Question about Goodman CLQ36AR49 Air Conditioner
We have a goodman heat pump and in the afternoon
The unit will come on but the fan doesn't run. It will operate again after I turn off the unit, wait a few minutes then turn it back on.
    Guru:
  • 587 Answers
If the outdoor fan is not coming on, then the unit is going off on high head pressure. You need to get the fan running before you unit unit will operate.
Disconnect all the power from the unit, Try spinning the fan blade if it spins freely, then the bearings are ok, if not, the bearings are bad and the motor needs replaced. Check the capacitor to see if it has a bulge or is distorted, if it does the capacitor is bad, if not you need to check the capacitor, sometimes you can take it to your parts store and they will check it for you.
If the capacitor is good and the motor spins freely, then with the power turned back on check to see if you have the proper voltage at the fan terminals. If you do then the motor is bad and needs replaced.
If you don't, then you need to be looking for a broken or loose wire.
Posted on Jun 01, 2010
Goodman minisplit flashes on pre. Def. Wont start
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Repair Tamarac
Apr 07, 2015 | Goodman Heating & Cooling
Will not come on but emergence heat works
Check contactor that operates compressor and condenser fan. Does it try to come on when you first turn it on, or just sits there? If it tries to come on, it could be the capacitor.
Jan 25, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Heat pump fan does not always turn on when heat pumd does. Is this a fan relay problem? If so, is this something a homeowner can replace?
if you are talking about the indoor fan on the unit and it is a electric heater then yes there is a fan relay that control the fan operation that is common to fail on these units.. it is fairly easy to replace and can be purchased on line at diiferent heating sites... type in goodman heating parts in a search engine and locate the relay you need... if you are talking about the outdoor fan motor then need to check a few things there is a capacitor that helps motor start that could be weak /by the way there is also a capacitor on the indoor unit you want to check to .... it usually is 5-20 microfarads that requires a meter or tester that can check the farads on capacitor... make sure these are good... the outside unit will sometimes not have the fan motor run if the unit is in a defrost cycle but should only stay of for 5-15 minutes at a time and only if it is in a defrost cycle ... hope this helps you out repost if you have anymore questions...
Jan 24, 2011 | Goodman Heating & Cooling
Fan does not turn off even after disconnecting
Are you referring to the fan on the external mechanism, or the internal air handling fan?
The external fan is not controlled by the internal thermostat. it is controlled by the thermos-witch of the compressor. The external fan may or may not run when the motor is operating. it depend totally on the temperature of teh compressor, and not the internal thermostat.
It the internal air handling fan is running continuously,it may be a a problem with the fan setting. check if the fan is set to 'ON' instead of 'AUTO', and correct it.
Incidentally the fan operation I described, is for modern, energy efficient heat systems. This is a energy saving design incorporated in all heating systems including automobile radiator fans.
Jan 31, 2010 | Goodman Heating & Cooling
Fan not running on Heat Pum
That does not sound normal at all, I have a Goodman Heatpump and the Fan on the Evaporator (outside unit) should run as soon as it starts up!
The only delay you should be seeing is when the unit starts, the fan in the AHU starts 5 seconds after and runs for about 1.5 minutes after shutdown.
Sep 19, 2009 | Goodman CLQ36AR49 Air Conditioner
I have Goodman combination heating and cooling outdoor unit PBB series. I am wanting to know if when the heat is on should the fan outside turn or is that only ac
If it's a heatpump, then yes the outdoor fan will turn unless the unit is going in defrost mode. But for the majority of the time a heat pump is operating in heat mode, the outdoor fan is running.
Jan 16, 2009 | Heating & Cooling
Goodman compressor cuts off when temp too high
I believe you have 1 of 2 problems going on here your system may be overcharged causing the compressor to cut out on a overload relay circuit internally, or it also could be tripping out a high pressure switch which could be from an overcharged system or a dirty condenser. I would have the tech come out on a 90 degree day and put the gauges on and check the pressures while it is operating under a full load.
Hope this helps you.
Please rate me
Jul 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman split not responding to remote
First turn the main power off to the unit at the breaker, wait about five min. and switch the breaker back on, then see if this solves the problem. In the instalation manual that came with the unit on the last page you will see a code of the red blinking light, this will tell you the most likely problem if not solved by switching the breaker on again.............Hope this helps
Oct 14, 2007 | Hitachi RAS-09UH Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
111 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
