I have a mutoh toucan lt i have 3 problems with it 1, i just replaced a print heda and need ot know hwo to set the individual voltage for it. 2. the language keeps getting reset to japanese. i need to know how to make it english again, and keep it that way. 3. it states not origonal ink, but it is, and i
Mutoh Toucan LT error E105 fuse 4 error
This Machine is 5 year old ,the problem start with System error E111 Head over heat 2,I replace the ribbon on Cyan was printing OK on small size job,wen I try to print a large size panel the machine will stop and display error E11 Head over heat 2 .
Were is the fuse 4 on this older model?
If the fuse went, is have a problem in the printer head?
PLEASE HELP
Ralph
Posted on Jul 14, 2011
Error code E000064-0000
E064-0000 Description The presence of a high-voltage error is communicated by the composite power supply PCB (The output for primary charging, developing, or transfer has deviated from a specific level of voltage) Causes The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty. proce Remedy 1. Contact Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact? YES: Clean the contact, and set it once again. 2. Wiring Is the wiring between the contacts for the following normal: DC controller PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller? a. DC controller PCB (J301) <-> composite power supply PCB (J136) b. composite power supply PCB (J130-7) <-> primary charging roller contact c. composite power supply PCB (J130-1) <-> developing assembly contact d. composite power supply PCB (FT133) <-> transfer roller contact NO: Correct the connection. 3. Composite power supply PCB, DC controller PCB Try replacing the composite power supply PCB. Is the problem corrected? YES: Yes. NO: Replace the DC controller PCB
Nov 19, 2014 | Canon Ir 3300 Black & White Copier
Code nck alcatel OT S 211
Hi. You can get the accurate unlock code for your Alcatel OT-S211 from ProUnlocking.com at affordable cost. Good luck mate.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch ON your Alcatel OT-S211 with a NOT ACCEPTED SIM Card,
2 - When the message "Enter Network Key" appears, enter the Unlock Code.
OR
1 - Switch ON your Alcatel OT-S211 WITHOUT SIM Card,
2 - Then compose : *#0000*CODE#,
3 - To finish compose : *#0001*CODE#.
CODE: The unique unlock code for your Alcatel OT-S211.
Jul 23, 2014 | Alcatel Cell Phones
Canon load correct paper
•When copying or printing received faxes, check the following:
1. Paper loaded in the machine
2. The paper size specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
•When printing from a computer, check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Oct 15, 2013 | Office Equipment & Supplies
Errore000064 occured
Power supply voltage error (high-voltage error)
power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause: The contact has poor connection. The wiring is faulty. The composite power
Action
1. Contact
2. Wiring
YES: Yes.
NO: Replace the DC controller PCB.
Jan 19, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
The spark plugs are not set in right order need the right setting in order how to place them
For the 1993 Chevrolet Lumina APV
I do not know if your have the 3.1L or the 3.8L Engine; however I have included both below:
For the 3.1L:
Firing Order:
1 - 2 - 3 - 4 - 5 - 6
Cylinders:
........(back)........
|...1.....3.....5...|
|...2.....4.....6...|
........(front)
Distributor Connections:
...(+)..2
..................3
.....................4
..6
...........5....(+)
For the 3.8L:
Firing Order:
1 - 6 - 5 - 4 - 3 - 2
Cylinders:
..........(back).........
|....2......4......6....|
|....1......3......5....|
...........(front)
Coil Connections:
...o <----6
O
...o <----3
...o <----2
O
...o <----5
...o <----4
O
...o <----1
Let me know if this helped, or if you have additional questions. Feel Free to contact me at FixYa.com!
Jul 21, 2010 | 1993 Chevrolet Lumina APV
Can this printer be used with a wireless network
Yes this printer does print wireless. Follow the instructions below. Accessing the [Device Settings]
  1. Press the <Menu> button.
  2. Use the right / left cursor button to select [Maintenance / settings] and press the <OK> button.
    Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 3.
  3. Use the right / left cursor button to select [Device settings], and press the <OK> button.
  4. Use the up / down cursor button to select the item to set, then press the <OK> button.
< 1 > Print settings
< 2 > Wireless print settings
< 3 > Bluetooth settings
< 4 > Other settings
< 5 > Language selection
< 6 > Reset setting
< 7 > Save settings
< 8 > Load settings
Further instructions can be found on usa.canon.com
Jan 06, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Problem and credit card payment already submitted on canon pixma Please advise. Problem with fax memory, can't print faxes
1 Press [FAX], then press [Menu].
2 Use [< ] or [> ] to select <MEMORY REFERENCE>.
3 Press [OK].
4 Use [< ] or [> ] to select <PRINT DOCUMENT> or <DELETE DOCUMENT>.
▼ If you select <PRINT DOCUMENT>:
1. Press [OK]. 2. Use [<] or [> ] to select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the Numeric Keys. If you are unsure of the transaction number, print the DOC. MEMORY LIST. (See "Printing A List Of Documents In Memory".)
3. Press [OK]. 4. Press [< ] to print the first page only, or press [> ] to print all pages of the document. 5. To print another document, return to branch-step 2, or to finish printing, go to step 6. ▼ If you select <DELETE DOCUMENT>:
1. Press [OK]. 2. Use [< ] or [> ] to select <ALL PRINTED DOCS.> or <1 DOCUMENT>. – <ALL PRINTED DOCS.>: Deletes all the printed documents stored in memory.
– <1 DOCUMENT>: Deletes a single document stored in memory.
3. Go to step 5. 5 Press [OK].
▼ If you selected <ALL PRINTED DOCS.> above:
1. Press [< ]. Press [> ] to cancel deleting, and the machine returns to the standby mode.
If you selected <1 DOCUMENT> above:
1. Use [< ] or [> ] to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the Numeric Keys. If you are unsure of the transaction number, print the DOC. MEMORY LIST. (See "Printing A List Of Documents In Memory".)
2. Press [OK]. 3. Press [< ]. Press [>] to cancel deleting, and the machine returns to the LCD of branch-step 1.
4. To delete another document, return to branch-step 1, or to finish deleting, go to step 6. 6 Press [Stop/Reset].
Sep 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Can't print DL envelopes on a Pixma iP4600
Hi ...
If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
Prepare the printer:
  1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
  2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
  3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
  4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
    * Figure 1
  5. Load the envelope.
    1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
    2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
      * Figure 2
    3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
      * Figure 3
      Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
Preparing Envelopes to Load:
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
Paper Type
Precaution
Envelope*
DL / #10
Set paper with the flap closed.
Unsuitable Envelopes:
  • Envelopes with an embossed or treated surface
  • Envelopes with a double flap or pressure seals
Printer Driver Settings:
  1. Select Envelope in Media Type.
  2. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
Don't forget to vote if this helps ... Cheers :)
Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Reset paa\ssword
Try this, it worked for my DP-300U.
username: psadmin
password: SYSXXXX (Where XXXX is the last four digits of the MAC address, which can seen on the underside of the server)
I learned this from viaujoc- (http://www.fixya.com/support/t224263-dp301p_psadmin_password_forgoten). On that post he also suggests a way of extracting the forgotten password from a configuation backup file.
Jul 01, 2009 | D-Link DP-300U (DHDP300U) Print Server
416 people viewed this question
k24674
jasbo
jasbo
