Question about Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side By Side Refrigerator, White (GS 5SHGXKQ, GS-5SHGXKQ)
Whirlpool side by side refrigerator laeking form
Whirlpool Gold side by side refrigerator leaking form the front bottom
  • Whirlpool Master
  • 1,606 Answers
It sounds as though your filter which screws into the front at the bottom kick plate is bad . The rubber seals on them tend to go bad causing them to leak into the drip pan and causing it to overflow . This will appear to be a leak when in actuality , all you need to do is replace the filter .
Posted on May 29, 2010
    Scholar:
  • 59 Answers
Hello
In the freezer section. Behind the lower rear wall is the coils and just below that is a drain. If you will remove any ice and use a coat hanger or screw driver to push down through that hole you should be able to get it unclogged. Take a small cup of water to verify that you have it unstopped and your done.
#225 in the drawing.
I hope this helps.
whirlpool side by side refrigerator laeking form - moz-screenshot-2.png0whirlpool side by side refrigerator laeking form - moz-screenshot.png
The Whirlpool Gold refrigerator is not cooling and the bottom freezer has ice formed on the back of the freezer. I purchased the refrigerator in February 2009.
If you can hear the fan running in the freezer you have a defrost issue. Depending on the Model number it can be a timer, adaptive defrost board, a bi-metal themostat, or heater.
May 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
My whirlpool gold side by side refrigerator forms a big peice of ice at the very bottom then the ice ends up melting and goes all over the floor whats wrong?
the drain in the back of freezer is blocked
dismantle front of evaporator and deice drain
maybe so hot water over this should fix problem
whendrain is clear water should run donwn hole and collect in evaporator tray under fridge
you may need to mop up after you finish
Nov 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking from hose @ bottom
you have to get filter and see were water is comming out
Mar 31, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker
Hi. Thanks for the question. the problem is . the brass fitting is missing . Or not connected .If missing . The hardware store will have this fitting . Thanks .The Appliance Doc
Sep 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold
Your drain was clogged. look for the drain funnel then remove the dirt.
Jun 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
142 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
