Question about Jwin JBTH500 Headset & Car Kit with Bluetooth Wireless Technology Wireless Headset
I lost the manual for jbth500 Iand I need to know the code to pair my new phone with it but I thought the code was 0000
I have lost my Bluetooth manual and have switched phones. How do I reprogram it to the new phone?
Hi,very easy.It's just the same way you paired the blue tooth with the phone.Dothe same with the new phone are you are done.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Have a nice day.
Sep 01, 2010 | Cell Phones
Bt 70r instruction manuel needed need manual or details how to pair bluetooth in car device
BT70R pairing with a new phone
The code for pairing with a new device is 0000.
However, the BT70R retains the identity of the phone that is is paired with and this old code must be removed before a new phone can be paired. There is probably something in the manual for this, but I have lost my copy. Here's how I got round the problem...
Place the BT70R in a sealed plastic bag (to protect it from moisture) and then put it into your freezer and leave for 24 hours. When you take the BT70R out it should have lost its memory of your old phone and you can pair it with the new one.
It worked for me!
Oct 21, 2009 | Car Audio & Video
Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Jun 29, 2009 | Jabra Bluetooth Headset with Adjustable...
BT pairing code
For Cellular Innovations Mini Blue HFBLU-AX1C.
To Pair with Your Phone....
1. Turn OFF Bluetooth Headset
2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode)
3. Search bluetooth device through your mobile phone.
4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
Jan 15, 2008 | Cellular Innovations HFBLU-AX1 Bluetooth...
Passcode for Motorola HS815
Hi, the password is 0000:)
love. Henrik
Dec 05, 2007 | Motorola Mobility HS815 Wireless Headset
Accept code for a bluetooth headset
If this solution doesn't work hold down both the volume up and down buttons on the head set for about 5 seconds whilst searching for a new paired device with your phone then when asked enter the code 0000 and connect
Sep 17, 2007 | Nokia 6300 Cellular Phone
Jwin JBTH500 Headset & Car Kit with Bluetooth Wireless Technology Wireless Headset Logo
60 people viewed this question
Top Jwin Radio Communications Experts
eradiostore
eradiostore
Are you a Jwin Radio Communication Expert? Answer questions, earn points and help others
