Question about RCA 32F531T 32" TV
Tv dont come on but have a clicking noise, the led blinks with a click
I have a Samsung 32" that did the same thing a few weeks ago and I am still trying to fix it. The problem is the Main Flyback Transformer is blow with an open circuit in the Primary Winding that means you'll get no Picture. I also found the Power Transistor that feeds this Flyback Transformer was also shorted between terminals Collector Base Emitter(CBE). I bought a replacement Flyback but didn't work so now I need to get the Original part & it's not easy to find. Always use Original Components NOT replacements. Simply put if you're not technical I suggest take the TV to your nearest repair agent but be prepaired to pay for it. Cost of Flyback around US$50 & $10 for Transistor & if you find an honest repairman it should cost around $150 to repair otherwise it's not worth it. Good luck
Posted on May 30, 2010
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Posted on Jun 21, 2009
Green light blinking on logic board
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 26, 2016 | Dell Televison & Video
Samsung fault finding
hello can I have the model number of the tv also is it a led, lcd tv set thank you. does the on and off light blink when it turns off if so how many blinks. One last thing give me a little more details on the clicking noise when it turns off.
Aug 19, 2014 | Samsung Televison & Video
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Won"t come on. Main fuse and all fuzible resistors (4A)check good.
Please described the problem in detail like what is the status of the LEDs at the front panel. Does it stay on? Does the tv make a clicking noise before the LED starts blinking red or does it blink continously. Also let me know how many times it blinks in between each pause? Please provide the make and model # of the the tv as well.
Sai.
Mar 21, 2010 | Televison & Video
My 27" wega was making a crackling noise when I turned it on. Last time I turned it on it made a pop and went to standby, it blinks three times, pauses then blinks again clicks and blinks four times.
pls. check your tv mains plugh is luss canaction
if not then
probulum is in side tv set so pls. dont.use tv again and cont.nearest tv tech.and solve this problum. becous cracking noise is dengered for your tv.set
* you dont. open tv back cover it your self.becous in side tv set very high voltage.
Nov 10, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
PC will not power up
Check that the ram memory hasn't come unseated from the mobo. If you are using an above board video card also check that it is properly seated as well.
The clicking noise from the PSU is kinda perplexing though...
Mar 01, 2009 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
Sharp aquos
you can try resetting the tv by
1. unplugging it
2. pressing channel down and volume up buttons at the same time while plugging tv back in
3. if you here a click, the tv has been reset
May 12, 2008 | Sharp LC-46D64U 46 in. LCD HDTV
RCA 32F531T 32" TV Logo
280 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
