Question about Whirlpool 24 in. GU940SCG Built-in Dishwasher
Dishwasher does not turn on
Checked breaker box and checked that the door was properly closed but no buttons light up
  • 523 Answers
With a volt meter check where the power hooks up
Posted on May 30, 2010
I start the dishwasher and it does nothing and lights do not turn on either
When your dishwasher won't start, it could be a problem with your electrical panel or the door might not be closing properly.
Check your household electrical panel for a tripped breaker or blown fuse. Also check to make sure the door latches closed properly.
For additional troubleshooting steps you can take and things you can do, read Dishwasher won't start for more suggestions. I hope this helps!
Aug 02, 2012 | Kenmore Dishwashers
Our Whirlpool dishwasher GU2500XTPT1 clean light blinks and will not go off. When we push the start/cancel button, it cycles through the 2 min cycle as the book says it should do and all lights go off. ...
That could be a problem with the control board, but before anything else try unplugging it from the wall, or turning the circuit breaker off. After turning it back on, see if it still happens. Also check to be sure the door is closing properly.
Oct 06, 2017 | Whirlpool 24" Bisque BuiltIn Dishwasher...
My dishwasher won't start.
FIRST MAKE SURE YOU HAVE POWER TO THE DISHWASHER. IF IT HAS A LIGHTED PANEL AND ITS LIGHTED UP, YOU HAVE POWER. IF NOT LIGHTED UP WHEN TURNED ON, THEN YOU HAVE A POWER LOSS PROBLEM WITH A FUSE OR BREAKER OUT TO THE SUPPLY WIRE TO THE DISHWASHER. CHECK YOUR ELECTRICAL FUSE BOX OR FUSE THAT SAYS DISHWASHER IN THE ELECTRICAL BOX IN YOUR HOUSE. RE-SET THE BREAKER OR CHANGE THE FUSE. IF IT STILL DOSE NOT START UP THEN YOU MAY HAVE AN ELECTRICAL CONNECTION UNDER THE DISHWASHER THAT IS NOT CORRECT OR NEEDS TO BE LOOKED AT BY AN ELECTRICIAN. DO NOT TRY TO CHECK THIS AREA UNLESS YOU HAVE THE FUSE OR BREAKER OFF. THEN LOOK TO SEE IF YOU HAVE A LOOSE CONNECTION. RE-TIGHTEN THE LOSE CONNECTION FOUND, TURN ON THE FUSE OR BREAKER AGAIN, AND SEE IF THE LIGHTED PANEL LIGHTS UP. IF IT STILL DOSE NOT START UP, THEN NEXT CHECK THE DOOR TO MAKE SURE IT IS CLOSING ALL THE WAY, THERE IS A SWITCHON THE DOOR THE SENCES FULL CLOSED AND WON'T START UP IF THE SWITCH IS NOT CLOSING. IF THIS DOES NOT FIX IT THEN YOU WILL NEED TO CALL YOUR LOCAL DISHWASHER FIX IT MAN. DISHWASHER HAS A PROBLEM HE MUST FIX.
Feb 20, 2011 | KitchenAid Dishwashers
I push start and my dishwaher wont turn on. I have checked the other buttons and they work. I also turned off my breaker to see if that will help and it still doesn't turn on,
either:
  1. something blocks the door from latching or closing. Check, if anything is stuck behind a dishrack. try reversing lower rack. check if the door aligns properly and dishwasher is installed correctly
  2. latch switch failed/latch mechanism is broken. Disconnect dishwasher from power. Disassemble door, check latch, check latch switches for continuity
  3. touch panel or control board (less likely) is failing. replace if none of the above is working for you.
Good luck,
Vlad
First Choice Appliance
Sep 14, 2010 | Magic Chef CDB1500AW 24 in Builtin...
WILL NOT START , COMPLETELY DEAD LIKE THERE IS NO ELECTRIC, WONDERING IF THERE IS A RESET BUTTON
Check the breaker switch in your fuse box in the basement. After that, make sure the door is properly closed, and engaged. Check also connections to dishwasher (with power off). If still no result, motor may be seized and its time to replace unit.
Oct 06, 2009 | Frigidaire Dishwashers
Same thing happened today
with the door open when your dishwasher was working normally Did the lights light up on the keypad? I am wondering because if the answer is the keypad only worked with the door closed .....you possibly have a bad door switch.
or it could be a blown fuse inside the dishwasher. are any lights on at all?
Jun 12, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
No power to Selections, Water Did Not Drain
When you remove the bottom panel cover, check the wiring connection inside the junction box on the right for a loose or shorted wire.
If that's ok, open up the console and check the continuity of the thermal fuse that's clipped to the control board. Chances are it needs to be replaced.
Mar 05, 2009 | Dishwashers
No electricity
I would check to ensure you have power to the dishwasher and that the door is closing/secure properly.
(i.e, Plugged-in properly under sink/back or washer, check for tripped circuit-breaker, and door latch is grabbing properly)
Jan 27, 2009 | Maytag 24 in. MDB6100A Built-in Dishwasher
Diswasher won't run
first check the circuit breaker box you might hva tripped abreaker, next close the door softly, and listen to perhaps hear the door switch activating, id the door doesnt close (bad switch) no power to rest of d/w
Feb 23, 2008 | Kenmore 15522 Built-in Dishwasher
Whirlpool 24 in. GU940SCG Built-in Dishwasher Logo
108 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
