The mouse works fine but the keyboard ceases to function after the boot gets to the "Applying computer settings"
    I have tried using a wirelss keyboard and mouse, and a regular USB keyboard and mouse. Each time the same thing happens. I have keyboard control in the very beginning of the computer boot. For example, I can get into the BIOS or Safe Mode.
    if I boot up in Safe mode, the keyboard works. in Both Safe Mode and Safe Mode with networking.
    this machine is on a domain.
    I scanned for viruses using Macafee in Safe mode, found nothing. I also used 2 different malware scanners and also no problem.
    Help me please:)
  • Ibrahim OKTAY
    Leave it as auto detect.
    The message on the blue screen means : STOP 0x0000007B error "INACCESSIBLE BOOT DEVICE"
    Check the boot sequence in the BIOS.
  • Ibrahim OKTAY
    On the BIOS, there is a USB controller option.
    You should set it to On so that USB devices will be detected and supported in the operating system.
    yes, I have done all that.
    here is what I have. I have a wireless keyboard and Mouse. And I have tried this with both a wireless and Wired keyboard.
    When I boot up regularly, the Mouse still works but the keyboard does not work. Pushing ALT+CTRL+DEL Does nothing. Pushing the Caps Lock or Number Lock does nothing. No Lights etc.
    If I turn on the machine, in the beginning I can still get to BIOS by puching F2, and I can push F8 and get to Safe Mode.
    Now, if I go to Safe mode and log in with networking and use my regular Domain username and Password, the keyboard works no problem.
    If I boot to Safe mode without networking and use a local Admin account username and password the keyboard also works no problem.
    What do you think?
  • Ibrahim OKTAY
    First, try the Last Known Good Configuration option by pressing F8 at the boot menu.
    I tried that once, but I tried it again and same result. Still no Keyboard.
  • Ibrahim OKTAY
    Try to update keyboard and mouse driver in the safe mode.
    Go to Control Panel, click the Hardware tab, click Properties, click the Driver tab, click Update Driver...
    (If it doesn't work You may use Recovery Console from the windows installation CD. I can explain what you will do.)
  • Ibrahim OKTAY
    Hi Pangze,
    The other solution is below:
    You can use the registry editor to remove the device filter driver entries and to solve the problem.
    WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system.
    To do that:
    Restart your system in safe mode
    Click start menu
    Then run
    Type the word regedit
    The registry editor window opens
    Here you will see the files as below:
    hkey_classes_root
    hkey_current_user
    hkey_current_machine
    hkey_users
    hkey_current_config
    Press ctrl+F and type the word mountpoints2
    press enter to find
    delete all the folders named as mountpoints2
    click start
    then run
    type the word msconfig
    and hit enter
    the system configuration utility window opens
    in both the tabs named startup & services look out for suspicious files and uncheck them that don't belong to your operating system.
    Click apply then ok
    Restart your computer in normal mode
    Hope this helps.
    Now for some reason when I boot into normal mode or safe mode the mouse still works but the keyboard does not work anymore in Safe mode.
    Before I took a rest, the Machine found a PCI device during boot up (Safe Mode). Another person decided it must be the keyboard so they manually added a keyboard driver to that unknown device. I could not stop them in time.
    I wanted to kill him, hahaha. Now my hands are tied since now the keyboard does not work Even in Safe mode.
    Help me.:)
  • Ibrahim OKTAY
    If your mouse is working in Safe Mode you can un install the keyboard driver and reinstall.
    Also using mouse and copy/paste function, you can run reg edit and do the previous procedures.
  • Ibrahim OKTAY
    To be able to open the regedit commands using mouse, you can save the message as text file and open in the safe mode by notepad.
  • Ibrahim OKTAY
    But, you can try the Last Known Good Configuration option by pressing F8 at the boot menu.
    Well, thanks for trying.
    I ended up making a a BARTPE type disk from scratch to fix all the problems.
    Thanks
  • Ibrahim OKTAY
    Thanks.
    Good luck my friend.
Foxconn N 15235. From cold start cannot find boot device, after ctrl alt del it reboots. CMOS battery replaced. Problem persists. Only 1 HDD Sata and no CD Rom / FDD intalled
make jumper setting to your hdd u will see at the front of the hdd the jumper settings before u"ll do the job unflug the power supply
Jan 20, 2011 | Computers & Internet
Some one give me this DVD burner Sony DRU-540A ..would it use IDE or Sata...It did not come with any cable...what cable i need to get?
If you look on the back of the burner, you will notice either a slot with 39 pins or a small black like plugin. The 39 pins would be for an IDE plug, and the little black pin would be for a sata cable. Simply go to the nearest Radio Shack, Best Buy, or computer hardware store and get the appropriate internal cable. Just advise the store attendant in that area to advise you were such cable is.
