Question about Hayward SAND FILTER, PRO SERIES
I have water leaking from under my hayward pool filter...any suggestions?
  • 640 Answers
Try consulting the the owners manual for these pool filters. They have a pretty good trouble shooting guide and it should be able to help you correct your problem.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Posted on Aug 31, 2010
Just had the spider gasket replaced and now water is "gushing" out the handle
Hi Shari,
I see two possibilities. 1. The diverter shaft o-rings are not sized correctly (or missing). 2. When valve handle was reinstalled it was not oriented properly with the diverter position in valve body.
Hope this helps you.
Jun 14, 2014 | Hayward SAND FILTER, PRO SERIES
Hayward 220T pool filter is leaking water; could it be the multi-port valve needs to be replaced?
if coming out of top where handle is yes if out backwash line yes make sure unions are tight also
Dec 30, 2013 | Hayward SAND FILTER, PRO SERIES
We have a Hayward pool filter that makes noise but won'tcirculate water.
It sounds like your pool filter is not getting proper suction. This could be cause by several things. The simplest suggestion is to check your pump and filter basket for debris that could be clogging water flow. There could also be restrictions in the intake or discharge lines. The next step would be to check for an air leak in the lines or cracks in the the pump. You could also try to backwash your filter to see if that helps and make sure that your pump is primed.
Jul 24, 2011 | Hayward SAND FILTER, PRO SERIES
I just had a new Hayward s244s sand filter put in and now am having problems draining water from my pool. For some reason I can't get it to drain past the skimmer level. Suggestions?
What are you using to drain the pool? A sand pool filter is not the best option for draining. You need a submersible pump for that. Why are you draining the pool? The filter should be used to filter water, not drain. It is possible, but not efficient.
May 21, 2011 | Hayward SAND FILTER, PRO SERIES
Water leaking out the top
Here is a copy of the users manual for these pool filters. It has detailed illustrations about how the filter should be put together.
http://www.backyardcitypools.com/images/hayward/perflex-system-manual.pdf
Jun 21, 2010 | Hayward EC-40 DE Pool Filter with pump
Sand in my waste water
O-rings or gasket are replaced to stop leaks, so that wouldn't have helped you.
It could be one of two things; either the white PCV-like pipe in the filter tank is cracked OR some of the laterals at the very bottom of the tank, under the sand, has melted. A whole new underdrain assembly is usually $70.
Aug 31, 2009 | Hayward Pro Series 31 Inch In Ground Pool...
Hayward filter problem
YOUR HANDLE IS NOT SEATING IN THE RIGHT POSITION THERE IS A SPROCKET UNDER HANDLE THAT MAY BE DAMAGED TRYSETTING HANDLE TO DIFFERENT POSITIONS SEVERAL TIMES IT MAY HAVE DEBRIS UNDER IT MAKE SURE PUMP IS OFF.TAKE HANDLE ASSEMBLY OFF AND CHECK SPOCKET
Aug 04, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward pump wont prime. air bubbles coming back into pol with water and de
You have a leak, if DE is getting back in pool your filter is either dirty and needs to be taken apart and throughly cleaned, or you have a ripe in one of the DE cells. The pump not priming is a leak somewhere before where water enters pump. Could be a bad o-ring in a valve. Hard to tell what is is without troubleshooting, piece by piece. I would start with cleaning Filter first.
Jun 17, 2009 | Hayward EC-40 DE Pool Filter with pump
Hayward sand filter needs primed every time
The problem is a malfunctioning check valve. It'll be somewhere in the line on the pump output side. If it's not a separate fitting it'll be in the line, probably in an elbow.
Need further info, let me know...
Charlie
May 29, 2009 | Hayward SAND FILTER, PRO SERIES
Haywards pool filter,model 244t
hi mike, unfoutunatley repairs of this nature are not very good, a replacement is the best course of action
Jan 22, 2009 | Hayward Pool Products Hayward Xstream...
Hayward SAND FILTER, PRO SERIES Logo
157 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
