My RCA TV will not come on. When I click the button to turn on it makes this clicking noise and then stop. What can I do? It is a 36 inch Home Theatre Twin Tuner Pip.
  • Gloria J. Gillyard May 30, 2010
    I have a 36 inch Home Theatre Twin Tuner Pip.
    the model number is F36685. When I push the button to turn my TV on it makes a clicking noise as if it is coming on then it goes right of.
    Guru:
  • 374 Answers
It sounds like you need to replace the power supply. If you feel confident enough it can be done yourself. It can be a little bit expensive to pay someone. When you leave it off for a long while does the picture ever try to turn itself on at all??
Posted on May 30, 2010
  • 5,807 Answers
Hi
twins,
Please note that if your TV denies to work ,
it can be a result of working power supply!
Power supply (SMPS in technical term) has 2 main functions :
1- Producing the needed voltages and supplying them to different stages.
2- Protection and monitoring for unwanted situations like short circuit ,
over/under voltage , over current , thermal problems and ...
In all of the above situations , SMPS cuts all or some of its outputs
for preventing further damages.
You can recognize this using some symptoms like click sounds ,
flashing standby LED , number of clicks and flashes
and some simple tests.
Thanks in advance for choosing Fixya for assistance please
include Model & chassis number and the year should you need to
have more possible solution for your problem.
Regards,
palaboy
  • 4 more comments
    M y RCA TV is a 36 inch home theatre twin tuner pip. The model number isF36685.
  • Rommel Cana
    Rommel Cana May 30, 2010
    Most often it is caused by the
    Flyback transformer or a bad component along with it.
  • Rommel Cana
    you may need to open the back of the TV and check on it.
    Procedures
  • Rommel Cana
    Additional info
    How to Use a Multimeter
    info on flyback:
    http://en.wikipedia.org/wiki/Flyback_tra...
    For visuals check for a possible bulge capacitor on the power supply or a possible bad CRT socket.
    Remove the CRT socket from the CRT pins, and might try powering it up ( don't let these board
    touch anything metallic or have an electrical contact with other components )
    if it does power up, you just found the cause.
    But if it doesn't
    might as well check the Horizontal Output transistor ( mounted on a
    heatsink )
    Could be bad.( Recheck everything on the first link above.....
    Flyback
    Make it sure that the unit is unplugged even for at least 10 minutes.
  • Rommel Cana
    and these is what a CRT socket looks like:
    Of course it is still connected on the CRT Socket Circuit Board.
  • Rommel Cana
    Rommel Cana Jun 08, 2010
    Check on Horizontal output Transistor,
    Remove it if it is shorted to fully confirmed.
    Once it is removed , you can then measure the B+ voltage on the deflection Board.
    You will then know, that your power supply is OK.
    One reason it is not powering ON is a partially shorted
    Flyback
    transformer.
Our TV will not turn on and makes a clicking noise
You have a bad retrace capacitor. RCAs are known for this. They are extremely high voltage at minimal MFs. Take this TV to tech please!
Dec 21, 2009 | RCA G36705 36" TV
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Rca 36 inch model f357731m13
power supply is bad -- probably need a new or refurbished power board --- check fuses on board first --- you can buy them online at partstore.com -- easy to install yourself
Feb 27, 2009 | RCA Televison & Video
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
36 inch RCA 36v430t
Mike-It looks like the power supply is going on your tv-it can be replaced. This happens, usually, when little kids are playing wth the remote or power button on the tv. Turn it off and on a whole bunch of times in a row, kids love to do that, and it burns out the power supply part- to make a CRT tv like your RCA36 incher- which is a beautiful machine- I have the RCA/PROSCAN 36 incher-LAST longer...You should always wait 5 min between turning it off and on. Don't ever sell it. This one is worth fixing. It has better color and sound Than the new plasmas and lcds-The Pros know this. Be carefull, they might try and talk you out of it-so they can fix it and have it for themselves. So what if it's not High Deff. It's a great set.
Jul 02, 2008 | RCA F36650 36" TV
LG 47" LCD TV - 47LC7DF Clicking Noise
I was told that these clicking noises (which happen on my Magnavox LCD too) were due to the "power required" at the internal switch. Seems that the power required to immediately turn on the TV is too much for a standalone household outlet, so it "surges" power in a series to get enough there. Hence, the clicking sounds are actually mini power surges to send more power to the internal circuits to turn the TV on.
If your set is like mine, these noises generally stop after a minute or two, correct?
Dec 13, 2007 | LG 47LC7DF 47 in. LCD HDTV
Tv does not turn on.
There is probably a short or a near short loading the power supply circuit, a leaky capacitor, shorting diode, transistor,IC,LOPT etc. Have the set checked by a technician near you.
It is still worth repairing!
imikendumuimui@yahoo.co.uk
Dec 06, 2007 | Televison & Video
TV WON'T COME ON
All the reports are showing the same problem the TV is in shutdown mode.
Something is wrong and it is refusing to start it makes a chirping or clicking sound. Solution is that it needs to be repaired nothing you can do unless you want to try replacing the motherboard yourself.
Dec 05, 2007 | RCA 24V511T 24" TV
F36650
Three clicks only==bad xformer==#2078 Asti. RCA original sometimes hard to get.#257805. NOTE:There is no lamp to change in your set.
Sep 25, 2007 | RCA F36650 36" TV
TV will not turn on when power button is pushed.
check the main fuse in the tv. test it with a multimeter, not visually. if its the thermistor that blew the fuse, it is very difficult to see the break in the wire. replace if blown. if unit blown fuse again withing a couple of weeks replace the thermistor in the degausing circuit. good luck.
Jan 09, 2007 | RCA F36665 36" TV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
