Question about Toshiba DR410 DVD Recorder
How to finalize a recorded dvd disc?
For example, I record a video on the disc, one hour,
or two hours, it does not matter because when the
recording is done, I follow the steps--- setup, etc,
but I cannot get to the 'dvd menu' under setup as
it is not highlighted, thus I cannot 'finalize' the disc,
and no playback.....why ? what can I do?
..the manual for my Toshiba DR430KU doesnot have
suggest any other alternatives....etc...thanks in advance
    President:
  • 1,285 Answers
On the remote is there quick navi button (this will take u to the finalizing screen)
Posted on Jun 26, 2010
  • ronf57
    ronf57 Nov 05, 2012
    what is this button labeled as I am staring at the remote and do not see any "navi" labeled button. closest is "setup" or "topmenu" or "menu/list"
Tried to record on a DVD-R disc, but unit said that the disc was full. I then tried to finalize the disc, but the unit got stuck in the finalization process. I unplugged/replugged the unit to make it...
The most likely reason the unit got 'stuck during finalisation' is probably because there was insufficent space left on the disc for it to write the respective lead-out/menu data (or perhaps there was a bad disc sector) - disc full? Because you unplugged the unit from power point before it had finished, the disc is possibly corrupted now. Throw that disc out.
The manual clearly warns: Do not disconnect the AC power supply cord while finalising. This
can render the disc unusable.
In other words, you have lost that particular recording and you are wasting your time with that disc.
There is nothing in the manual to suggest the length of time required for DVD-R recovery - there is a recovery process for the whole unit (such as after a power cut while recording a timer program for example) but not for discs. I may be wrong here...
However, the upshot is you have lost a disc, not a recorder. Another drink coaster for your living room.
Mar 29, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
When recording two vhs tapes back to back on one disk, it will not finalize. But, will finalize if one tape is recorded. Mind you now each tape only has one half an hour recording on them, and the disk is...
The disc requires some space for the finalizing process. Two half-hour tapes take up all the room on the disc and leave nothing for the process. You'll need to record at a lower speed.
Feb 26, 2011 | Cameras
Is there a way to record something on a dvd from the tv?
Which model do you have? Some of the GoVideo DVD/VCR units are only DVD players so you can only record to the VHS tape. If you have a DVD writer version, you may find it tedious but doable. First load the blank DVD and set the Disc Record mode (you will see an on-screen prompt) for VR (this lets you do more editing of the video) or Video (this choice is compatible with more players). Then set the REC Mode by pressing that button repeatedly (SP (2 hours per disc), LP or XP(1 hour per disc). For one-touch recording (recording the current program that you are receiving on the device), select your Channel and Audio track then press REC. If you press REC several times, you will set when the recording stops. Otherwise it will not end until you press STOP.
For timed recording, press Timer Record. Then go through all the items to set the DVD recording information. Record mode, Channel, start and stop times. The left and right arrows let you change menu sections and the up down scroll through the settings. Press Enter to save the programmed recording. Then press Return. Make sure blank media (or with enough room for the programmed item) is in the machine. On some units, you will need to turn off the machine for the Timed Recording to work.
For recording from external sources, press Input instead of Channel.
For any recording, leave a bit of extra space on the disc to Finalize the DVD if you will want to play the disc on other players.
I hope this helps.
Aug 15, 2010 | GoVideo Go Video DVD/VCR Combo
Finalize a Disc on Mangavox MWR10D6
No. Generally finalising just writes the unused spaces as unused so the player knows and adds a stop code. The shorter the DVD the longer the finalise. An hour and a half on two hours is plenty of space.
Apr 13, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I'm trying to copy old family videos from VCR to DVD. I'm using the correct disc type (DVD-R) and there's no copy protection. I've tried both Sony and HP discs. Each time, it seems to be working but...
First, try to refinalize the disc if it failed the first time by going into the edit menu. Sometimes finalization just fails the first time.
If you are recording on 2-hr mode, and the length of your recording is an 1hr 50 min or more, there will not be enough space left on the disc to finalize. Going forward, your best solution would be to record in 3- or 4-hour mode for every 2 hrs worth of recording (6-hour mode for 3-5 hours of recording, etc.). Just to quickly decipher recording modes: 2-hr mode (sometimes called SP Mode, depending on DVD player) will record about 2 hours worth of material on a standard blank DVD (but some extra space would be required for finalization); 4-hour mode would record 4 hours worth of material on a standard DVD; 6-hour mode would record 6 hours, etc.
As far as salvaging the recordings you have already made - load the burned, yet unfinalized DVD's into your computer. Copy the files onto the desktop or some easy-to-find location on your computer. Then use a program, free or otherwise (I personally reccomend Nero or Roxio), to re-burn the discs. The newer version of Nero automatically finalizes the disc, but some software requires you to select an option that allows you to "close disc" or "finalize" the disc. (In computer lingo, "closing" means the same thing as "finalizing").
-Tha Mp3 Doctor
Mar 04, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Recording from VHS to DVD
First, you will need to know if the program was recorded in XP mode, SP mode, LP mode, or EP mode. To find out how much room there is left, put the dvd in the tray and press the Disc Menu/List button on the JVC remote. This will display the title and how long it is - write that number down. It will also say either "XP,SP, LP, or EP" - write down that mode. In XP mode, a DVD will hold 1 hr and 20 mins worth of prgramming - MAXIMUM. SP mode = 2 hours. LP mode = 4 hours. EP = 6 hours. So, if your program is one hour, and you recorded in LP mode, you have 4 - 1 = 3 hours of space left for recording on that disc.
If you finalize a disc, you will no longer be able to add more programs to that disc, unless the disc is a + or - RW disc. Also note that finalization requires some disc space, so if you recorded a program that is exactly 1hr and 20 mins long, and you recorded it in XP mode, then the disc will probably not finalize correctly.
That being said, the finalization directions are on p. 23 of your manaul: Title --> Finalize --> => --> find finalize --> Enter --> OK --> Enter
Now it will play on other players.
Here is a link to the user manual:
http://resources.jvc.com/Resources/00/00/93/LPT1133-001A.pdf
-Tha Mp3 Doctor
Dec 31, 2008 | JVC DR-MV7 DVD Recorder/VCR
I am recording fron VHS to DVD. When I am finished and push the stop button, How can I tell how much space is on the DVD to record something else and how do I finish the dik so it can't be recordered over
JVC DVD Recorder – Finalizing and disc space
-Tha Mp3 Doctor
Finalize cd-rw on Sony HandyCam DCR-DVD92
hi dear
you can finalize your dcr in record position
going to disc manager find the finalize
and finish
oke
Mar 28, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
DVD-RW will not finalize after recording
There is no solution for your problem. I thought my 4500 wouldn't finalize also but what is happening is that it didn't record on the disc you used. This is an older model unit and will not record on 16x discs. I believe you are boinked.
Feb 13, 2008 | Sansui VRDVD4005 DVD Player/VCR
Toshiba DR410 DVD Recorder Logo
947 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
