Question about GE GSH22KGR Side by Side Refrigerator
Coils freezing upevery 2 weeks or 3. goes upt to 48 in fridge ans 20 or so in freezer. runs great after i defrost it
  • GE Master
  • 1,606 Answers
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Posted on May 30, 2010
  • 166 Answers
Remove the back panel of the freezer and defrost the coils. once you have done this inspect the defrost heater(s) located in the coils. if you know how to use an ohm meter you should check the heater for continuity. this heater is a glass tube with a coiled wire inside it. you may be able to gently pull the heater apart if it is bad. if it is good you will feel tension in the coil. a lot of these refrigerators were made with just one heater and the replacement will be a 2 heater pack. this is the most common problem for this refrigerator not to defrost.
other causes could be the defrost termination thermostat located above the coils or the main board.
MAYTAG MSD2734GE side-by-side fridge/freezer. The freezer coils on a regular basis (3-6 weeks intervals) will freeze. We will have to remove the coil covers and manually defrost them before it will...
I have written tips pertaining to each of those 2 issues
Drian blocked tip...http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
Evap. coil freezing up tip...http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
i have 2 pictures in the coil freezing up tip and they always for some reason post incorrectly so here they are..oldtech2332_43.jpgoldtech2332_44.jpg
Aug 22, 2011 | Maytag MSD2734GE Side by Side Refrigerator
The freezer gets really cold but the vent that runs from the freezer to the fridge freezes up and the coils also. when i clean the coils and the freezer vent it works great for 2 weeks then it starts to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | Maytag MSD2656G Side by Side Refrigerator
I have an electrolux inspire fridge/freezer and found that the temperature has risen to 20 celsius after one week of none use. however the freezer is still working as normal Please help
We have same problem which has happened twice now
The engineer told us to defrost for at least 48 hrs the air vent from freezer to fridge freezes
He didnt know why this happens though
Aug 03, 2010 | Refrigerators
The self defrosing fridge freezer is freezing and leaking inside of fridge, 3 weeks ago I melted ice in freezer and drain with hair dryer, worked for 3 weeks, now freezes agin?
You have a problem with the defrost system. There 3 components... heater, thermostat, and timer or adaptive defrost control depending how old your refrig is. Check heater and thermostat( located on the evapotator coils) with an ohm meter. The heater will have some resistance and the thermostat will be closed(must be cold). If these check good replace timer or adaptive control.
Mar 24, 2010 | Refrigerators
Freezer works great, fridge not cold. about 60 degrees in fridge. had repair man look at the fridge, said the mother board, was bad. panel inside freezer iced uped. fridge seem to get better for about 2...
And you are posting because,.......????? You are looking for a second opinion? Don't like the repair estimate?
1. Your freezer is not working great. If it is frosting up, frozen packages will soon beging to soften also.
2. All of the cooling takes place in the freezer compartment. A fan blows air over the coils in the freezer, and directs some of it into the fresh foods side to cool it. When the coils become blocked with frost, the air can no longer flow into the fresh foods compartment. Result is warming of FF area. You may also see freezing in the bottom FF bin, water dispenser not working, FRZ section warm, etc.
3. Manually defrosting the coils will temporarilly solve your problem, but it will reappear in a few days to a week or so. (depending on door openings, ambient temp, etc)
4. The motherboard controls the defrost interval and (although not the most common) certainly can be a cause of defrost failure. If a qualified servicer diagnosed it as such, it most likely is just that.
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
your defrost timer is bad. this device is dual purpose, it is a small heater/solenoid that calls for the compressor to turn off so the lines can defrost (usually does it once every 48 hours or so). it looks like a round button clipped to the coil lines in the freezer behind the plastic paneling where the cold air comes out. you need to replace that part, which is actually very inexpensive compared to a new fridge. it will unclip from the coil line and the two or three wires will either disconnect or you may have to cut them and splice on the new ones from the new defrost timer. either way it is a job that will take anyone with basic hand tools less than an hour to do.
May 29, 2009 | GE GSH22SGRSS Side by Side Refrigerator
Motor runs, freezer defrosting and fridge won't cool
If you have frozen coil at the back of the freezer section, then the defrost thermostat is usually failing. Allow the fridge to defrost completely overnight. If the fridge restarts cooling immediately after defrost, then the problem was the defrost system. In that case the fridge will stop cooling again in a couple of days, as soon as the evaporator coils restart freezing and the condenser goes under stress with the whole cooling system loosing efficiency.
Nov 25, 2008 | Jenn-Air JCD2389G Side by Side...
Freezer is freezing up, then freezer and fridge warm up.
hi thanks for your question. you have a no defrost problem. the cheapest part to replace is the defrost termination switch. located in the freezer., its clamped to one of the coils by the fan motor replace this part. see what happens thanks the appliance doc
Oct 30, 2008 | Kenmore 50522 / 50524 Side by Side...
Maytag side by side model GS24C8C3EV Refrigerator too warm
it is almost certainly a defrost problem. when fault has occured, remove freezer bzck panel and see if there is ice build-up. if so this confirms a defrost problem - possibly that the element is open circuit
Jun 21, 2007 | Maytag MSD2434GE Side by Side Refrigerator
GE GSH22KGR Side by Side Refrigerator Logo
185 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
