I have a snap back delay when I try and record using my m-audio and protools. I can hear a slight delay in my headphones to what I'm actually playing. How do i get rid of this?
  • 3 Answers
Like Graeme said it's a latency problem.  With the MBox there is a knob to monitor the input coming into the Mbox with no latency and a knob to blend the input signal with the output signal of the pro tools session.  In theory you're supposed to mute the track you're recording and monitor what you're playing in real time with the session audio using the input/output knob.  For the Digi 002/003 and MBox Pro there is a low latency monitoring option in Pro Tools that allows you to monitor while recording without doing this.  I don't think this is the case with M Audio interfaces.  I think the only option is to try to bring your hardware buffer as low as possible so the latency isn't too bad or use an external mixer to do what the input/output knob does in the MBox.
Posted on Apr 26, 2009
  • 1,512 Answers
Hi emmastevens
what you are hearing is latency(delay) in the electronics, software, and maybe your computer is producing some problems also. Have you tried to monitor yourself direct from a mixer before you feed the signal into the MBox.
Posted on Apr 08, 2008
When I record with my m-audio mobile pre USB, there is no latency issues with recording but there is a delay in the headphones if I turn them up to hear myself while recording. How do I fix this? I'm using...
Have a read at this article. I assume you are using ASIO4ALL if not then you should.
Specifically this part:
Note about latency: USB microphones generally only allow you to hear the sound being recorded after it has passed through FL Studio. As the latency of USB microphones depends on the ASIO4ALL latency settings, there may be a troublesome delay between the sound made and it being reproduced from your speakers or headphones. For example, low latency monitoring is particularly important to vocalists as high latencies cause a distracting echo effect. The only solution to this problem is to lower your buffer length settings (there are limits) or obtain a new soundcard with direct-monitoring.
Feb 15, 2015 | M-Audio Computers & Internet
I can't hear the sound from my PC when I'm using the mixer. Its hooked up to both the computer and the speakers, but when I'm recording in pro-tools 11 I can't hear any of my playback. I have to bounc
hello. Im not too familiar with Protools (mainly because its a headache right out of the box), but MY understanding is that Protools won't recognize a lot of external audio devices. (such as behringer)
however..if you are able to record and 'see' the audio there, just not hear it, there might still be a solution, & seeing as how i never used protools, it still might just work.
First of all:
if you're using the UCA-200 external usb box connected with rca cables, then my solution SHOULD work, as it is what i did to get mine to finally do the same thing.
#1) you will need to pick up (x2) RCA-1/4 jack adapters . (radioshack, about $2 each)
#2) insert a red and white rca cable in the RIGHT side of the Mixer's CD/Tape out .....the other end of the rca cables will go into the UCA-200 INPUT.
#3) with 2 more cables in the OUTPUTs of the UCA-200, put the rca-1/4 jack adapters on both cables, insert them back into the Mixer inputs 9/10 (in the analog 1/4 instrument inputs)
#4) adjust volumes accordingly, make sure channel 9/10 isn't muted, headphone volume is up, etc..
.......if that didn't do the trick, then you will need to go into the Audio Settings menu on your computer..(or protools) and change the default playback device to your mixer (probably named Generic USB or something similar)
I really hope this helps somewhat, because i remember going through the same thing & it took a looong time to find the correct awnser.
best of luck!
check for any updated drivers for your mixer! (I personally recommend you do a Google search for Asio4all drivers, they're pretty good)
if your awnser is A), i would suggest going into your computer's Audio Settings menu, and select the mixer as your default playback device.
Nov 23, 2013 | Behringer XENYX 2442FX Mixer
Sentry headphones with mic
My mic DOES pick up stuff, we just can't quite figure out where the mic actually is so we can talk into it and actually hear us talking pretty well, we can slightly hear us talking into it in a recording, but it's so low! (we/us being me and my friend)
Jan 28, 2012 | Sentry HO900 Headphones
I can record voice, but no guitar. Just as many people on this forum, but i didn't saw a proper answer for my problem. I can hear my guitar im using pro tools SE. The light on my fast track lights up,...
In Protools go into hardware setup and make sure that your interface is being read properly. It may be set to something other then your fast track. Then, in the MIX window make sure that your input is set correctly. If your microphone is plugged into input 1, your input on your protools track should correspond to that.
Sep 06, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
When I record and listen to playback, I only hear the left side.
This is normal for recording. Even professionals do the same. What you need is to set your input to mono(either hardware or software), or explore your software look for effects like STEREO to MONO with some delay which I prefer for my recording. I did have a good result. Good Luck
Mar 07, 2010 | M-Audio M AUDIO MOBILE PRE - USB MIC...
Mbox 1 no ouput from protools
Double check and Ensure your headphones work.
Ensure that the master level is turned all the way to the right (Playback). I would also check that the main audio out of the Mbox is functioning so use two TRS 1/4" [balanced] cables to and amp and speakers to ensure master output jacks give you the same result. If they do chances are the Mbox is bad, if not it could be just the headphone preamp is bad
Nov 11, 2008 | Digidesign Mbox External Sound System
Mbox cannot start new session or load in old sessions.
Digidesign website had the answer....go to windows,show workspace and change the settings for your relevant disc from transfer T to R...record in the column.
Thanks  Bobcat8
Oct 07, 2008 | Digidesign Mbox External Sound System
Mbox problem (no input,output)
i'm running os 10.5.6 w/ protools 8.0 and the original mbox. i had the same problem. protools opened and seemed to work except there was no sound from either analog outputs or headphones. this worked for me:
1. shut down computer
2. unplugged all usb cables except keyboard/mouse
3. restarted computer
4. re-plugged usb cable from computer to mbox
5. opened protools session
6. hit play and now i'm hearing sound and everything seems normal.
i hope this helps everyone else
Oct 03, 2008 | Digidesign Mbox External Sound System
M-Audio Pre USB
I guess your output is leaking and you are recording it again to the track.
Try recording with lower output volume. :)
Mar 16, 2008 | M-Audio Mobilepre USB Bus-Powered Preamp...
127 people viewed this question
