Question about Car Audio & Video
I bought a wiring harness for my new cd player and i hooked it up and everything works except for the sound when you are using the cd player. when you are listening to the tuner or radio you hear everything. when you turn it to cd player it starts at the first track and goes all the way to the last track but you dont hear any sound.
  • spicymama021 May 29, 2010
    MORE ANSWERS
    NO SOUND FROM CAR CD PLAYER WHEN IT IS IN CD PLAYER MODE.
  • 2,427 Answers
Well I don't think that's your wiring ... If it was u would get no sound period.. Seeing as the cd skips to the last I will suggest u first try the player directly to the battery.. If that fails then the problem is deffinatley the player itself.. Hope u got warranty if not take it to a repair shop.. I'd bet the control ic. Is shot.. If it works directly to the battery then connect both red and yellow power wires to the battery and use it.. The player aint getting enough power..
Posted on May 29, 2010
  • 4,924 Answers
Look again at the back and see if it has something named CD out ..if does probably you need to make a connection between that out-put and the cd in ..or aux...or something like that ..or ...if it ha s something inserted try to remove ..probably it has an output to get the signal from cd only and it has a plug that mute it ..assuming that you got the signal out in a amplifying device ...If there isn't any of these and the unit is compact and has only one output stereo for all devices on it ..that it is a matter of settings ..or a loos contact at the signal from cd inside..
Assuming that it is a setting ..try to select the unit to be on cd from device selection and after that play the disk ..Just like in a payer with multifunction ....If it has a volume function or a equalizer...look careful to not be muted..
if any of these ain't working ..just look in the menu for settings reset ..and reset it to factory defaults and see if it does work after ..if not..it only can be a physical damage inside...probably the chip of the cd amplifier or a wire on the signal out ..from the cd board..
I am tring to put a cd player on my 2004 pontiac but it wont work the sterio wont turn on so i ran a wire from the fuse box on the side of the dore and it turn on but it has no sound wat am i doung wrong
hook up all your wires to the harness and the cd player EXCEPT the ground take and run both wires to the firewall or something metal instead of hooking them up together
Aug 30, 2011 | 2004 Pontiac Grand Am
Ive hooked up all the wires from the dash to the player, it turns on an everything works except the four stock speakers, everything seems to be hooked up correctly an everyonce in a while ull hear a...
A couple of things to think about. If the radio is new, then the speakers may be bad. If the radio is not new and purchased from someone else, the radio may be bad. You are making sure the volume is turned up right? You did use a harness when hooking the radio up right? That is something I strongly recommend.
Happy Hunting
Aug 13, 2011 | Car Audio & Video
I have a snoy cd player that i hooked up with a wiring harness i bought from the store. I lost my old one. They told me that the harness will work but after connecting everything the cd player won't work....
you may need the ilumination, pleas google your car model year and brand and the words "stereo wiring diagrams" and you'll may find the correct wire distribution of your car
Mar 23, 2011 | Sony CDX-GT510 CD Player
Speakers don't work
If you had followed the directions correctly and the old speakers worked as well, take the new radio back for exchange
Jan 18, 2010 | 1990 Nissan Maxima
Pioneer dehp3100ub.stock speakers wont work with unit?
If the vehicle has a premium sound package - you need to use the remote wire to turn on the factiry amplifier.
If you want to use the power from the radio for the speakers, you must buy and install a factory amplifier bypass harness.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 19, 2009 | Pioneer DEH-P3600 CD Player
Wont play throught speakers only crakles everything hooked right maybe needs new wireing harness but everything works but sound
If everything is hooked up correctly, you may need to wire harness. It could be a bad capacitor in the audio outputs. Easy to try wire harness first. Sometimes turning off and back on again works.
Jul 08, 2009 | Pyle PLDVIN7 Car DVD Player
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
Kenwood cd player to an 05 jeep - no sound
Hook the Blue/white striped wire to the power antena lead of the jeep (blue) to turn on the factory amp
Don
Apr 17, 2008 | Kenwood KDC-135 CD Player
Kenwood KDC-MP202 sound turns off when headlights are turned on
just solved a similar problem on my car i bought a Cd/dvd player for my 2000 concord lxi i hooked it up and hooked a rear-view camera and it worked perfect but wen i turned the headlights on the cd player shuts of so i disconnected the orenge wire that came out of my cd player from the orange on the aftermarket harness then grounded the ping wire (rear con wire) it worked fine but i couldn't see any footage from the camera for that i bought a long red power wire and hooked it to the red camera power wire that hooked from camera to reverse light and took the other end of the new wire i bought and hooked it to the orange wire that came out of the cd player now every thing works fine. you probably dont have the right power to run both cd and head lights thats why you need constant power to run both just hook up an extra wire between a positive wire to the orange dimmer wire its simple;
ground to ground (black)
12+ positive to 12+ positive (red)
and an extra wire (usually a red 18 guage wire bought mine at walmart) to the dimmer wire from the back of the cd player (orange) edit.gif
Mar 21, 2008 | Car Audio & Video
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
