Question about Garland GXC-48 Grill
Can't light the grill - it's 6 burners Garland
  • 652 Answers
You may need a new striker. I'm sure you have gas right? try using a match to light it.
Posted on May 30, 2010
  • 1 more comment
  • debrademuth May 30, 2010
    Can't smell the gas when we turn ignite knob. We don't have manual......just moved in new home w/grill. Gas is on. Would match still work? Willing ot give it a try. D
    How do you turn the gas supply on/off for the outdoor Garland Grill 6 burner? Where would the gas supply typically be controlled?
    I can't read the model number off the back - seem to be a number of models listed under "model #." with circles next to them. I need this to get the manual.
    Thanks,
    Debra
    May 30, 2010 - Can't smell the gas when we turn ignite knob. We don't have manual......just moved in new home w/grill. Gas is on. Would match still work? Willing ot give it a try. D
    May 30, 2010 - How do you turn the gas supply on/off for the outdoor Garland Grill 6 burner? Where would the gas supply typically be controlled?
    Thanks,
    Debra
Grill burners not working correctly. There are 3 burners under our grill. the left one has pilot light on but wont light burner middle and left burners will only work if turned clear up to high
Not familiar with these models, but it sounds to me like it could be a gas pressure problem...? Is there a regulator - sometimes they fail. Are any other appliances hooked into the same gas line? If so, how well are they functioning?
Jan 19, 2014 | Garland/Us Range Gfe60-4g36rr Gfe Starfire...
Our garland grill caught fire yesterday and we are needing parts...can you help, if not where do I call to get them ? 407-384-7368 Nancy
Nancy, the following link is for the Garland Parts Department. When you contact them, be sure to have the model number of your grill, handy. Without that, there's not much they can do to help you.
http://www.garland-group.com/?xhtml=xhtml/gar/us/en/minisite/service/contactparts.html&xsl=minisite.xsl
Hope this helps you. Please let me know. Thanks.
May 04, 2011 | Garland Grilling
I took over a kitchen which has the garland grill don't know the model number because the previous owner lost the manual for it and i can't find any marking on the equipment. It's an older model where i...
if its gas then it wouldnt be a pilot it would be an ignitor remove top lower heat shield or look from bottom either way one way or another you have to be able to get to the ignitor and perform an ampere test on the ignitor should be drawing 3-3.3 amps any less then this and you would have to replace the ignitor yes at 2.9 you should also replace the ignitor because it would take longer to light the gas making your cooking take longer and the oven not heat properly as well if you have any further questions message me back and Thanks again Rick
Jan 10, 2011 | Garland H283 Gas Kitchen Range
Pilot relighting Garland Commercial range
The main burner valve is the oven valve. The pilot will be next to the burner and you either have to insert a long shiskabob stick ( lit) into the hole or lift up on the bottom of the oven (inside) and you will see the pilot.
Feb 09, 2010 | Garland H286 Gas Kitchen Range
Looking for spare parts for a garland griddle any one know where i can get them ?its a three burner one not working properly
I can get what ever parts you are needing for your Garland grill. Give me a shout @682-433-7378
Rick
Jul 17, 2009 | Garland GXC-48 Grill
Garland 6 Burner Oven
Garland have there own web site for ranges , 6 burner garlands are used in catering . AS for repairing it don't know . Its not that hard I have done a few most parts are good to get .
Jun 08, 2017 | Garland H284-24G Kitchen Range
Black Garland H283 convert to Electric ignition?
Is there a kit to convert an older Garland 6 burner, double oven, griddle and salamander to electronic gas ignition?
Sep 25, 2008 | Garland H283 Gas Kitchen Range
Oven pilot light will not stay lit on Garland 6 burner, double stove, salamander commercial in home
Use a needle right where the pilot flame comes out. Should do the trick. GOODLUCK!!
Dec 16, 2007 | Garland H283 Gas Kitchen Range
60" double oven gas Garland stove
We use a Garland from the 1960's and pilot lights ARE scary and should make you nervous. This is why they are no longer allowed in new gas ranges. I mounted an inline gas shut off to the stove where the gas enters (on mine this is right in front on the left side). It turns on and off like a burner and when we are done cooking we simply shut off the gas there. To light the burners or the stove I use one of those long reach lighters. I go to bed knowing that NO gas is coming in.
We love the stove, it makes cooking more fun.
Good Luck!
Oct 24, 2007 | Garland H283 Gas Kitchen Range
Grilling Logo
35 people viewed this question
Top Garland Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Garland Grilling Expert? Answer questions, earn points and help others
