Question about One For All URC-3021 Remote Control
Steps to program remote to t.v - One For All URC-3021 Remote Control
Programming key fobs for a 2007 Silverado
If Your 2007-2010 Silverado Has a VIC - Vehicle Information Center Step 1: Sit in the vehicle with all the doors closed and unlocked. Start your Silverado and leave it in Park.
Step 2: Press and hold the Vehicle Information button, marked by an image of a car and the letter "i", until the display reads "Press V to Relearn Remote Key".
Step 3: Press the Set/Reset button until "Remote Key Learning Active" appears.
Step 4: Simultaneously press and hold the Lock and Unlock buttons for 15 seconds. A chime will sound indicating the remote has been successfully programmed.
Step 5: Program additional remotes by repeating Step 4 for each fob.
Step 6: Exit programming mode by turning off the vehicle and removing the key.
Step 7: Test your remote(s).
If Your 2007-2010 Silverado Doesn't Have a VIC - Vehicle Information System Step 1: Sit in the vehicle with all the doors closed and unlocked. Turn the key to Accessory Power position.
Step 2: Press the trip odometer meter reset stem repeatedly until you see "Relearn Remote Key".
Step 3: Press and hold the trip odometer meter stem for three seconds. The display will read "Key Learning Active".
Nov 02, 2016 | Chevrolet Silverado Cars & Trucks
Unable to program new sender to receiver. The receiver should flash three time but the diode lights up a fourth time for a period and the sender is not programmed.
This is the procedure for remote to remote programming, try this!
Step 1. Using a old programmed remote that is already up and running.
Step 2. Press the button for five seconds of the new remote you want to activate and release.
Step 3. Press slowly three times the old remote button.
Step 4. Press the button again slowly and release control.
Step 5. Verify that the new remote works.
Nov 01, 2014 | Building Materials
How do I program the oversized brookstone tv remote control to my new Samsung television?
Step 1: Turn on the device you wish to program (TV, VCR, DVD) manually
Step 2: Press and hold the button for the device you wish to program for more than 3 seconds, the red LED will illuminate indicating that the remote is ready to accept a three digit code.
Step 3: Enter the first three digit code listed below within 30 seconds, the red LED will shut off indicating that the remote is programmed.
Step 4: Press the ON/OFF button to verify correct code entry. If the device shuts off then no further programming is required.
Step 6: If the device does not respond, repeat steps 2-5 using a different three digit code.
Samsung - 043, 048, 054, 057, 062, 073, 074, 075, 078, 080, 089, 092, 097, 104, 112, 117, 118, 125, 131, 139.
Jan 13, 2011 | Brookstone 538744 Remote Control
What are the codes for a 153639?
wtlc50
I have provided a link for instructions on how to program your remote. You weren't clear if you were having problems with the remote working on your receiver or your TV. Step 5 is for programming the remote to your receiver, with step 6 programming the remote to your TV. I have also provided a link with the codes for the different TV manufacturers.
Readdress remote to receiver (step 5) / program to TV (step 6):
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Ray Calo
DISH Network
Aug 27, 2010 | DISH Network IR Remote Control
Need remote code for symphonic tv. Have living solutions giant remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Jun 30, 2010 | Symphonic ST420FF 20" TV
I am not able to use the hand held lock/unlock now. The driver door lock tries to work, but it won't. If I push the lock down manually, it will lock all locks. What could be wrong?
Note:
Entering the programming mode cancels all learned keyless remotes, so none of the
previously programmed remotes will work. You must reprogram all of the keyless
remotes once you are in the programming mode. You must complete each step within 5 seconds of the previous step to keep the
system from exiting the programming mode.
1. Turn ignition switch to ON (II)
2. Press the LOCK or UNOCK button on one of the remotes. (An unprogrammed
remote can be used for this step.)
3. Turn ignition switch to LOCK (0)
4. Repeat steps 1, 2 and 3 two more times using the same keyless remote used
in step 2
5. Turn the ignition switch to ON (II)
6. Press the LOCK or UNLOCK button the same remote. Make sure the power door
locks cycle to confirm you are in programming mode.
7. Press the LOCK or UNLOCK button on each remote you want to program. Make
sure door locks cycle after you push each remote button to confirm system has
accepted the remote.
8. Turn the igniton switch to LOCK (0) to exit programming mode.
9. Test remote(s)
Mar 07, 2010 | 2002 Honda CR-V
Programming a remote
Sep 01, 2009 | Televison & Video
How to program the keyless entry for my 1996 Acura TL.
Hi, Stacie,
here's the instructions for a 97 TL - I hope they're the same.
Note:
none of the previously programmed remotes will work. You must reprogram
all of the keyless remotes once you are in the programming mode.
You must complete each step within 4 seconds of the previous step to keep
the system from exiting the programming mode. You must program remotes
within 10 seconds of each other
2. Within 4 seconds press the LOCK or UNOCK button on one of the remotes.
(An unprogrammed remote can be used for this step.)
3. Within 4 seconds turn ignition switch to LOCK (0) position
4. Within 4 seconds turn the ignition switch to ON (II)
5. Repeat steps 2, 3 and 4 two more times using the same keyless remote
used in step 2
6. Within 4 seconds press the LOCK or UNLOCK button on the same remote.
Make sure the power door locks cycle to confirm you are in programming
mode.
7. Within 10 seconds press the LOCK or UNLOCK button on same remote.
8. Within 10 seconds press the LOCK or UNLOCK button on all other
remotes you want to program. Make sure door locks cycle after you push
each remote button to confirm system has accepted the remote.
9. Turn the igniton switch to LOCK (0) to exit programming mode.
10. Test remote(s)
Hope this helps :)
John
Mar 26, 2009 | 1998 Acura TL
Keyless remote
Note:
all of the keyless remotes once you are in the programming mode. You must complete each step within 4 seconds of the previous step to keep
used in step 2
mode.
10. Test remote(s)
Dec 24, 2008 | 1998 Acura TL
Program my remot
http://www.directv.com/learn/pdf/System_Manuals/Hughes/HNS_SD_HBH.pdf
remote programming instrutions start on page 49 of the PDF file and give step by step instructions for programming your remote
Feb 26, 2008 | Hughes HRMC11 Remote Control
One For All URC-3021 Remote Control Logo
43 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
