Question about FIC AM 35 Motherboard
Computor won't start computor tech said motherboard burnt
  • A Miller May 30, 2010
    Believe him or her ...
  • 38 Answers
If a computer tech has looked at your computer and the motherboard is dead then your only option is to replace the motherboard.
Posted on May 30, 2010
2008 VW POLO CLSSIC 1.4 ENGIN LIGHT DOENST APPEAR AND THE CAR WON,T START CAN U PLEASE HELP ME BEAUSE I UNPLUG THE COMPUTOR BOX FOR HOUR SO WHEN I PLUG IT THE CAR WON;T START
You have no communication with your ECM, it could be the ECM itself or a Can-bus wiring problem. You will have to check continuity on your CAN wiring from the ECM to the gateway, you will need wiring diagram. Should be able to find those on the internet or some parts stores offer them free
Feb 11, 2014 | 2000 Volkswagen Beetle
Have no spark battiery burnt hole in hood bought new computor still wont start
The Engine and Automatic Transmission (not applicable to manual transmissions) in this vehicles drive train are fully electronically controlled by a computer called the PCM and TCM (Power Train Control Module, Transmission Control Module). When a problem like this or other drive-ability related problems occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM. Also always check fuel pressure for correct spec for your make and engine type.
Oct 02, 2012 | 2001 Mitsubishi Montero Sport 4WD
GE side by side fridge HSS25IFMDWW burnt pin on relay on main board and compressor not running. Tested compressor and it runs okay. What would cause the burnt pin?
Most times the motherboard is the problem that causes the solder to melt from a defective relay. You will need to inspect the compressor start relay and capacitor to insure that they did not cause the relay on the board to overheat. Also check that you have 12 volts dc going to the evaporator and condenser fans while running because if for some reason the fans are defective and you change the motherboard while one of the fan motors are defective your new motherboard again can be damaged. Here is a link to a=> Artica/Profile Service Manual
Here is a motherboard test photo=> Artica Profile Tech Sheet I will be glad to help answer any questions you may have Thanks Sea Breeze
Aug 28, 2012 | GE Refrigerators
My PC power supply crashed, burnt resistors, Powerman IW-P250A3-1 20 pin plug to motherboard, bought new power source, but the old power source had a white cable to the 20 pin plug which was -5vdc 0.3amp....
For your system to boot up properly, you need an identical power supply for your system. Most likely the reason why your system won't boot up right now is because you purchased a different power supply and it is lacking something(which is the other pin).
Regards
Sep 14, 2011 | Computers & Internet
The computor boots to bios window then freezes i try hiting delete to enter setup but comp is froze
go to the start menu and find iexplorer and right click and select "create desktop shortcut". If you cant find it in the start menu, the open the search menu and search "explorer", find the file with the extension .exe and set that one to the desktop. If you want to get rid of the shortcut arrow on the icon then right click the icon and go to properties, then you can change the icon to anything you want from there!!!! GOOD LUCK and Please Rate This Post!!!!!
Oct 06, 2009 | Biostar NF61VM2 Motherboard
Monitor wont stay on when you start computor,its goes green for 5 seconds then straight back to standby,monitor works fine on my other computor.
Its totally ur internal CPU problem.
checkout ur motherboard, microprocessor & fan also from wellknown person.
Dont do anything at home.
Aug 06, 2009 | MSI K8MM-V Motherboard
Board dead
Depending what type of phone service you currently have. You can call Asus tech directly. M-F, 9:00AM to 5:00PM. EST
At: 1-812-282-2787. It will take about 2 minutes to get connected with a tech (The people who do repairs on MB's). Give them the location of the capacitor & motherboard model number.
Good Luck!
Mike
Jun 12, 2008 | ASUS K8V-MX Motherboard
Pc restart problem
Yes, your mobo Asus P5LD2-VM support CPUs with Conroe-core ("Core 2 Duo"). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5LD2-VM But for new CPUs strongly recommended use last BIOS version - 1401 from 2007/08/14. http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5LD2-VM/P5LD2-VM-1401.rar
Oct 03, 2007 | ASUS P5LD2-VM Motherboard
Foxconn moterboard
Does the system not even start up the power supply? That most likely means you've wired up your power button incorrectly. Also it could be possible that you're grounding the motherboard to the case. Make sure it is screwed onto the case correctly.
Aug 06, 2007 | Foxconn 845GV4MR-ES Motherboard
FIC AM 35 Motherboard Logo
74 people viewed this question
Top FIC Computers & Internet Experts
David
David
Jax Planet
Jax Planet
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
