Held the (0)down,nothing,then (#)nothing,then (*)nothing?What gives me the meter reading on a AL1655?
  • mbbigmike May 30, 2010
    If you read my question,you will see that I have already,more than once,held the (0)& other digits down,for over 15sec.,each,and nothing begins to happen?How about getting into service mode?Any help?
  • 1,326 Answers
The total count will flash on the display in 3 digits sets. You need to have the copier ON & hold the "0" botton for a few seconds & it will flash the total count
Posted on May 30, 2010
Electrical. All lights off when key is on.
check inside the ignition switch is clean and makes contact in the on position etc ! may need a new one !
Apr 28, 2014 | 1998 Suzuki GSF 1200 Bandit S
How do you test a throttle poston sensor
Back probe wire harness with hat pin & use your
volt meter to read both sides, as you open & close
the throttle plate (Component Testing)
Can look at it with scan tool also
Should have PCM/ECU 5V on one wire,two
sensors wires & a ground
You connect your black meter lead to a
good ground
You probe each wire one at a time
Have 5V on computer voltage
Have 0 to 5 one one sensor
Have 5 to 0 on other sensor
Nothing on gorund
Jul 01, 2013 | Cars & Trucks
Icom IC-M34 transmit correct but do not receive if sql is above 0
Sound like a speaker problem, dosconnect the speaker and check it with a meter, it should read 8 ohm. Good luck.
Mar 13, 2011 | ICOM Informatique Floating Hand Held Vhf...
Power meter on my dx-979 barely moves off of 0 when transmitting the swr meter also hovers around 1.0 no matter what channel...not used to seeing such low swr readings and almost nothing on the power...
I would check the radio with an external meter to see if it is the transmitter or the Meter in the radio. If it is the meter in the radio it could have a bad detection Diode or just oout of adjustment or even a bad calibration pot. other wise start looking to fix your transmitter like finals or other similar problem.
May 13, 2010 | Galaxy Radios DX-979 40-Channels Base CB...
Power meter on my dx-979 barely moves off of 0 when transmitting, the swr meter also hovers around 1.0 no matter what channel...not used to seeing such low swr readings and almost nothing on the power...
Well,some meters are set different than others,to see what is going on,you need a good WATT-SWR meter,but that is not a bad reading of SWR, you can get one at Radio Shack. You can not go by the meter that is on the radio,it,s probably not set right. hope this helps..
Mar 21, 2010 | Galaxy Radios DX-979 40-Channels Base CB...
How do you clear the service light on a S60 T5 2003. Please can you help.
Ensure all doors are closed.Turn ignition key to position 1.Press and hold reset button on a dashboard left hand side down/instrument panel/.Immediately turn ign.key to position 2.Keep reset button depresed until trip meter is reset to 0. NOTE:IF trip meter has already been reset.Hold reset button for 10-14 secondsuntil previous trip meter reading is shown.Press and hold reset button until trip meter is reset to 0 ;;;; Release a button within 4 secondsThere will be an audible signal When reset complete.
Nov 28, 2009 | Volvo S60 Cars & Trucks
Meter reading
2 ways to check the meter.
press the user tools button on the op panel. on the screen press counter. you can either view the counter on the screen, or press print counter, and it will give you a hard copy.
the 2nd way is to look behind the front cover, probably behind a piece of tape, on the right side, about half way down.
Nov 20, 2008 | Lanier 1205 Copier
Post oil change set up number on odometer back to 00
http://www.northamericanmotoring.com/forums/showthread.php?p=2157290
  • I filled up at a gas station for the 1st time yesterday, and I wanted to zero out my trip odometer so I could compare mpg by hand vs. the computer. But pressing the little 0,0 button did nothing. Pressed several times, then ended up holding it down too long which put the computer into diagnostics. Had to restart the car twice to get out of diagnostics, but after that, when I pressed the 0,0 button it reset the trip 'meter to zero like it is supposed to. Don't tell me, the software is made by Micro$oft and needs constant rebooting to function properly
  • I had this happen the first time I tried to reset. I held the button down waiting for it to go to zeros. It didn't. Then I held it down again for about 2 seconds and released and it reset. I've been doing the 2-second-then-release ever since and haven't had an issue.
  • i noticed initially that it took just a real quick depress for it to reset to 0. Every time i held longer than a half second it wouldn't reset. So just a quick jab should do it. Although if you keep having problems you may want to have your SA look at it.
I hope this answers your question.
raresolid
Aug 15, 2008 | 2002 Mini Cooper
Dryer turns on doesnt dry
Suspect heating element or thermal fuse. The heating element and fuse can be checked with an ohm meter. The reading should be 0-2 ohms on both devices. If heating element reads infinity (nothing) replace heating element and fuse. If the fuse reads infinity then replace the fuse.
Jan 06, 2008 | Maytag Performa PAV2200
41 people viewed this question
jasbo
jasbo
