Question about Maytag 24 in. MDB6100A Built-in Dishwasher
Flashing light and water in bottom
My Maytag MDB6160AWW stopped working 3 days ago. The RINSE ONLY light and the CLEAN light are flashing and nothing I do will change that or turn it on or anything. I even cut the electricity at the circuit breaker, left it off about 10 seconds, and turned it back on, with no change.
It's probably not coincidental that there was an inch of water in the bottom. I suctioned that out though and no change.
I also looked through the tubing and there doesn't appear to be any buildup or crud.
  • 18 Answers
SOURCE: I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Posted on Feb 04, 2007
SOURCE: "3 second" light flashing
The 3 second flashing light is a lock that locks out all other functions. To disable, depress the 3 second light for 3 seconds and all the functions will be released. This feature is to use to keep little kids from starting the appliance.
Posted on Jul 04, 2007
  • 3 Answers
SOURCE: lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Posted on Mar 30, 2008
Part Number: 99002254 you may need this part depending on model no
SWTCH-DOOR 99002254.jpg View Larger Image
Posted on Jun 02, 2008
SOURCE: Maytag Dishwasher
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Posted on Sep 21, 2008
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
MDB6160AWW - flashing lights after hitting the normal cycle: Clean and Heated Dry buttons flash. What is this code telling me? Keith
Hi
These blinking lights indicates an issue with heater circuit, door switch or wash pump. Please reset the power to the dishwasher and after, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Jan 18, 2011 | Maytag 24 in. MDB6100A Built-in Dishwasher
I don't beleive my sprayer arm is working on the bottom of DW
The problem is hard water and your softener must not be taken it all out. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 05, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
Blinking Clean and Rinse lights on Maytag PD8460AWN
My Maytag PDB4600AWN quit working with a flashing CLEAN light and RINSE only button. I took off the bottom panel and took out the electrical diagram.
I ran the diag test, tried pulling power, and a series of other ideas just to see if the error always pointed to the same thing and it did. It's the motor pump. My Maytag is 10 years old. Not sure what yhe life span of such things are. My Mom had a Kenore dishwasher that ran 17 years. Don't think that happens anymore. I bought my Maytag laundry washer and dryer at the same time as my dishwasher and they have trouble now also. Guess those TV commercials were a little on the iffy side of truth. Hee heeeeeeeeeeeee. :)
I think I'll just buy a new dishwasher. The repair guys bill will be high enough that I may as well
Cheers
Feb 06, 2009 | Kenmore Dishwashers
Won't work
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Aug 16, 2008 | Maytag MAH2400A Front Load Washer
Maytag Dishwasher Quiet Series 200
The 3 symbol on the face control panel light is on and starts flashing anytime you push any other button, and is full of water in the bottom of it. My wife says she stopped the washing cycle a couple of days ago but now it wont start back up.
This is a Maytag series 200
Mar 15, 2008 | Dishwashers
Flashing F-9 and beeping
Check that the filter is not clogged.
Disconnect AC FIRST........******
open the bottom access panel , (3 screws on bottom lip)
remove panel
open the large filter in the center, very apparent
be prepared for water, have mops ,buckets rags, pans ready.
clean and remove all debris.
see if anything when up into the small pump area too.
spin the pump propeller and make sure it spins free.
if you find nothing but water then the main large hose in the center may be clogged, that will take some work to disengage the clips and to reinstall.
Jan 26, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Jan 27, 2007 | Maytag MDB9600A Jetclean II Built-in...
Maytag 24 in. MDB6100A Built-in Dishwasher Logo
76 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
