Question about Navigon 2090S Car GPS Receiver
Navigon software cannot be started. please reset your device.
Reseting does not work, service center is a joke. better solution to just recicle? thanks and don't buy this brand!
2 Suggested Answers
Wood Chuck
  • 29 Answers
SOURCE: Navigon 2000s I cannot reset the Navigon 2000s
Well after many emails to Navigon I got the fix for my 2000s What you have to do is download the 1.2 version software for the 5100 install it on a 2GB micro SD Card. Put it in the slot and turn it on. You will have to regester as if you have a 5100 but it will work. The reason you have to use a 2GB card is the maps are to large to go on the internal memory.
Posted on Aug 21, 2009
It only shows Restoring factory settings and cannot switch it on or off
With the help of NAVIGON Fresh you can reinstall the software and thus return the device to the factory state. This can be necessary when the device does not work properly anymore or when the software freezes, crashes or otherwise does not behave as intended.
Please be advised that after reinstallation your saved data and favorites will be deleted. After reinstallation a software update or reinstallation of maps can be neccessary as well.
In order to reinstall the software and return the device to the factory state follow the steps detailed below:
1. Check if your device is on the compatibility list for the device restore
process.
2. Charge your device fully with the car or home charger.
3. Connect it via USB cable directly to your PC and turn it on.
4. Start the NAVIGON Fresh program and log in to your account with your
email address and password.
If NAVIGON Fresh is not installed on your PC, you can download the
software here.
5. Go to the menu bar at the top window border and click on
"My Navigon Device" and "Restore Device".
6. If NAVIGON Fresh does not recognize your device, please contact the
service center.
7. Follow the instructions and choose the device which you want to restore.
8. When the wizard has lead you through all the steps, click "next" to
begin the device restore.
9. As soon as the device restore has successfully finished, check for
updates for your device and install them.
Jun 03, 2011 | Navigon GPS
My Navigon GPS says the software cannot be started. Please reset your devise. What do I do to reset it?
what brand name is it ? if it is Garmin then there should be a button on the back of it or bottom it is small just hold it for a few seconds then it should reset it all. hope it works
Feb 28, 2011 | Navigon GPS
I turn it on now it says navigon software cannot be started hold on off key pressed and press reset simultaneously..still doesnt work...help!!!!!!!!!!!!!!
Delete the app and reinstall it via iTunes.
If that doesn't work, you might want to consider restoring your iPhone via iTunes, then reinstalling Navigon. Hope that helps.
Regards,
-K
Jan 13, 2011 | NAVIGON AG NAVIGON MobileNavigator North...
I have a Navigon 2100Max 4.3" GPS. When it turns on freeze at the Navigon screen. I tried to reset it won't work. Their website is no help. Please help.
Please remove the battery for a minute or so. If the problem still persists then have the firmware reinstalled as it has got corrupted.
Dec 14, 2010 | GPS
Navigon software cannot be started. Please reset your device. Thats the message I get when I turn my navigon 2090S on. Can I get help
there is a reset hole somewhere on there that you could fit a paperclip in, click on that for 5 seconds and it will reset your device for you
Dec 29, 2009 | Navigon 2090S Car GPS Receiver
Jun 09, 2009 | Navigon 2000S GPS Receiver
I HAVE A MESSAGE ON MY 2100 GPS,SAYS MN6 .EXE HAS PERFORMED AN IL
Sounds as if the system software that runs the GPS has been corrupted. Your device should have come with a CD that has software that can be reloaded or a utility that can be installed on the PC that connects to the navigon website to download and install the software for you.
Might want to start with that.
Hope this helps
TankMurdock
Apr 24, 2009 | Navigon 2100 Max Portable GPS System
Navigon 2100 problem
2 things that might help...use a paperclip and press the reset button (small hole on side, you'll feel a click) hold it for 5 seconds. THEN hold down the power on button for over 10 secs (keep holding while it shows version number) and it will perform a factory reset. You will possibly lose any settings and addresses, but better that than a locked GPS unit.
Oct 10, 2008 | Navigon 2110 Series Satellie GPS Receiver
Open Questions:
I cannot start my NAVIGON GPS 3310 - Europe 40 pays: I get a message that tells." NAVIGON software cannot be started. Please reset you device. Contact the Navigon Service center if the problem persists: The problem does persists in spite of the numerous reset I did. I also tried to restore the factory settings, it does not change anything. When I connect the GPS to establish a conection between the GPS and the computer, for example save the content of the GPS in the computer I get a message which tells me No device was detected (CG2001) No Navigon device was detected. They suggest to unplug and plug again the GPS to the computer, I did so and get the little music which tells me that I am plugging/unplugging a USB device, and I see NAVIGON in Windows Explorer. But still I get the same message that No device was detected: Ths GPS was delivered with all data in the internal memory and none on the SD card (It was working with no SD card). It seems to me that all data in the GPS disapeared, and unfortunately I did not save the data when I I had a chance. Do you think you can help me? I was thinking that perhaps I could install a SD card will all data, meaning Navigon program and maps, and may be it would work. What do you think about that? The problem would be to find this data, The Navigon progam in particular. As for the maps they can be bought, but on a DVD as far as I know, and what if the computer does not recognise the GPS? So, as you see I am puzzeld and seriously consideing buyin a Garmin instead,. I,ve heard that they are more reliable.
Feb 28, 2017 | Navigon 2090S Car GPS Receiver
Navigon 2090S Car GPS Receiver Logo
452 people viewed this question
Top Navigon GPS Experts
perdue40
Are you a Navigon GPS Expert? Answer questions, earn points and help others
