Question about Yamaha RX-V663 Receiver
How do I connect outside speakers to my yamaha rx-665 receiver?
  • David Dunn
    David Dunn May 29, 2010
    Um, the same way you connect INside speakers, but with longer cables? Not sure what you're getting at here.
4 Suggested Answers
SOURCE: yamaha stereo receiver rx-830
Does your TV have any audio outputs such as RCA perhaps?
Posted on Jan 13, 2008
Ajkill
  • 2035 Answers
SOURCE: yamaha rx-v2500 receiver how to hook up speakers
You can hook the speaker like this one center speaker , two front right and left speaker,and then rear right and left speaker and one sub speaker in the unit ...
Good luck...
Posted on Oct 06, 2008
petraman7
  • 1175 Answers
SOURCE: Wii to RX-V363?
Hi..
If youre talking about the set of 3 A/V plugs in the front then you need to connect to the Video Out (yellow) plug in the back that says something like "Front Video" or "video 3" out. Connect that to the display.
Posted on Jan 14, 2009
I have connected a cordless microphone to RX-V663 but there is no output in speakers? Do I have to make changes to amplifier or select out some outputs?
How did you 'connect' the cordless microphone to the RX-V663? You will need to select this same input in order to get output in the speakers.
Sep 25, 2014 | Yamaha Rx V663 7.2 Channel 665 Watt...
Why yamaha rx-v 575 does not turn on?
You have a short in your speaker cables (not connected to speakers or small fiber of wire connecting across the speaker terminals)
-or-
your output transistors have gone bad and need to be replaced. This usually costs the same as a new receiver.
Jul 31, 2014 | Yamaha Audio Players & Recorders
Im not getting any sound from my speakers
You may have to turn the TV speakers off to direct audio output to your receiver. Your setup routine should allow you to do this
Dec 24, 2012 | Yamaha Rx V663 7.2 Channel 665 Watt...
I have a Yamaha RX - V665 and the right rear surround works only part of the time.
Start by using an old test speaker and connect it directly to the right surround output with a short wire and monitor it.
If it sems to work with no issues, you either have a bad connection at receiver or speaker, or a break in the speaker wire somewhere.
If you have the same problem with the test speaker, you have a rgt. rear output issue in the receiver and it needs repair.
Hope this helps
Apr 17, 2010 | Yamaha RX-V663 Receiver
Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Jan 06, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
I have a Yamaha RX-V863 receiver connected to a
Do you have all 5+1 speakers connected? You need to go to the Setup menu of yamaha and set which speakers you have and which you don't. For example if you don't have the Center speaker connected, receiver will redirect and mix the sound to the other speakers.
Blue-ray film over HDMI should automatically output via all your configured speakers (nothing to be configured).
Nov 26, 2009 | Yamaha RX-V863 Receiver
Yamaha RX-V361 DVD cuts off w/ check SP cable message
This message means that speakers are not connected properly. What is their impedance? What is the impedance set on the receiver via Advanced Setup menu (see manual)? Check if it is not short-circuited.
Try the receiver without speakers connected. If the message goes away, receiver is OK and problem is in the connection to the speakers.
Jun 04, 2009 | Yamaha RX-V361 Home Theater Receiver
How to run outdoor speakers from my in house receiver
If you have a button for A and/or B speakers on the front of your unit, then use the A (or B) speaker connections for the inside speakers and B (or A) speaker connections for the outside speakers. Then of course you just select either A or B depending on where you want the sound to come out. If you select A and B then it will come out at both locations. If you don't have A/B speaker selection available on the unit, then you will need a speaker select switch (from Radio Shack) or else wire up a four pole double throw toggle switch to do the job.
Jun 03, 2008 | Yamaha RX-V2090 Receiver
Yamaha RX-V663 Receiver Logo
50 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
