Question about Countryman E6 Ear Professional Microphone
Countryman mic getting a noise like a white noise generator sounds but it comes and goes. What can I do about it?
Serious crackle or noise is a different problem, but a lesser, rustling crackle is very common with these mics. If you aren't looping the cable close to the mic, you will run into issues.
What you have to do, is put a small, 1/2' loop in the cable, making sure that the looped part of the cable is touching the initial part of the cable. Affix them so they stay that way throughout your performance/production. The closer you get the loop to the mic, the better.
As a test, take the mic, hook it up to equipment and listen on headphones. Start handling the mic, mainly by rubbing the cable, or rub the cable with various fabrics, listening for the rustle. Then put the loop in it and do the same thing. It is amazing how much more quiet it becomes. Try it with the loop half way down the cable and handle the cable above and below the loop. you can hear the rustling above the loop, but not below.
This model HAS to have that loop for quiet audio.
Posted on Aug 02, 2012
Where can I get a E6 mic repaired in Johannesburg
Try contacting Countryman. They should be able to assist you.
Oct 18, 2011 | Countryman ISOMAX E6i (E6IOW5BC2)...
We use a Countryman E5 for our Pastor. We are getting a ocasional crackling sound. I have checked all of the connections and we always start with fresh batteries.
It is common to get a crackling sound from the mic brushing against hairs or fibers on a shirt. Make sure the mic is taped to the face to avoid rubbing against anything.
Feb 07, 2011 | Countryman Audio Players & Recorders
Get a lot of poping and feed back
Hi, in other not to get feed back, make sure that the monitor speakers are a way from the mic.
Also it depends on the processors your using,Feed Back destroyer, compressor,etc.
That will determine the cause of the feed back.
Notemake sure the positioning ofthe speaker doesn't come to close in contact with themic,cause themic is so sensitive too peak any slight sound around.
Please you can pass your comment and tell me what you have in your setup.
Hope that helps..
Nov 03, 2010 | Countryman E6i EARSET f/SONY...
Hi We use a Samson UT-5 at my church. Recently it seems like there is static/buzzing noise whenever our priest touches the connector. Is there a connector problem or should we take it to a repair store...
That sounds like a floating ground problem.
The UT-5 is a beltpack transmitter, right? What microphone do you have plugged in to it? We use a Countryman headset with a Sony beltpack, and there are components inside the connector for our setup.
Try unplugging the microphone and see if you can make the beltpack buzz without a microphone. If so, then it's in the beltpack. If not, it might be the mic cable.
Apr 03, 2010 | Countryman E6i EARSET f/SAMSON UT5/TX3...
Is there way to tell if the e6 mic is having
You likely broke one of the 4 wires between the circuit board in the pack and the connector for the mic when you replaced the antenna lead. These leads are hard to work on and the solder can pull away. They can appear to be connected and not quite touching... a gentle tug to test each one!!!
Feb 09, 2010 | Countryman ISOMAX E6i (E6IOW5BC2)...
Countyman E6 "crackels".
Replacement caps are available from countryman directly. The noise is usually indicative of a cable problem. Check the wires where they enter the capsude and at the connector end as well. I believe that countryman has a "refurb" rpogram where they will replace the cable for a nominal fee (much less than a replacement). Caution should be used when storing the mics such that the cables don't get tangled or crimped.
Dan
Jan 12, 2010 | Countryman E6 Ear Professional Microphone
The countryman E6 mic caused a loud bang during use.
It appears that the "bang" was the result of a static discharge from the mic boom. I trust it doesn't happen again.
Nov 04, 2009 | Countryman E6 Ear Professional Microphone
I have no sound from my E6
Check the headset closely around the mic capsule and ear attachment for placing the mic on your ear. This is prone to problems from bending the mic to fit different people. You may find a break in the metal under clear rubber material. Also the cable itself could have a problem. Countryman sells the cable and it unplugs rather easily. There is a junction in the cable that is actually a plug. You can pull it apart there. Be careful as the mic is very expensive. Also countryman provides excellent technical support. Good luck.
Drobertson
Dec 28, 2008 | Countryman ISOMAX E6i (E6IOW5BC2)...
A little more info on our poblem
The problem may be resolved by placing a 330 PF capacitor across the mic's two input lines. With countryman you cannot access the mic capsule easliy so it is best to take the TA5F connector apart,( this would be the connector that plugs into the beltpack) and place the capacitor across the two lines. LECTROSONICS.COM has the capacitors and a wiring diagram to help solve this. The part number for the capacitor is SCC330P
Good Luck!
Dale Robertson
Mar 31, 2008 | Countryman ISOMAX E6i (E6IOW5BC2)...
Popping over the house speakers.
Has it always done this or recently started?
Try to determine if the popping is coming from the words spoken into it, or if you get popping from simply moving the mic and cable around. if you get popping from simple movement, there is a chance that the mic needs to be replaced. We use these in our church, and over the last 6 years I've had to replace about 6 of them...sometimes they go bad in the wire, sometimes inside of the mic. The wires are so thin, excessive use wears them out sometimes. Depending on the model countryman that you are using...I've seen them become disconnected where the mic. meets the wire...some can disconnect here beneath a rubber coupling...if you have this model, make sure that it is properly seated.
If there are no shorts in the mic or cable, and you only hear the popping while speaking into it, you may need to filter out the low end on this channel only (everything below about 120hz - 180hz)...and try using a wind shield to help control this.
Hard to troubleshoot without being there, but I hope this gives you a few good ideas.
Mar 30, 2008 | Countryman ISOMAX E6i (E6IOW5BC2)...
205 people viewed this question
Top Countryman Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Countryman Audio Player and Recorder Expert? Answer questions, earn points and help others
