Question about Singer Featherweight 132Q Mechanical Sewing Machine
Won't stop zigzagging
My machine seems to only want to zig zag and not straight stitch
    Problem Solver:
  • 8 Answers
At some time your machine was probably stored in the zigzag position. When left set this way they will lock themselves in. To fix open the top of the machine & using sewing machine oil (not 3 in 1 as that will lock up the machine) oil every part that moves or looks like it should move. After letting it set a while you should be able to work it back to straight stitch setting. I have had some stuck so bad this way I've had to use T-fal to break them loose, but if you do be sure to clean it out good and oil with machine oil afterwards.
Posted on May 30, 2010
HOW DO YOU CHANGE THE STITCHING FROM STRAIGHT TO ZIGZAG
Check that your sewing machine is even capable of zig-zag. Some machines are straight-stitch only.
Consult your owner's manual.
If your machine can do zig-zag, somewhere there is a dial or setting called "stitch width" that will determine how wide the zig-zag will be.
May 21, 2016 | Sewing Machines
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Machine not picking up a zig zag stitch
it's possible that the cam that makes the zigzag stitch could be worn or damaged, it would probably be a good idea to have the machine checked.
Feb 23, 2014 | Brother XL-5700 Mechanical Sewing Machine
Morse 4300 fotomatic won't zigzag
if all the dial are set correctly for the zig zag, and the machine
still won't do the zig zag stitch then it's possible that there is a
gear or cam inside the machine that is worn or damaged.
a sewing machine shop can tell you for sure.
Nov 05, 2012 | Sewing Machines
Someone gave me a singer 403. I put in the zig zag attchment but it still sews only straight. What am I not doing??
Of course, you have to push the zig zag adjusment lever from the 1 position to one of the zig zag positions, 2-5. Also, the zig zag disc must be inserted. Take of the top of the machine (two screws to loosen the attachment and lift off the top), and you can see a steel connecting piece called the pitman and it should move back and forth when zig zag is engaged. If it isn't, maybe something is gummed up as has been suggested.
Jul 20, 2012 | Singer Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Zig Zag wheel not working
Need to know what type of machine, but most likely the connecting arm for the zigzag width to the needlebar is gunked up somewhere. Clean the joints of it and oil liberally with lots of exersizing it.
Mar 17, 2010 | Sewing Machines
Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Nov 05, 2009 | Kenmore Sewing Machines
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Singer Featherweight 132Q Mechanical Sewing Machine Logo
96 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
