Question about Welding Tools
Ramsond ct 518 tig does not work, red overload light stays on. re-set's with off then on, but striking an arc usually causes overload red light to reoccur. Please help, ty
davesoucy
  • 148 Answers
SOURCE: Arc start board
At your nearest Miller distributor (almost all gaz reseller)
Posted on Aug 08, 2009
co7196
  • 3433 Answers
SOURCE: Miller Syncrowave 200 wont strike arc for TIG
proper polarity?
Posted on Nov 12, 2009
SOURCE: Tig welder wont strike up arc, power to welder ok,
www.millerwelds.com › ProductsTIG -
www.millerwelds.com › Service & Support
Posted on Mar 27, 2010
nitrospawn
  • 290 Answers
SOURCE: giant inverter tig mma111 230 volt
check if the load on it is not more than its capacity and check the batteries if they are still in good condition
Posted on Mar 31, 2010
  • 3 Answers
SOURCE: My miller sychrowave tig welder is not blowing
Remove the tig torch twist lock from the front of the machine. Step on the pedal as if you were striking an arc and gas should flow out of the twist lock port. If gas comes out of the port, your torch probably has a valve built in (many do) often this is a sleeve on the torch body which you rotate but may not be obvious.
If no gas out of port then its the solenoid or regulator.
You do have the machine in TIG mode and not stick?
Posted on Jun 04, 2010
Testimonial: "Your solution didn't solve the problem directly, but it led me to the solution. I had the tig torch hooked up to the "work" plug when it needed to go into the "electrode" plug. Removing the side panel to find the valve showed me where the argon hose went. Thank you!"
No gas flow
If theres a pre or post flow set it will deley gas flow when using a foot pedal or strike arc.
Jun 05, 2010 | Miller Welding Tools
My miller sychrowave tig welder is not blowing sheilding gas when it strikes an arc. The gas is on at the tank. I can hear what sounds like gas or a valve opening when I press the foot control, but my...
May 28, 2010 | Miller Welding Tools
My tig welder wont arc unless I touch the metal with it
my guess would be the type of welding machine you have.usually there is extra switch which says start control also continious cycle , sometimes smaller machines dont have these switches to allow a wider variety of tweeking the welder ,also its ok if you have to touch the base metal cause thats what starts the contact with the work peice ,keep a arc after touching about 1/4 inch away from work peice ,also a good steady hand rest will make a good welder in any situation this should allow the arc to remaim stable with a comntinious weld arc puddle. happy welding
May 22, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Arc start board
Jun 03, 2009 | Hobart Welders Champion 500433A Factory...
LINDE HDA 300 TIG WELDER HIGH FREQ. PROBLEMS
The contact should have a gap .008 .
Mar 21, 2009 | Welding Tools
GIANT 200AMP INVERTER ARC WELDER NO POWER TO THE LEADS
remove the fan from the circuit and try it then, does it weld ok with the fan removed?
Dec 13, 2008 | Inverter 220 Volt Tig Arc Welder
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
