Question about Cameras
Ihave a Pentax *ist DS camera with which I use a SanDisk Ultra II memory card. I have recently bought a SanDisk Extreme III Secure Digital Card (SDHC) CLASS 6 Micromate card which does not work in the camera, please coud you advise if it is possible to use both these cards in the camera? Many thanks. Jill Poppleton
    Novelist:
    Champion:
  • 214 Answers
According to this site
http://www.sandisk.com/Assets/File/pdf/SDHC%20Compatibility_2007-02-15.pdf
your camera does not support the SDHC cards.
Posted on Apr 08, 2008
SOURCE:
What type of SD card does the digital camcorder recommend? Will a 2GB DC card work?
You need a faster SD card for camcorders usually - checkout Sandisk Ultra II series. or Sandisk Extreme III
Dec 23, 2009 | Jazz DV-179 Digital Camera
Sandisk extreme iii 4gb problems??
May be a problem or trash in the reader slot.
Try the card in another device connected by usb, ie, put it in a camera then connect it to the computer.
Dec 17, 2009 | SanDisk Extreme III 4GB Secure Digital...
I have a Pentax Optio A20. I currently user an Sandisc Ultra II 1.0 GB card. I can't find those cards anymore. I'm not sure if the camera will support a SanDisk 4GB UltraII SDHC Card or a SanDisk 2GB...
It will take a 2 GB card, I am using one now.
I can't tell you about a 4GB card, but that's a LOT of storage, so you probably don't really need a 4GB card anyhow???
Dec 12, 2009 | Pentax Optio A20 Digital Camera
What Memory Cards will work?
Hi,,
Unfortunately, the Pentax K100D is not SDHC compatible, which means that the camera can be equipped with a maximum memory capacity of 2GB.
It is also advisable to choose a fast version of the Secure Digital memory card, such as Ultra II or Extreme III by SanDisk. I would recommend using a memory card of at least 512MB, or even 1GB if you can.
Hope this info helps
Dec 03, 2009 | Pentax K100D Digital Camera
Sandisk extreme III says CF full when the card is empty
If you've tried the usual fixes like reformatting the card and trying it out in other cameras, then there is nothing more you can do to fix this.
Fortunately, Sandisk are very good at replacing faulty memory cards provided they've not suffered physical damage. Just contact the company to find out how to exchange your CF card.
Nov 06, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
I have Sandisk Extreme III 4GB memory card why after i shooting photo the file is cannot read?
Make sure your camera is compatible with a 4GB flash card. Some only take 1 or 2 GB cards. If that isn't the issue, format your card inside the camera with the camera's format utility.
Oct 08, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Memory card locked
On your SD card, there is a small tab near the top (similar to floppy a disks), just switch that the other way it should fix that lock error.
Jun 11, 2009 | SanDisk Ultra II 2GB Secure Digital Memory...
Why is my *ist DS eating my SD cards?!
I've used Sandisk Ultra II 512M cards, a PQI 1G and a Transcend 1G card (all high speed rated) in the *istDS. I've done about 1500 exposures now, many RAW, and have done several rounds of upload to my computer. No problems at all. These same cards work flawlessly in a Panasonic FZ10 as well. Either you have had a bit of bad luck, two defective SD cards in a row, or have a *istDS with a stuck or bad memory card controller. Try using the Reset command in the Set Up Menu, see if that helps. BTW, always format SD cards with the camera once before you start using them.
Sep 13, 2005 | Pentax *ist DS Digital Camera
SD card for *ist DL
Interesting... I've heard that (for the DS at least) the camera isn't capable of using more than about 60X, but of course your downloads can be faster if you use a reader. At 2gb, this might give you some benefit, but a full transfer of 1gb on a garden variety sandisk only takes a few minutes.
Sep 08, 2005 | Pentax *ist DL Digital Camera
Cameras Logo
99 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
