Question about Vivitar DVR 850W Flash Media Camcorder
There is a large red f on my screen
I was just taking a video and a large, red, ''F'' in a box showed up in my screen. Any idea why or how to prevent it?
  • 4,924 Answers
It supposed to be an E ..but many devices show just an F ..and it means error..this can be caused from many things ..and without a number code near Im not sure ...but it is either from power...or from a unfit format that can not be read..or a lack of space ...so try to reset it ..than to clean its internal memory by downloading it and format ...and check the power to be ok ..the battery well charged..and try again ...
Also see the troubleshooting in the manual if it says anything about the Error shown on the screen and how to reset it ..
Posted on May 29, 2010
  • deggers06 Aug 30, 2010
    The user manual states that when the letter "F" shows up on the screen, that the memory is full.
I cannont get my lg m4201ce tv to connect to my dish network box!!! It isn't showing anything on the screen and I can't change the channel!!! What's the deal???
Take a patchcord with 3 rca conductors and connect one end to video and audio out on your dish box.They are color coded(red,White and yellow) Connect other end to your video and audio in on your tv.Go to menu on tv and find "video"1,2,or 3.Set it to whatever one you chose.
Sep 25, 2010 | Televison & Video
My tv no longer shows the color red. No idea what
I have sound but my tv screen is black. Sometimes when I turn on the tv I get a picture but after 15 minutes or so the screen goes black again.
It's a 4 year old LCD.
Nov 23, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Red ring of death and freezing
How many segments show in the RROD? It may be that the unit is overheating. You can open the case and remove the shielding until the heat sink (large aluminum fins) is visible. The outer case opens much like a clamshell once the case screws and gray plastic end pieces are removed. There is one not-so-obvious case screw through the middle from the bottom which makes the inner components hard to access. Take your time and do not force anything. If the heat sink is dusty, blow it off with compressed air or dust-off and reassemble. This will probably stop the freezing. It is advisable to keep the unit is a cool, dust and smoke-free environment if possible to prevent this problem in the future.
Nov 17, 2009 | Microsoft Xbox 360 Console
Hello, I've got red wavy lines across screen
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 22, 2009 | Samsung HCM5525W 55" Rear Projection...
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
A red image pops up when I take a pic
I chose the DMC-TZ3A since I didn't know what the letter was at the end of the model number for your particular camera. If this is the camera
Here is a link to the manual
If not
Here is link to the Lumix series cameras
Pg 25 indicates that flashing red in the upper right corner is the battery needing to be recharged. If the battery was recently recharge and its turning red on the screen, it could be that the battery isn't holding a charge and may need to be replaced.
I didn't see any other error messages on the screen indicating that icon unless b,c, or d models have a different error message in that area of the screen.
Jul 11, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Black and gray boxs show up on my screen
try to hook up signal diffrent instead of rf go video, or s video
i would try video if you have original remote see what happens
Jun 13, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Erasure prevention
Sounds like a CCD sensor problem ( no image in capture mode but ok in playback ). Replace CCD block and will work fine.
Sep 06, 2007 | Panasonic NV-DS65 Mini DV Digital...
When a black box appears on the screen it means that your closed captions are on and set to TEXT. When the closed captions are set to CC1, it puts the words on the screen and when set to TEXT it puts a black box in the center of the screen. Go into the set's menu, navigate to the closed captions page and set the captions to OFF.
Aug 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Vivitar DVR 850W Flash Media Camcorder Logo
200 people viewed this question
Top Vivitar Video Cameras Experts
Joseph Wright
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
