Question about Euro-Pro Fast and Easy 420 Mechanical Sewing Machine
Tension problems I'm going insane!!! This is my sisters machine and I can't get the tension right. The top stitches are pretty good, but the stitches underneath are as jagged as a scerated knife. HELP!!! Oh, and she doesn't know where her manual is.
  • 40 Answers
Start with the bottom- should allow thread to pass freely with slight tension when dangled from the thread. Tiny screw on the bobbin case turned clockwise tightens tension. Next, check upper tension. Thread should pull through with foot down, with good tension. Stitch should 'lock inside the fabric(use two pieces of fabric and make a seam, thread from both top and bottom should be visible when you open the seam.
Posted on Jun 01, 2010
Bottom stitch is a straight thread that pulls out easily. Top stitching looks good. I have rethreaded itseveral times. What's another option?
Tighten the top tension. Tension is a tug of war between the top and bobbin threads. Right now, the top thread is not applying any tug on the bobbin thread. The tension is correct when the two threads meet in the middle of the fabric. Tension is never static. When the project changes, you should probably check and readjust the tension.
Understanding Thread Tension Threads
Nov 17, 2017 | Sewing Machines
The bottom stitching looks like a line and not stitches the top stitching is fine
whether its bias or straight does not matter to machine. loosen the bobbin tension and put more tension on take up spring by inserting a screwdriver in the slot of the top thread tensioner. turn to right.
Dec 13, 2012 | Juki DDL8300N Sewing Machine
Top stitch looks great, under stitch bunches. I have rethreaded, rebobbined, changed tension. same result. :(
Bunching of thread is 99% a top tension problem. Make sure you thread the top thread correctly. Thread the machine with the presser lever up. Test the tension by lowering the presser lever before threading the eye of the needle, by pulling the thread with your left hand and adjusting the tension with your right hand while slowly pulling downwards. There should be no resistance when the tension dial is on zero, and you should be able to feel more resistance when you increase the tension. Ideal tension is between 3 and 5. When your top tension is correct, your machine should operate correctly. If you feel no resistance with the presser foot down and the tension dial on 5, check the tension disks for fluff or broken thread. When you lift the presser foot, the tension disks should open and you would be able to remove any cotton or fluff. Good Luck
Aug 30, 2011 | Singer 4423 Sewing Machine
How do I adjust the bobbin tension? The stitches it produces are loose/loopy. The thread pulls out of the fabric like a basting stitch.
Make sure that your top threading is right. My sister in law has this same machine and it is a really hard thing to do, Your manual has very vague instructions but check your thread going through the tension discs by pulling on the top thread with the presser foot up, it should pull smoothly, now put the presser foot down, it should barely move. /Sometimes this seats the thread in the tension discs. She is having no luck with the buttonhole making. In 50 years of sewing I have never seen a more vague manual and no customer service at all.
Dec 04, 2010 | Euro-Pro Shark 60 - 384
The top thread is looking good, the bottom stitch is bunching up
re-thread the top, when the top looks good but the bottom is bad it is the top thread
Oct 16, 2009 | Necchi Sewing Machines
Sears Kenmore sewing machine model number 15358 tension issues
#14 needle is way big for cotton napkin scrap. a #10 is good for most lightweight fabric. #14 is for sewing denim or levis, like that.
the tension problems on almost all machines regardless of price usually fall on the upper tension. the lower bobbin tension is factory set and it's rare you should ever need to mess with it.
if you have a drop in bobbin (top loading), tighten the adjustment screw all the way and then back it off 1/4 turn. if your machine uses a shuttle bobbin, tighten the adjustment screw all the way and then back it off in 1/4-turn increments until you can hold it in the air like a yo-yo and cause to bobbin case to fall slightly dipping your hand.
A dull needle and stitch length will also mess up your stitch. The idea is to narrow the problem down to one thing and one thing only -- UPPER THREAD TENSION.
So, if you have the right size needle for the job, with the right thread, and if your stitch length selection is correct (usually between 2 and 3 or 8-to-10 stitches per inch, the problem should be with your upper thread tension.
An easy way to fix this then is to remember: Loops on top, upper tension drop. Loops below, upper tension grow. If you get loops on top of your work, lower (drop) your upper thread tension to a lower number. If you get loops on the bottom, raise the upper thread tension.
Different stitches on the same machine will require different upper thread tension settings. Don't be afraid of it. Just remember the pneumonic: loops on top, tension drop, loops below, tension grow -- referring to upper thread tension.
have fun :)
Apr 15, 2009 | Sewing Machines
CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Jan 18, 2009 | Euro-Pro 8260 Mechanical Sewing Machine
I am pretty new to sewing and my machine. I just changed thread and put in a new bobbin. Now my stitches look correct on the top side of the fabric but awful on the underside. There is a ton of extra...
it's the tension on the top thread.  rethread the machine and make sure the thread actually goes into the tension discs.  the thread should flow with resistance.  very good explanation of the problem by the way--good luck and enjoy sewing!
Jan 17, 2009 | Sewing Machines
I have a Singer Featherweight 221-1 that won't form a stitch
The needle goes in with the flat side on the left and you thread it from right to left ,hope this helps
Jan 10, 2009 | Singer Featherweight II 117
Euro-Pro Fast and Easy 420 Mechanical Sewing Machine Logo
131 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
