Question about KitchenAid Superba KSRS27CN Side by Side Refrigerator
The refigerator is a little wobbly
One corner of the refrigerator is lower and the whole refrigerator is therefore wobbly when I close a door. I know that the adjustjment is probably not too difficult, but I would like to have a description of what the wheel and any adjustment mechanism looks like. A picture is worth a thousand words! I hope I do not have to lie the refrigerator on it's side, god forbid! Any information would be very helpful. Thanking you much in advance.
Sincerely,
Wayne Kitchenaid Superba Model KSRS27Q
side by side refrigerator
    Scholar:
  • 59 Answers
Hi Wayne,
I believe I can describe the procedure.
1. Remove the front lower grille.
2. Look on the left and right front lower part behind that grille and you will see one of two things. Leveling legs or you will see bolt heads right over a wheel. These bolt heads are adjusting bolts. I ll go over the bolts because legs are fairly easy.
3. Choose the wheel in the front that is going to support your unit the best and turn the bolt just above it. It will be okay you can turn it with no problems you will see the wheel go up and down. Thats it.
4. I have posted a tip just below for you to read about leveling and doors. If you follow that you will be fine no laying the refrigerator down.
And please if you need further help all you have to do is ask.
A tip about doors.
Posted on May 30, 2010
Kelvinator Cyclic 330 not getting cold enough
Empty the refigerator and freezer, unplug it for about 8 hours, leave freezer door open so it will completely defrost. Plug it back in for 4 hours and close doors before you fill it back up with food. If you have a thermometer, check the interior temperatures before you fill it back up. Refigerator should be around 42 degrees F.
Mar 19, 2014 | Refrigerators
Refigerator door doesn't stay sealed shut
Check the seal condition for any damage, crack and etc. Ensure you check the whole seal. Clean the surface (seal and the contact) from any dirt/oil and etc.
Sep 24, 2007 | Sub-Zero 650 / O Bottom Freezer...
The left side door has dropped and the piece that closes the gap between the two doors will not operate properly. It leaves the gap open and the refrigerator looses coolness. Need to know how to realign...
Check the lower hinge of that door for a broken closer cam. The upper hinge is adjustable and adjusting the corners in the front will shift the cabinet to align the door also.
Eric
Dec 11, 2009 | Samsung RF265AA Bottom Freezer French Door...
Freezer drawer jars open at upper right corner when refrig door is closed. Air leaks in and is forming frost on frozen food.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Nov 05, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
My refigerator leaves too much moisture in the refigerator. Everything has mositure on it.
99 percent of the time that is from leaking door gaskets or a door not closing completely. The moisture you are seeing is from air entering the refrigerator and the moisture in the air condenses to water. Check the door gaskets for a good seal all around and make sure there is no gaps anywhere when the doors are shut.
Sep 13, 2009 | Refrigerators
WATER DOES NOT DISPENSE FROM DOOR
Sounds like the water solenoid valve poppet is sticking in the closed position. You will need to replace the assembly. It is located behind the fridge at the lower corner.
Jun 18, 2009 | Whirlpool ED5SHAXM Side by Side...
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Lower door wont stay closed
I doubt it. The problem is probably that the unit is on an uneven or unlevel floor. Make sure all 4 corners are 'solid' and the unit is level. Is the door overloaded? Any hinge damage to either door or loose hardware?
Jan 10, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
KitchenAid Superba KSRS27CN Side by Side Refrigerator Logo
244 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
