Question about Danby DAC8007EE Wall/Window Air Conditioner
Where can i get the freon - Danby DAC8007EE Wall/Window Air Conditioner
    Genius:
  • 1,400 Answers
Hello
You cant,federal epa laws prohibits the sale or use of freon unless you are cfc certified.
Posted on May 29, 2010
How do i find blockage in air conditioner hoses after freon added and gauges dont register that there is freon
Did you try to add freon because is was no longer blowing cold air? Who added the freon local repair shop or A/C specialist?
Oct 06, 2014 | 2004 Chevrolet Malibu
Air conditioner electric circuit
Try disconnecting battery for two minutes to reset the system. Then start the car and check a/c operation.
Dec 22, 2013 | Oldsmobile Cars & Trucks
How can I bleed freon on my 2007 Impala LTZ
there's no way to legally take Freon out without a machine but if you push down on the valve with something some Freon will come out
Jul 01, 2013 | Cars & Trucks
My air conditioner works but does not cool . i have added freon the last two years and fixed the problem ,did the same thing this year but did not help .
When self adding freon after it leaks out you get air trapped in the system. After adding freon a couple of times the air expands not leaving room for the needed freon. To continue adding freon with air tapped will knock the compressor out pretty quickly, there's not enough room for both & the air is keeping the freon from being able to cool properly give the false indication of being low on freon. The freon you are adding has the dye added to assist in finding the leak since freon does not evaporate nor dissipate it its being leaked out. A black light will assist locating the leak. The best thing is to have the unit checked & serviced by a mechanic...he'll charge about $ 150.00 to check for leaks, remove the old freon...his machine will tell him how much air its trapped in the system by how little freon is removed. For the service fee he will replace valves & gaskets, where needed, correcting most leaks. After sucking the system down & recharging the problem should be corrected.
Jul 19, 2011 | 2001 Dodge Ram 2500 Truck
Trying to evaporate old freon and install new freon on 05 neon
Against Ferderal Laws to discharge refrigerent into
the atmosphere
That is the may cause of holes up there
You can not install new freon without leak testing.
repairing leaks & pulling a vacuum with a pump
& knowing the theory of A/C Systems
Need a shop that is trained & has the proper equip
Jun 12, 2011 | 2005 Dodge Neon
I want to know wat kind of ac freon my expadition
It uses the 134 A which is a replacement for freon, but is not freon. It is supposed to be more environmentally friendly, but is not as efficient when it comes to cooling as the old Freon 12. It is illegal in the US for you to have freon in your possession, only authorized shops are allowed to have it and install it.
Jul 25, 2010 | 2003 Ford Expedition
How much freon goes in a 1991 honda civic?
Your Honda takes R12 freon, R12 freon is no longer sold, if your car has not been retro fitted to 134a freon, you will have to buy a retro fit kit, so you can install 134a freon, If it has been or after retro fitted, total freon 1.5 lbs 134a freon.
Jul 09, 2010 | 1991 Honda Civic
Adding freon to the sistem
hello,seems your low side have pressure than your freon can,usual procedure in filling the freon,first vacuum the system with low and high hose,charge the freon on low side with correct amount,if you want, try to top up in high side,ty
Apr 22, 2009 | 2001 Mercedes-Benz E-Class
Low freon and low pressure cutout open preventing clutch from coming on
Before you add Freon, you should check the leaking first, if the Freon is too low, sometimes cause this kind problems. use color Freon test it and tight the leaking area and then add Freon, you can not do it yourself because the law say.
Jul 27, 2008 | Chevrolet Lumina Cars & Trucks
Danby DAC8007EE Wall/Window Air Conditioner Logo
76 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
