Question about Pioneer VSX-D606S Receiver
I forgot how to turn on the sub on my VSX D606S
  • 86 Answers
There may be a switch to turn or a botton.
Posted on May 30, 2010
How many fuses are on my pioneer reciver vsx-d606s?
1 for the power supply and 1 for left and 1 for right channel, but every stage inside has also fuse-resistors resistors with a extra function to protect some components that are resistors the are mounted higher or different on the print .
Nov 04, 2015 | Pioneer Audio Players & Recorders
Adjust speakers without remote
usually you can cycle though the settings on the front of your amp, using the jog dial. If not possible contact company for replacement remote. But I can do everything on the front of my receiver. By the number of buttond on this model you should be able to.
Dec 09, 2012 | Pioneer VSX-D606S Receiver
Pioneer 606 overload
Check the speaker wires on the back for shorts, no issues! suspect audio output problem in the pioneer, serviceman recommended.
Jul 01, 2012 | Pioneer VSX-D606S Receiver
My VSX-D606S had got hot so I tund it off and now it's not tuning on
Too late.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 18, 2011 | Pioneer VSX-D606S Receiver
PIONEER VSX-D606S WHEN POWERED STAYS IN STANDBY MODE- LIGHT IS ON, A CLICK IS HEARD BUT THAT IS ALL
Your unit staying in standby mode is an indication that its having a power problem. Remove its plug from the wall and fix it back into the wall, then turn it on again. If its still stuck in safe mode, then the power supply board in the unit is the cause of the problem.
The power supply board might be defective and maybe that's why the unit won't power up. Its receiving power but it cannot transfer the current to the necessary part of the unit because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the unit might not come on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.....
Apr 17, 2011 | Pioneer VSX-D606S Receiver
Dear expert I am the Israeli distributor for Paradigm, MartinLogan, Anthem and more. I have a customer who has the Pioneer VSX-D606S that the subout is not working. He does not have the manual and even...
I can't find a free manual to quote.
There are three parts to this scenario and only one named.
First, you need to set the receiver up with speaker definitions and capacities, subwoofer presence, bass management and Test Tones to verify it CAN make each speaker work.
The DVD player has a piece of this, too. It probably has a menu for speaker configuration that needs to be set up. And its digital output prbably has a setting like DTS/Dolby Digital/PCM. Look in the manual. Look in the manual.
Then there's the sub itself. Is IT working? Jack it into any other pre-out as a test.
Mar 23, 2011 | Pioneer VSX-D606S Receiver
Lost remote controller of Pioneer VSX-D506S
You can buy Original Pioneer Remote from HERE for VSX-D506S
Feb 10, 2009 | Pioneer VSX-D506S Receiver
User manual....
go to google and type the model number, you will find it but you have to pay about $20.00
Oct 28, 2008 | Pioneer VSX-D606S Receiver
Pioneer VSX-D606S subwoofer set up
is the square button also labled as down arrow button, push the down arrow button and will give access to the lcd screen setup options on the receiver center speaker size lfe att settings cross over rear channel size ect. i don't have the manual either took me a year to fix the issue.
Jan 24, 2007 | Pioneer VSX-D606S Receiver
Pioneer VSX-D606S Receiver Logo
229 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
