Question about Samsung WF337AA Front Load Washer
Soap dispenser fills with water
Samsung front loader. After every wash load the little compartment you pull in and out to put in detergent, softener and bleach well,,the side you add the softner to fills up with water. Everything is in place as before the problem started.
  • 27 Answers
SOURCE: detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Posted on Jun 26, 2007
the dr
  • 447 Answers
SOURCE: Maytag Washer, Model # MAH4000AWW (Neptune - front loader) appr. 4 yrs old
Hi john, There is a blue cover that i am suspecting you are missing from the softener/bleach dispenser. It fits over the two tubes in the dispenser and it siphons the water out. It is part number 22002266. Also the machine has a water filled balance ring. It is normal to hear sounds of water when the tub is turned. If you can see water in the spinner its a different story.
Posted on Nov 24, 2007
SOURCE: Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Posted on Feb 05, 2008
jsrock516
  • 5911 Answers
SOURCE: Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Posted on Feb 11, 2008
murdozzz2
  • 75 Answers
SOURCE: Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Posted on Feb 29, 2008
Why does My Samsung VRT front loader leave the soap dispenser full of water at the end of the wash cycle. I have to empty it in order to add detergent for the next wash cycle.
there are 2 components to the soap dispenser, 1 using liquid soap has a little tub that you dispense soap into and 2nd you remove the tub when using powder soap. I assume that you are talking about the little tub is filled with water. How this works is by adding water to the tub the level rises and siphoning empties the little tub. If any water remains it is due to water being added after the little tub has already emptied. That is not a big issue and will happen. Just empty the water or add some water to start the syphon process.
Oct 11, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Water leaks out of the soap dispenser of my kenmore elite front loader and all the soap or bleach us not out
The 1st thing to try is to take out the dispenser ,there is a little piece that you will push down and then pull the entire assembly out, rinse it out with hot water ,most likely there is a build up in the dispenser,there after use only powder detergent, and no more then 1 tbs ,and any other stuff IE bleach ,fabric softener,use 1/2 the amount and dilute it with water.
Jul 20, 2014 | Kenmore Elite 45986 Front Load Washer
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Water &detergent are standing in the soap dispenser. I would like to remove the entire tray that holds detergent,bleach,softener, but have lost my manual and don't remember how to remove it.I have an...
Most washing machines that I am familiar with have one of two possibilities of getting the soap dispenser out.
1. Look for a "knob" or something like when you put your hand (palm up) inside the dispenser, if you hit a "knob" push it and pull the dispenser out at the same time.
2. Pull the dispenser slowly out of its "home".
When the dispenser is out and wash in warm water, under the tap.
Good luck
Dec 27, 2010 | Washing Machines
My problem is that the fabric softener doesn't dispense on my GE front loader WCVH6260 washer. (I rarely use the bleach compartment, so I don't really know if that is working.) The detergent part dispenses...
I know this may sound silly, but I have seen this problem solved on many occasions by cleaning the filter screen(s) in your cold water supply hose!
This is because the softener dispenser must fill with cold water (on top of your softener liquid) in order to start the siphoning off of the softener. If the cold water supply is restricted, the dispenser will not receive enough water begin the siphon effect.
Now before you tear things apart, try this test...
Begin a wash cycle by filling with HOT water, and observe (listen to) how fast the tub is filling for a few seconds... Now change the wash temperature to COLD, and notice the difference in water flow. If you detect a noticeable decrease in water flow... Clean the cold water hose screens!
How? Unplug the unit! Turn the cold water valve off, and remove the hose. (If you did the test above, you will easily feel which hose is the cold one.) Use a small brush and a squirt bottle to clear the screen inside the inlet to the washer, and also check the end of the hose where it attaches to the plumbing... some guys put a screen at both ends of the hose. Put it back together, turn the water on and CHECK for leaks. All OK? Plug 'er in and wash a load, and pat yourself on the back for saving yourself the price of a service call!
Hope this helps...
Bondo
Oct 29, 2009 | GE Energy Star WCVH6260F Front Load Washer
Bosch Washing Machine Softener Tray not emptying
You need to replace the cold water inlet valve. If the machine is older than one year it may be clogged on the side that moderates the cold water to the bleach and softener compartment. Replacing the valve fixed the problem. During the cycle when the softener dispenser fills it should fill quickly and no or little water should be seen in the soap dispenser area. If a lot of water goes into the soap dispense and little into the softener area the valve is clogged.
Feb 15, 2009 | Bosch Logixx WFT 2806 Front Load...
Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
Jan 10, 2009 | Kenmore 42822 Front Load Washer
Odors on the clothes after washing in Maytag front loader
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
Oct 23, 2008 | Maytag EPIC MFW9700S Front Load Washer
Samsung WF337AA Front Load Washer Logo
409 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
