Question about Car Audio & Video
My power acoustik amp is making a funny noise when the bass hit it a a2400db
  • 185 Answers
Well that tells me that some thing came lose in the amp thats all i can say hope u have a warnety
Posted on Apr 09, 2008
SOURCE:
The amp will light up power on but when i was setting the gain and bass boost it wasnt putting out any bass i could touch my sub and barly feal a vibration
assuming that the input is not the problem did you check to make sure that the polarity of the speakers is wired correctly?
Jan 16, 2011 | Power Acoustik Area 820x2 Car Audio...
Remote bass control
there might be a hidden switch on the amp for with or with out bass control
Apr 25, 2010 | Power Acoustik GOTHIC OV2-1800 Car Amp
Makes head lights dim wen bass hits.
You need to install someting called a power cap. the amp needs so much power to produce the big bass thump that the alternator cant keep up. Use a powercap and its like a power reserve.
Jan 13, 2010 | Power Acoustik Car Audio & Video
I have a few problems. i have 2 amps and 4 subs. first problem is when i connect one amp to my speakers it just hisses and crackles. this never happened before. when i turn up the gain to try and get...
The first amp, sounds like there is straight power going through the gain instead of it being limited. The second amp...hook the other subs up to it and see if it sounds ok. If so, then the subs are messed up. If it sounds the same, make sure the subs are connected correctly.
Oct 21, 2009 | Car Audio & Video
Lt960-4 power acoustik Amp 4 channels mono
it can be used as a bass amp. if each pair of channels is bridged then you will basically have a 2 channel amp. just be sure to set the x-over's to lpf for subwoofers. I checked the power ratings, and bridged at a 4 ohm load will give you 250 rms watts per sub, so thats enough to run most 10's or 12's. there wasnt a rating for a 2 ohm load, but your amp should support it.
Aug 03, 2009 | Power Acoustik LT-980/2 Car Audio...
4 AWG amp wire
For that amplifier you need to be running 0 gauge wire . Also check your ground to make sure you have the best connection possible.
May 16, 2009 | Power Acoustik A2400DB Car Audio Amplifier
Amp is not putting out, shuts down
you have a bad ground recheck your ground and make sure you have a good one
or the guage of your power wire isnt big enough
May 01, 2009 | Power Acoustik GOTHIC OV2-1800 Car Amp
600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Oct 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
