Question about Toshiba MD14FP1 14 in. TV/DVD Combo
Sound but no picture
The television doesn't have a picture - but has sound. It's hooked up to cable - the TVs in the other rooms work fine.
What should I check?
    President:
  • 1,099 Answers
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer.
Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
Good luck...
Posted on Jun 01, 2010
Pc hdmi no sound
some televisions require a seperate audio feed from the HDMI cable to hook up audio. if you have the cables for this i would try that first. normally ends up having to go thru an AV connection
Jan 16, 2014 | Proscan Televison & Video
My polaroid fxm-1911c picture is distorted, sound distorted with loud buzzing when I try to utilize the tv signal input jack, also the dvd player doesn't work
Looks like there are some partial defects in the TV and might need attention of a qualified service technician. Anyhow, make sure that the input cable, RC jacks and sockets all do not have any loose contacts. Go through settings and ensure that every set up is as it should be.
Aug 02, 2012 | Polaroid FXM-1911C 19 in. LCD Television
I have sound but no picture from all my AV inputs on LCD TV. It was working fine then when I switched sources from sky to xbox they stopped working. All connections are fine
Ur LCD inverter board is dead.Replaced this board will get the piccture back.It a long board.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 10, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Picture Jumping
Have you tried to hook it up on video instead of the coax cable
Aug 05, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture but no sound on two cable channels. All
Make sure under the Audio Menu that you have SAP turned OFF
Jul 09, 2009 | Sharp Aquos LC-13S1U-S 13 in. EDTV-Ready...
Converter box installation. Not a clue.
rf cables will work fine for older tvs. newer tvs should use the composite (yellow, red and white cable) to produce a digital picture and sound. FYI the indoor antenna works best when positioned in a window. Best thing to do is install an outdoor antenna in the attic near the gable vent or on the exterior of the house.
Jul 04, 2009 | Televison & Video
Samsung DLP TV and PS3 Problem
Would you please read the manual of TV & PS3 for HDMI cable's
version.
If you match that version, can play.
Dec 27, 2008 | Samsung DLP HL-P5663W 56" TV
New straight out of the box, TV no picture and no sound
If this is working in another room I suggest you check the connection from wherever that particular wire comes from ex. splitter or directle from the antenna I do not know where you tapped in that line. I hope this helps you out.
Nov 28, 2008 | GPX KCL8806DT 7 in. Portable Television
No picture or sound on my tv when hooking up my av cables
Ok
switch the power switch on then wait til the red light comes on..
the push and hold the power button until you hear it beep it should reset itself and sync up! may take 5-10 times
Jun 30, 2008 | Sony Playstation 3 (PS3) Console
Toshiba MD14FP1 14 in. TV/DVD Combo Logo
133 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