These are very simply to plug in, simply plug in to the back of the cd-rom, and plug into the motherboard with a similar plugin on the motherboard. Make sure the plugin on the motherboard states it is Sata, on the motherboard it will have something printed near it with Sata1 Sata2 or something similar. Put the CD-ROM in the closest bay, and plug in appropriately.
Dec 04, 2010 | Sony DRU-540A DVD±RW Burner
I need to know where to connect the sata cables for the cd rom to the mother board
Sata cables on both ends have female connectors. Just find a "L" shaped connector on the back of your cd rom and to the motherboard( usually about the size of a usb connector but narrower a little bit, sometimes color blue or black depending on the brand of your motherboard with a lable on it like "sata 1" or "sata2" ) and connect the cables on each end. Ther's only one connector at the back of the cd rom but on the motherboard, you can choose any sata connector available.
Oct 06, 2010 | Computers & Internet
Not deteck hdd & cdrom
Power down you're system and remove the power cable from the PS.
Open you're case. First clear the cmos jumper. See bottom of page 14 in manual. The GA-8VM533M-RZ motherboard was made Jan-1-2004. It is very likely that the cmos battery needs to be replaced. Average life span is 5 years or less. Pull the cmos battery and check its voltage with a voltmeter, it should read no less than 2.7volts DC.
I'm guessing it’s the bios that’s not seeing the CD-ROM drive and the hdd? Suggest you check both the data cables and their power cables.
Since the GA-8VM533M-RZ motherboard only supports ATA IDE hdd's, check the drives jumper. (It should be jumpered as a Master) and so should the jumper on the back of the cd-rom drive. See the link provided; http://www.easeus.com/resource/install-ide-hard-drive.htm
The link above helps but you're hdd may be different. See the sticker on
you're hdd for the correct jumper setting.
If you are using a single data cable to connect both cd-rom and hdd to the motherboard don't. Use an 80-pin data cable for the hard disk drive. You can use a 40-pin data cable for the cd-rom but if you have a spare
80-pin data cable connect the cd-rom drive to it.
Connect the hdd to IDE1 and connect the cd-rom to IDE2. See motherboard layout in the manual page 5. Need the manual? Download it from Gigabyte; http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1766
To view the manual you will need to download and install Adobe reader;
http://www.adobe.com/products/reader/
Re-connect the power cable to the PS. You can leave the case opened for now. Power on the system and press the Delete key every 2 seconds until the bios menu opens. (Make sure the time and date are set current). See page 19. Than turn to page 23. Make the settings as follows;
First Boot Device [Floppy] - (if one is connected)
Second Boot Device [CD-ROM
Third Boot device [HHD-0]
Password Check [Not needed]
CPU Hyper-Threading [Enabled]
Check all settings while in the bios, save and exit. The system will auto re-boot. If after replacing the bios battery (If needed), and the bios still
does not see either drive than the problem is either the bios or the motherboard's controller. The bios can be flashed but the MB controller can not be repaired.
Cheers'
Mike
Feb 15, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Sata dvd rom cause the computer to crash, is it because its plug in to the wrong plug in on the board or the sata on the motherboard isnt the right one im trying to install a sata rom on a gateway 5474,...
on pata ,flate data cable use in long connerter . on sata cable we use thin and flatcable join in n small squire port. some bord have both type port we can use diffrent port in same time . but port should be good. i think there no chance to join different connecter joining. we look seriously. in any coonater we saw cuttin g shape or male female shape. power cable of smps which join in hdd/cd room may be lose when we join any part it can be short so connecting any cable before we do switch off or pullout powercable.
Nov 05, 2009 | SuperMicro LiteOn SSC-2485K - Disk drive -...
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
Hi when I start the computer, at the beginning i get error messages like, sata drive not found press f1 to continue press f2 to reboot, but i tried both f1 & f2 still windows doesn't start goes back to...
hi...you can try to remove the battery of your motherboard..the battery is located somewhwere in the bottom of the motherboard..it will reset you bios settings to default.
Apr 14, 2009 | Computers & Internet
Is the 2400 Toast ???
Two main reasons why this things happen, first.. there's an error with your hardware. If you know how to diasassemble your pc, then do it. Cleaning your machine will make it work. If it doesn't, repair the operating system with your windows installer cd. Be sure to clean your cd rom or you might as well borrow or buy a new cd rom so that the installation will run smoothly
Dec 05, 2007 | Dell Dimension 2400 PC Desktop
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Dell OptiPlex 755 Motherboard System Board Socket 775  DR845 Logo
114 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
