Question about Xerox DocuColor 12 Printer
How to hook n40 on a network
I want to add this on to a router,
  • 4,924 Answers
Just add it to one of the router's lan ports..and after that access the tcp/ip protocol into the network card ...of the printer ..and choose to get an ip address automatically ..
This will add it into the network ..and all the other devices will be able to send jobs to its IP ..or just find it when you hit search for printer inside default gateway ..
If this do not work ..than you will have to configure the Ip and subnet mask ..and default gateway manually like this ..
the Ip will be the router's Ip +the number of the port ...so if the router is ..192.168.1.1...than the printer in number 3 port will be ..192.168.1.4 and the subnetmask will be :255.255.255.0 and the default gateway will be the router itself..192.168.1.1
the dns servers will either be configured automatically and in this case will take the network's ones from the router ..or insert the ISP dns same as in the router ..
Posted on May 30, 2010
  • Catalin Turcu
    Catalin Turcu May 30, 2010
    I forgot..if it is a wireless one ...just enable the card ..and search for the network ..when it finds it ..insert the admin and user and the password just like in a laptop ..or if it is a free non pasworded network ..just hit connect ..
Looking to hook up wirelees router
You should have one plug that is marked WAN - this connects to your modem with a standard Ethernet cable. If you cannot read the labels, it will be the plug, slightly removed from the other four plugs.
You need to connect the power adapter to a power strip to avoid unnecessary power entering your network and to protect the router.
You should be able to start the router without a PC attached. Just look for Dynex being broadcast wirelessly. Your network is not secure wirelessly until you add a password to the network.
See if you can get to fixya.com from your laptop. If so, things are going pretty well. You now want to add security to the wireless network.
Write back if you need help.
May 24, 2010 | Dynex 4-Port Ethernet Broadband Router...
Tip
How to wirelessly hook up xbox live GOLD
wirelessly hooking up xbox live is an easy, simple process; tech savy or not. first, you will need a wireless networking adapter, which range from 80 to 100$ USD. bestbuy or walmart .com are examples of retailers of such product.
hook up the the adpater into the back of the xbox 360.
if you do not have a wireless router that is currently serving no purpose, you will need.
bestbuy and walmart are once again ideal retailers, and i would suggest a Linksys brand router, hook that up and configure to your router.
no more purchases, except for a xbox membership of course.
turn on the xbox with the Wireless networking adapter plugged in and tap the center "Big X" button, scroll right twice and find "network setting" from there, configure network, and then scan for networks...
if you were successful in hooking up the router, you will find your router as an option to connect to, you may or may not have a specified sercurity.
if you do, you will be required to enter the password you chose.
you should now be connected to xbox live...
want a friend? add gamertag: "xInsanitea" and we can play sometime... thanks for reading!
on Apr 30, 2010 | Microsoft Wireless Network Adapter Xbox...
Set up difficulties
You sure can. Start w/ the Comcast modem as long as it is NOT a USB type and hooks using a CAT-5 cable (regular network cable). Hook the comcast modem to the WAN port of the wireless router. On the back of the wireless router use the normal 1-4 extra LAN ports to hook other computers or the SD208 switch to it and other computers from there.
Word of advise if using Wireless Router, be sure to read manual and set a KEY for your network to secure it from unwanted outside use.
Apr 03, 2010 | Linksys SD208 8-Port Ethernet Switch...
I am using my install disc and got as far as USB connection, which I did and now my continue window is grayed out. Trying to add my Lexmark 5600-6600 to my wireless network.
You're trying to do what?
Are you using a router that is also a print server?
Are you using a USB print server?
Printers don't hook up to routers unless it's a network connection with an ethernet cable.
Print servers hook up to printers with a USB cable, but are attached to the network with an ethernet cable in most cases.
Dec 22, 2009 | Computers & Internet
So i have my desktop set up online, but i want to get my laptop hooked up as well and i have a router. how do i hook that up to?
On the right bottom corner of your screen, you should see a message/icon about wireless networks.
Select the icon and you should see a list of wireless networks. Select your network, add your password (if you set up a password) and you should be connected.
Open your browser.
Hope this helps.
Sep 08, 2009 | NetGear WGR614 Wireless Router
Changing the language display on xerox n40 printer
IF YOU CANNOT READ RUSSIAN, THEN MAY I SUGGEST ADD AND REMOVE, DELETE SOFTWARE FOR THIS PRINTER AND THEN REINSTALLING THE SOFTWARE, IT SHOULD THEN ASK YOU WHAT LANGUAGE YOU REQUIRE.
Jun 16, 2009 | Xerox DocuPrint N40 Laser Printer
Second computer cant connet through the router..
You must reconfigure the wireless settings on the wireless computer. Go to Network and Sharing Center > Manage Wireless Networks. Now you must delete all the prefered wireless network profile there. If they are all deleted, click on ADD > Click Add A Network in range of this computer > Select the signal from your router and connect. If it asks you for a network key, you should know that, otherwise, contact your router provider to determine what your network key is. That should solve it.
May 06, 2009 | Computers & Internet
Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Jan 19, 2009 | NetGear WGR614 Wireless Router
Hooking a Linksys wireless router and SpeedStream router together
Connection should be from LAN port of Speedstream going to Internet port of Linksys router. That should be it.
Oct 25, 2008 | Computers & Internet
Hooking up 2nd laptop
Have the laptop look for the network in Wireless Settings. Look for the SSID of the network you have in your home. Make sure you have obtain the IP' s automatically. and you should be good to go.
Mar 22, 2008 | Linksys Wireless-G Broadband Router
Xerox DocuColor 12 Printer Logo
64 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
