Question about Insignia 37" LCD Flat-Panel HDTV
Why did the red and green leave. We no longer can get the color red or green
  • 10,594 Answers
What is model and brand of your tv that has blue picture?
How old is this tv and when it started that problem?
Does it happen on all inputs or with any particular video input like dvd player etc?
Let me know above info to diagnose problem.
Thanks.
Posted on May 29, 2010
  • 8 more comments
  • djdooley1327 May 29, 2010
    We have bright yellow and blue , the grass is brown and we have no red
    The TV is one year old
    Insignia NS-LCD32-09
  • Shahid Electronics
    Shahid Electronics May 29, 2010
    OK, unplug tv from wall socket for minute to get it reset, replug back in and turn it On and check its picture.
    Still no good picture then go to tv menu and reset tv to factory default settings in setting menu to solve picture issue.
    Thanks.
    unplugged per your instructions. Went to Preset everything is GREEN!!!
    Does it happen in all inputs like cable, dvd etc?
  • djdooley1327 May 30, 2010
    Yes, We have it hooled to the cable box, we triied a dvd and also
    By the way we moved the tv from one spot to another today and this happened
    Shahid Electronics May 30, 2010
    It sounds lose connector in circuit board, specially LVDS cable connector that can cause such problem.
    oops-hooked up to the cable box
    tried
    We have an HD cable box from comcast. we movedit also
    What is LVDS cable connecter?
    Is it costly to have the circut board in the TV tweeked/fixed and where do you take these TV's in Michigan? Any help will be appreciated
    LVDS cable carrrys video data towards lcd panel from main video processor to present picture in lcd screen.
    Please click on Fixya Repair Directory and put your zip code on letf side Location search bar to locat nearest tv repair shop in your area to get this tv fixed.
    Thanks.
    Thank you
The picture screen is green and red.
It sounds like one of the three color guns has failed and based on the fact that you have red and green that would leave the blue gun as the culprit.
Feb 16, 2016 | Mitsubishi WS-65807 65" Rear Projection...
What is convergence IC problem
Convergence has to do with how different colors are displayed on a screen or monitor - typically the rear projection and some other types. When colors are overlapping to create unexpected combinations, or leave gaps between areas where overlapping is expected that results in a shifted red, green or blue image strip or edge - that is an indication of a convergence issue. They can look like this in severe cases:
Colors will drift, so manufacturers often include a utility to help you nudge the colors back in the right place. Most times this utility is buried in the Set Up Menu and when activated, produces a screen like this:
You will need to adjust the red, green and blue colors for each cross so that only a white cross is displayed. Keep red, green and blue fringing to a minimum. When you're done, the screen should look black and white, symmetrical and straight - like this:
Problems arise when you are no longer able to coax the utility to give you these crisp, B&W results with no red, blue or green ghosting. This is often due to a failing convergence integrated circuit ("Convergence IC"). Many times, replacing it will solve the problem, but other times it can be the result of failing components either ahead or after this IC. If you're attempting to replace this IC, please make sure the TV or monitor has been *unplugged* for 24 hours or more to allow the dangerously high voltages to dissipate.
Sep 08, 2014 | Hitachi 50VS810 50" Rear Projection HDTV
What is the purpose of an R2 filter?
Each filter intensifies its color and darkens others, especially the color opposite on the color wheel. They're not of much use in color photography, unless you want weird color casts, but they come into their own in black&white photography.
For example, a red filter intensifies red and darkens blue. It can make a sky look almost black, making clouds pop out. Similarly it can darken foliage. A green filter on the other hand will brighten foliage.
If your camera can take black&white photos, try taking pictures of a red rose with green leaves with and without the filters. With one combination the rose and the leaves will be the same shade. With a red filter the rose will be bright against the dark leaves. With a green filter you'll get a dark rose with bright leaves.
With digital photography you can achieve the same effect in postprocessing, but some times its easier to get the result in camera.
Apr 28, 2012 | Quantaray 55mm Red R2 Lens Filter
Hi,,i only see two colors on my tv screen,blue and white,,waht should i do..please help me
there are three primary colors from your TV's chroma circuit, red green and blue..
you'll notice it when you open your back cover of your television set, the wire colored red, green and blue.. you better leave it to the expert technician to prevent severe damage
Sep 15, 2011 | Sharp 27F543 TV
I put the 5fr red velvet hair color in my sisters hair with a red intensifer and its washing out can you tell me why
you need to leave it on longer. Red fades quickly try using joico cuticle seal after coloring . after coloring try to just rinse out color, don't use shampoo spray the cuticle sealer on the hair and don't wash hair for 2 days..it should keep it from fading so quickly.
Jul 08, 2011 | Joico VeroColor Permanent Hair Color 5FR...
When the display is dark i get red and green arcs on the screen
Color arching is an easy fix. You need a screw driver and some patience removing the front panel. You will be looking for a box with 3 screws on it. This is the color gun. THe scews are Red, Green and Blue color only, however, they usually don't indicate the color on them. Turn the screw (Slighlty) till the arching is no longer there. You have to do this with the tv on.. LOL
Best Regards and Semper Fi....
Aug 06, 2010 | Sony KP-65WS500 65" Rear Projection...
Projection is messing up. Too much red and blue color.
A CRT projector requires Convergence and Color balance adjustments from time to time. These settings can drift. What you are seeing is a lack of Green color intensity. Do you see some pink in the 'whites'?
The Green CRT surface also burns off faster than the Red and Blue leaving behind the same appearance. As long as your Green CRT is not too burned by gaming or watching Golf and football, a local tv tech will be able to dial it in for you.
Jan 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
Color Problem
prob bad crt. blue gun weak. new tv is answer.
Nov 17, 2008 | Zenith B25A74R 25" TV
No Red element is picture
It is on the end of the picture tube. Resolder and reseat the socket on the board. Good Luck
Apr 14, 2008 | Jensen Q2749J 27" TV
Insignia 37" LCD Flat-Panel HDTV Logo
50 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
