Question about Garden
I have a sears garden tiller model 825 that starts and runs with choke. When choke is released it dies. Will not run unless choke is on.
  • 284 Answers
Fuel related issues
Do you have clean and fresh fuel?
Remove carb and bench it and dismantle and use carb. cleaner and air and find all orifices and clean and blow out dry reassemble and reinstall
Check for proper fuel delivery from fuel tank
if you have a fuel filter replace it
Posted on May 30, 2010
Testimonial: "Thank you very much, that was the problem, works fine now."
Yardman 3.5 cultivater starts but dies when choke is opened
Most likely the Carburetor is dirty and needs a good cleaning
Apr 30, 2015 | MTD PRODUCTS INC yardman"" garden tiller"
I have a troy bilt pony with a 6hp Tecumseh engine. It's difficult to start and when I get it started I have to leave the choke on or it will die. Also it doesn't run as it should. I drained the...
I recommend cleaning the filter with gasoline if its foam or replacing it if its paper. If this doesn't fix the problem you should remove the carburetor (in between the air filter box and the engine) and cleaning it thoroughly with carb cleaner from your local parts store.
Jun 17, 2011 | Troy-Bilt Pony Garden Tiller
Will run with full choke on but once i turn choke off it dies
The carb jets are clogged, it will have to be removed and soaked in carb cleaner. Sometimes that will not work either, and the carb will have to be replaced. Reason is, some of the carb passages are as fine as a human hair, so it's hard to get gunk and bad/dried gas deposits out.
You could try running something called Sea Foam (mixed in the gas)from Walmart through the tiller for a while, that MAY help somewhat.
May 23, 2010 | Mantis 2-Cycle Tiller
Engine dies out
Could be any of several problems. Since you indicate you just bought it, I'd suggest you return it. Troy-Bilt is pretty good at making customers happy and should repair or replace it right away.
Apr 09, 2010 | Troy-Bilt Pony Garden Tiller
Starting & getting the triller to run
If you leave the choke on 1 (wide open to air) does it engage? If you are careful, you can remove the Air Filter and try pulling it over. This will provide adequate Air to the Gas mix and allow the engine to run. ** MAKE SURE there is NO dirt near the filter housing or you will **** dirt into the carb. If this works, you have a speck of dirt in the carb....... THIS IS ONLY TO TEST, do not use this in the garden or you will **** in dirt.
May 31, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Tiller won't stay running
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
May 25, 2009 | Mtd Products Yard Machines 158CC Tiller
Cannot keep tiller running
Could a gas/oil mix been used by mistake. When you cleaned carb did you also clean dusty air filter?? Try leaveing off filter first and run. Are you sure you are in "choke position" when engines seems to be running ok,be sure to double check yourself here. If engine runs ecelleant in "choke" sounds like your in "Run" position and positioning is problem not performance.
Please rate. Thanks jj505
Mar 28, 2009 | Garden
Garden Logo
119 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
